B&M Racing
Old 04-15-2012, 07:07 AM   #127
paul2010
paul2010's Avatar
Drives: 2012 ZL1 #1278
Originally Posted by hairtrigger View Post
I think 130 is plenty and in race car terms knocking on 10 zero's. For ET they need to launch the heavy car with gear or low end torque. Gear is the easy answer for that and 4.10's will still not hit the limiter in 4th at the stripe at 130.
With 3.70s I hit the revlimiter in the last 100' and needed to bump it up to 7000 to make it without shifting into 5th. Mine is an auto though so not sure whot it would be with an manual.
2012 ZL1 #1278
2010 2nd Place Fastest 4 5th Gen LSX Shootout
2011 2nd Place Fastest 4 5th Gen LSX Shootout
paul2010 is offline   Reply With Quote
Old 04-15-2012, 07:14 AM   #128
Vulpine
'the Outcast'
Drives: N/A
Arrow Reaction time...
Originally Posted by Pgoldston View Post
I like what I see. 10s should be easy with that mph. Are the 60' ft's limited by the tire or testing? As well will a 17inch rim fit on the back with a slick and can you hit the car any harder? I may have missed it manual or auto?
If you dont mind me asking did you get any air temp data?
Sorry for all the questions more interested in data than the actual run, but the run is nice and shows that once time is given the zl1 will be able to kill at the strip and the road course with out affecting each other.
The reaction time looks pretty slow to me as well...
Vulpine is offline   Reply With Quote
Old 04-15-2012, 07:45 AM   #129
Vulpine
'the Outcast'
Drives: N/A
Thumbs up LMFAO...
I hope you are talking about a bull because 8 seconds with anything other than a car or a bull is embarrassing no matter what the circumstances are
Thats not what SHE said...
Old 04-15-2012, 07:57 AM   #130
Vulpine
'the Outcast'
Drives: N/A
Exclamation Opinion...
Originally Posted by 2012ZL1 View Post
more hp to go faster, more gear to go quicker...(in this case) I agree with the 4:10 observation, unless of course you are aiming for real low 10's high 9's in which case more power to the level of needing a forged rod/piston combo I think.
If you go with a 4.10 in the rear don't plan on doing well in autocross with that setup...
Old 04-15-2012, 08:02 AM   #131
Wondering
Wondering's Avatar
Drives: Z06,GS Vert,Ford GT
R/T has no effect on ET.
Wondering is offline   Reply With Quote
Old 04-15-2012, 08:22 AM   #132
Graham Behan
Drives: Various
I figured that.
What do you guys think the hp limit will be on the zl1 with pump gas? Or is that a wait a see thing?
The power curve at the start of the thread, shows a safe number for 93 oct, with cat protection still enabled. If we ran leaner with no cat protection it would easily surpass 600 rwhp.
Graham.
Graham Behan is offline   Reply With Quote
Old 04-15-2012, 09:10 AM   #133
Pgoldston
Drives: 1999 camaro
Graham.
So what I am reading is Non-Emission state ZL1's have more potential....... Im going to be registering this thing in New mexico anyways.
You can lead a horse to water but you cant force people to look at the data
Pgoldston is offline   Reply With Quote
Old 04-15-2012, 09:14 AM   #134
Graham Behan
Drives: Various
Yes, sir, this car was completely stock exhaust and cats and if we leaned out the AFR from the low 11 high 10:1 where its at, 600 rwhp is no problem, without resorting to headers.
Graham.
Old 04-15-2012, 09:48 AM   #135
Pgoldston
Drives: 1999 camaro
Graham.
I had a feeling the AFR was that low. Thats good to hear.
Old 04-15-2012, 10:05 AM   #136
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
Graham,
My planned mods were a 2.55 upper, cai, LT headers,no cats, and a cam like an ls9 or similar.
With a tune, how much rwhp should I expect on 93 octane? race fuel?
Do I need a fuel pump or injectors?
Is it possible to send you my ecm for tuning, and how much is a tune?
Considering the boost drop from the LT's should I consider a 2.38 pulley instead?
Thanks, Mark
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 04-15-2012, 10:19 AM   #137
Graham Behan
Drives: Various
Graham,
Thanks, Mark
Hi Mark,
If you plan headers and a cam the 2.38 will probably be the best solution, you definitely need injectors and probably a fuel pump, we have tested to 20 volts of boosting of the stock pump and although it will deliver enough fuel, we would not advise this for a long lasting solution. Yes it is possible to send the ECM but we do offer an Autocal that can do this, or if you have EFI Live we can E-mail it.
I would estimate 630-640 rwhp could be reliably achieved with these mods, but we will test this configuration early next week, sans headers and let you know. I have no idea on sale price of tune, I just get to do the engineering, oh and like today, build an engine in a yellow car
Graham.
Old 04-15-2012, 10:29 AM   #138
Pgoldston
Drives: 1999 camaro
Graham
What type of fuel system is on the zl1? All my time is on the ford side of things and I havent been keeping up with GM. Is this a modulated returnless system or a return setup?
Old 04-15-2012, 10:30 AM   #139
Fenderaddict2
Opinionated bugger!
Fenderaddict2's Avatar
Drives: Boss 302, Mazda 2, Praga & Intrepid
So just so I understand, to run toe to toe in the HP/TQ numbers with the overpriced '13 Shelby how much do you have to spend on the ZL1? I thought I heard negative comments about having to add track pack and such to the Shelby to get the best out of it? I'm confused...
Follow me on forums everywhere as Fenderaddict2 or my kid on the track and Twitter @fastmyles
Fenderaddict2 is offline   Reply With Quote
Old 04-15-2012, 10:37 AM   #140
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
cold air and pulley does it. My guess less than 500 bux.
2012 ZL1
2012 camaro zl1, 2012 camaro zl1 quarter mile, 2012 zl1, 2012 zl1 quarter mile, 2013 camaro zl1, 2013 camaro zl1 quarter mile, 2013 zl1, 2013 zl1 quarter mile, camaro z1l dyno, camaro zl1 dyno figures, camaro zl1 dyno numbers, camaro zl1 dyno results, camaro zl1 dyno video, camaro zl1 forum, camaro zl1 forums, camaro zl1 quarter mile, camaro zl1 quarter mile time, zl1 dyno, zl1 dyno figures, zl1 dyno numbers, zl1 dyno video, zl1 forum, zl1 forums, zl1 quarter mile, zl1 quarter mile time
Lingenfelter Breaks Deep Into the 9s paul2010 Dragstrip and Launch Techniques Discussion 94 10-28-2011 04:09 PM
FS: 2010 Lingenfelter Camaro Speed74SS Autos For Sale / Wanted 22 07-05-2011 09:35 PM
Drag Suspension??? 10camaross Suspension / Brakes / Chassis 38 05-28-2011 09:54 AM
GM SUPER CHARGER COMMENTS camaro99 Canada 62 01-15-2011 06:27 PM
Some nice runs for the SS and I... MadMav Dragstrip and Launch Techniques Discussion 5 06-13-2010 01:55 PM
