Old 04-14-2012, 05:08 PM   #85
Pgoldston
Drives: 1999 camaro
Im just glad that the first run down the 1/4 wasn't done at Mile High at 5pm in July with a Auto! Actually maybe I do, I think people would be trading them in and I could get one earlier for a steal!
You can lead a horse to water but you cant force people to look at the data
Pgoldston is offline   Reply With Quote
Old 04-14-2012, 05:12 PM   #86
Hoverman
Hoverman's Avatar
Drives: 2010 2ss
Great Job Graham, Of course I never had any doubt. Go LPE!! Mine is running great by the way. Mike
LPE 417 Stroker, 780 Hp, 780 Tq
Corsa Cat Back, LPE gt9 cam
ARH LT Headers High flow cats
Pfadt adj coilovers,Pfadt trailing arms,
Pfadt Dif Bushings, Pfadt rear tie rods
Hotchiss Cassis Brace, LPE 3.91 gears
MGW shifter,Billetprototypes Catch Can
LPE Pedals, LPE Sway bar links
LPE custom ralley stripes, Paint upgrade and 4 coats of clear
Lingengelter Embroidered Headrest
Foose wheels, LPE Brake calipers with slotted rotors
Hotchiss/LPE Strut Brace,
Hoverman is offline   Reply With Quote
Old 04-14-2012, 05:13 PM   #87
boxmonkeyracing
juggernaut
boxmonkeyracing's Avatar
Drives: VRSCF, 2011 SS vert
Send a message via AIM to boxmonkeyracing Send a message via Yahoo to boxmonkeyracing
give it a few months/years and you'll see these start showing up on the lots because people couldn't make the payments or fell on harder times. sad to say but I think some will end up on lots sooner then later.
We do not want to use the Z28 moniker on a car that does not deserve this hallowed name.
boxmonkeyracing is offline   Reply With Quote
Old 04-14-2012, 05:21 PM   #88
Graham Behan
Drives: Various
Originally Posted by boxmonkeyracing View Post
the point I was trying to make with him on a different day you could see 10's. or as the hotrod blog shows worse. conditions will effect every car there not just the ZL1. if there was a GT500 that day it wouldn't be running the best either.
what people are doing is comparing the best GT500 times to an avg day for this car. which shouldn't be done. more passes on different tracks and in different conditions will give a better view of what this car is capable of.
also I think people are confusing the LPE car with the HPE. one manual (LPE) and one auto (HPE). I can see some frustration just in that. oh well. I'm done arguing that this car can see 10's with the mods you have done. I know it's possible.
Hey man, that was not a dig at you, I guess I was trying to say that differing conditions affect things greatly, a lot of people do not understand this. My bad, but on a given daygiven at a given it is what it is.
Graham.
Graham Behan is offline   Reply With Quote
Old 04-14-2012, 05:24 PM   #89
DoggyB22
DoggyB22's Avatar
Drives: 2001 Camaro Z28
Awsome! No video?!?!?!
LT Pacesetter Headers, Moser 9" 3.89 Gears, FAST 90mm Intake & TB, 28" M/T Tires, Tune
Dyno'd 346 rwhp 354 lb tq
DoggyB22 is offline   Reply With Quote
Old 04-14-2012, 05:41 PM   #90
boxmonkeyracing
juggernaut
Graham.
trust me when I say this. when it comes to this I trust what you are saying. and I hope you all slaughter the 10 second barrier quick. give some of these guys something to be happy about.
I for one am content with what you saw that day. good luck.
Old 04-14-2012, 05:44 PM   #91
Pgoldston
Drives: 1999 camaro
Graham,
Do you recall what the car crossed the line at rpm wise and I suspect in 4th gear?
Old 04-14-2012, 05:47 PM   #92
Graham Behan
Drives: Various
Thanks!
Graham.
Old 04-14-2012, 05:48 PM   #93
Graham Behan
Drives: Various
Graham,
5745.
Old 04-14-2012, 05:50 PM   #94
BigHemiSrt
Drives: 07 Dodge Charger SRT8
Tuning is always on the "safe" side, obviously this was done on a race gas tune, the number shown on the 93 Oct dyno sheet is about 4 degrees less, but at less boost. At this boost level the race gas tune has 7-8 degrees more than the 93 tune.
Graham.
Idk what it is on LS engines but my car gained 10rwhp for every degree of advanced timing. If its near the same then 8* of extra timing is huge!! Just writing my thoughts.
BigHemiSrt is offline   Reply With Quote
Old 04-14-2012, 05:51 PM   #95
sasquash1984
502 RWHP N/A
sasquash1984's Avatar
Drives: The yeti
Lpe ftw
factory motor factory trans, Gpi ss4 cam stock heads ported and milled, full exhaust, circle d 5c 4000 triple disk, 3:91 rear end with posi mod, cai, bmr derlin rear diff bushins, bmr derlin cradle bushins, bmr trailing arms, toe rods with bushings, and bmr anti extreme sway bar. Weld rt-s 17x5 fronts and 17X10 rears on mickey thompson et street r's
sasquash1984 is offline   Reply With Quote
Old 04-14-2012, 06:00 PM   #96
ThaCamaroKid
ThaCamaroKid's Avatar
Drives: 2010 Camaro 2SS/RS L99
so just by a pulley swap and different intake they gained 80 hp? the Zl1 is looking better and better everyday...
375RWHP/399RWTQ
ThaCamaroKid is offline   Reply With Quote
Old 04-14-2012, 06:00 PM   #97
Graham Behan
Drives: Various
knock limited
Yes it is huge, depends on the timing response, good old spark looop. The engine will increase in power, with ignition advance, until it plateaus and then loses, assuming it is not knock limited.
Graham.
Old 04-14-2012, 06:02 PM   #98
Pgoldston
Drives: 1999 camaro
Graham
I take it you guys have found what the engines MBT when its not fuel limited?
2012 camaro zl1, 2012 camaro zl1 quarter mile, 2012 zl1, 2012 zl1 quarter mile, 2013 camaro zl1, 2013 camaro zl1 quarter mile, 2013 zl1, 2013 zl1 quarter mile, camaro z1l dyno, camaro zl1 dyno figures, camaro zl1 dyno numbers, camaro zl1 dyno results, camaro zl1 dyno video, camaro zl1 forum, camaro zl1 forums, camaro zl1 quarter mile, camaro zl1 quarter mile time, zl1 dyno, zl1 dyno figures, zl1 dyno numbers, zl1 dyno video, zl1 forum, zl1 forums, zl1 quarter mile, zl1 quarter mile time
Lingenfelter Breaks Deep Into the 9s paul2010 Dragstrip and Launch Techniques Discussion 94 10-28-2011 03:09 PM
FS: 2010 Lingenfelter Camaro Speed74SS Autos For Sale / Wanted 22 07-05-2011 08:35 PM
Drag Suspension??? 10camaross Suspension / Brakes / Chassis 38 05-28-2011 08:54 AM
GM SUPER CHARGER COMMENTS camaro99 Canada 62 01-15-2011 05:27 PM
Some nice runs for the SS and I... MadMav Dragstrip and Launch Techniques Discussion 5 06-13-2010 12:55 PM
