Old 04-15-2012, 12:13 AM   #113
hairtrigger
Drives: 69 Chevelle SS396 2013 ZL1
Originally Posted by Pgoldston View Post
No reason to put 4.10s in it. By my math with the current setup they can run about 140-145 before they would need to get into 5th. Running the 4.10s would force them into 5th and drop the rpm down around 5000 rpm.
I think the 3.73s with the 28 inch almost 29 inch tall tire is about perfect for that car. It makes enough low to mid range torque to pull mid 1.5 60's if not better.
4.10 is the perfect ratio with 28.9 tires. They are crossing the stripe at 5745 with the 3.73's. With 4.10's they will be crossing the stripe at 6200 at 130 MPH with a 1:1 trans gear.
hairtrigger is offline   Reply With Quote
Old 04-15-2012, 12:18 AM   #114
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Originally Posted by Tob View Post
Wait. Was proper break-in followed?
Originally Posted by 2ndCamaro79 View Post
That was sweet, but if your going to mod a ZL1 to go fast straight, would your money be better spent on a SS?
Originally Posted by Graham Behan View Post
Yes its now broken in
Damn straight!
If getting power is that easy why did GM, just not do these things from the start?? Or why don't the 2013s come with a pully change and better cold air unit so you don't have to loose the warranty on a 60K car??
LOL
Originally Posted by adamgl View Post
Baseline time would have been nice.
As well so many people keep pointing out that their ss will keep up for less, thats great but would it be able to keep up on the road course as well. Normally everything is a compromise from one to the other. the ZL1 is starting to show that it will be able to hang pretty good at both tracks with a little work and not upsetting the cars suspension or much of anything else.
Also people talk about the warranty, everything I have seen on this car can be switched back to stock pretty easy unless GM is actually watching how many times the tune is changed. I had heard rumors of this but never got anything solid on it.
They can see if the tune has been flashed.
Originally Posted by 69 Rebel View Post
Throwing 30k in a SS will not get you in the 9's for sure not in the 8's
It could be done.
Originally Posted by peteypab2133 View Post
track conditions were not complained about in the original post, so why defend an issue that doesnt exist? There is no such thing as "perfect" track conditions. If its cold, you cannot hook up and get less heat soak. If its hot you hook up but lose power. Numbers will gravitate towards the middle of those two conditions.
Seat time, assuming its an automatic makes no difference. Are we talking about reaction time's getting better?? As far as I am concerned its as simple as pushing down the far right pedal and letting the ECU shift for you.
So name 2 more please.
You need to make it out to the track more often.
SUX2BU is offline   Reply With Quote
Old 04-15-2012, 12:21 AM   #115
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Exciting stuff, thanks for sharing Graham.
I just picked up a regular SS m'self with the slushbox.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 04-15-2012, 12:26 AM   #116
Pgoldston
Drives: 1999 camaro
It would be perfect if they were planning to not run anymore more MPH. Im sure they plan on going faster
You can lead a horse to water but you cant force people to look at the data
Pgoldston is offline   Reply With Quote
Old 04-15-2012, 12:31 AM   #117
hairtrigger
It would be perfect if they were planning not running anymore more MPH. Im sure they plan on going faster
I think 130 is plenty and in race car terms knocking on 10 zero's. For ET they need to launch the heavy car with gear or low end torque. Gear is the easy answer for that and 4.10's will still not hit the limiter in 4th at the stripe at 130.
Old 04-15-2012, 12:44 AM   #118
rmyers
rmyers's Avatar
Drives: Both American Made
Perhaps because the Camaro's performance may always be boxed in by the Corvette. GM would likely never produce a Camaro with more HP than their top performer and money maker.
rmyers is offline   Reply With Quote
Old 04-15-2012, 12:51 AM   #119
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
more hp to go faster, more gear to go quicker...(in this case) I agree with the 4:10 observation, unless of course you are aiming for real low 10's high 9's in which case more power to the level of needing a forged rod/piston combo I think.
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 04-15-2012, 12:54 AM   #120
hairtrigger
Absolutely correct
Old 04-15-2012, 12:56 AM   #121
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Oh by the way...great job Graham and LPE!!!! (how much is the cold air kit)
2012 ZL1
Old 04-15-2012, 01:09 AM   #122
hognutz
hognutz's Avatar
Drives: 2013 ZL1
Originally Posted by F-MAN-SS View Post
isn't the LSA motor basicaly the same engine in the CTSv? If so why all the amazement at HP increase with pully change?
Cts-v has an LSA in it. 556hp instead of 580hp.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 04-15-2012, 01:12 AM   #123
BLACK10
BLACK10's Avatar
The heck with race gas, we are about to spray one with a dual nozzel alky kit and a smaller pulley.
Lets not forget the race wheels that were run on the car also...Awesome times none the less!
Old 04-15-2012, 03:08 AM   #124
ad445
Drives: ....
Stock 2011 gt500 11.16@124mph....It belongs to this svtperformance member: http://www.svtperformance.com/forums/member.php?u=53649
ps:I own a pully/tune 2011 Gt500 and am thinking of getting auto ZL-1 this summer..
ad445 is offline   Reply With Quote
Old 04-15-2012, 03:15 AM   #125
REAPER SS
REAPER SS's Avatar
Drives: 2010 CAMARO BLK 2SS/L99
Maybe this ZL1 will calm the masses...just maybe
REAPER SS is offline   Reply With Quote
Old 04-15-2012, 06:56 AM   #126
Vulpine
'the Outcast'
Drives: N/A
Wink Go figure!
Shhh...don't let the cat outta the bag!There is a reason it was almost called the panther because panthers ate mustangs! And how else are they going to suprise us to bump up the performance on the ZL1 with the new GT500 2013 stats.
Vulpine is offline   Reply With Quote
2012 camaro zl1, 2012 camaro zl1 quarter mile, 2012 zl1, 2012 zl1 quarter mile, 2013 camaro zl1, 2013 camaro zl1 quarter mile, 2013 zl1, 2013 zl1 quarter mile, camaro z1l dyno, camaro zl1 dyno figures, camaro zl1 dyno numbers, camaro zl1 dyno results, camaro zl1 dyno video, camaro zl1 forum, camaro zl1 forums, camaro zl1 quarter mile, camaro zl1 quarter mile time, zl1 dyno, zl1 dyno figures, zl1 dyno numbers, zl1 dyno video, zl1 forum, zl1 forums, zl1 quarter mile, zl1 quarter mile time
Lingenfelter Breaks Deep Into the 9s paul2010 Dragstrip and Launch Techniques Discussion 94 10-28-2011 04:09 PM
FS: 2010 Lingenfelter Camaro Speed74SS Autos For Sale / Wanted 22 07-05-2011 09:35 PM
Drag Suspension??? 10camaross Suspension / Brakes / Chassis 38 05-28-2011 09:54 AM
GM SUPER CHARGER COMMENTS camaro99 Canada 62 01-15-2011 06:27 PM
Some nice runs for the SS and I... MadMav Dragstrip and Launch Techniques Discussion 5 06-13-2010 01:55 PM
