Old 04-15-2012, 09:14 AM   #1
429LS3WS6
Drives: 2002 Trans am WS.6
help with fast 102 ls3 intake
Hey everyone, i am putting a ls3 into my 2002 ws6. It has a fast ls3 intake on it. What is the spot on the top front for? Also what are the spots on the back for? I am try to plug this stuff up but want to make sure first. Also on the evap canister on the front side can you delete that? Thanks all help is appreciated!
429LS3WS6 is offline   Reply With Quote
Old 04-15-2012, 10:24 AM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Pics would probably help to point out the "spots" you're referring to.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 04-15-2012, 11:36 AM   #3
blackonblacksls
Drives: 2011 2ss/rs
Talking about the spots for the map? One on front and back that' look similar?
Have to be drilled out for appropriate MAf. Till then they are for nothing.
Spots in back are for whatever other vacuum lines you need. I plugged one and used the other for the booster.
blackonblacksls is offline   Reply With Quote
Old 04-15-2012, 02:13 PM   #4
429LS3WS6
I was talking about how it looks like there are two map spots? One on the front and one on the back. Are those two map sensor spots? If i only have one map sensor how do i plug the other one off? And for the evap canister spot in the front by the tb can i delete that? Thanks guys
Old 04-15-2012, 03:49 PM   #5
AG454
I am not "Fast & Furious"
AG454's Avatar
Drives: 2010 Camaro LSX454 1LE
You can use either MAP sensor spot, they have to be drilled out. If one is allready and you are not using it you will have to plug it. Same for the vacuum ports, up front or back, cap what you don't use.
The day I take a bend too fast
Judgement that could be my last
I'll be wiped right off the slate
Don't wait up 'cause I'll be late, I'll be late
AG454 is offline   Reply With Quote
Old 04-15-2012, 04:09 PM   #6
429LS3WS6
Cool thanks. I think i got it figured out. I bought a ls3 map sensor and a ls1 to ls3 map adapter and going to make a blovk off plate for the front. Does someone make a block off for the map?
Old 04-15-2012, 04:18 PM   #7
AG454
AG454's Avatar
I have not seen a block off for the MAP hole if it has been drilled. Maybe use silicone or epoxy to fill the hole?
Old 04-15-2012, 04:37 PM   #8
grocerygetter
instigator
grocerygetter's Avatar
You could make something or get a map sensor and put in its place. A bad one or something.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 04-16-2012, 08:48 AM   #9
429LS3WS6
Thanks guys! I deleted my evap to the back so no gas smell and vented it. Then ran a map extension to the front of the intake and made a metal block off plug. Thanks
Old 04-16-2012, 11:36 AM   #10
SC2150
I take it you swapped heads to rectangle ports from cathedrals, correct?
Old 04-16-2012, 08:55 PM   #11
NC-V
NC-V's Avatar
Drives: cts-v
He is putting a complete LS3 into his ws6. Thought the same thing then re-read the original post.
NC-V is offline   Reply With Quote
fast 102, ls1, ls3, trans am
Cold Air Inductions Intake System! ADM Performance Cold Air Scoop! & Packages! AutoAgenda V8 Bolt-Ons & Tunes 438 11-23-2013 11:49 PM
MACE's Intake Insulator/High Flow's Ported Intake Manifold bmorecam Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 432 12-08-2011 09:26 AM
FS:Mamo Ported FAST LS3 intake tvwilkes V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 19 10-14-2011 11:49 AM
FAST LSxr 102mm intake showed up today! camaro1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 36 04-19-2011 04:54 PM
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 07:02 PM
