HeadlightArmor
Old 04-15-2012, 11:51 AM   #1
Stealth6
IN OMNIA PARATVS
Stealth6's Avatar
Drives: 2011 BLK 2SS/RS LS3
Lingenfelter LS9 clutch...
Need some feedback from anyone that's using Lingenfelter's LS9 clutch or the SLP LS9 clutch system... Thanks.
Stealth6 is offline   Reply With Quote
Old 04-15-2012, 12:09 PM   #2
IDEALG
Chevy's "Rumble" Best!
IDEALG's Avatar
Drives: 2015 ZL1 6 speed
Send a message via AIM to IDEALG
I have the the katech version of this clutch and I love it. has a tad harder pedal then stock so you can actually feel the clutch pedal unlike the stock feel. no chatter
IDEALG is offline   Reply With Quote
Old 04-15-2012, 02:10 PM   #3
Stealth6
IN OMNIA PARATVS
Stealth6's Avatar
Steel or Aluminum flywheel? Are the flywheels balanced? What's the approx. price range for parts and labor? Thanks.
Old 04-15-2012, 02:39 PM   #4
IDEALG
IDEALG's Avatar
http://store.katechengines.com/ls9x-...maro-p220.aspx
Old 04-15-2012, 03:06 PM   #5
Pollock
LS3 M6
Pollock's Avatar
Drives: 2011 2SS/RS
Does this clutch set up fix the pedal sticking to the floor issue.
JRE 470 RWHP Cam, UD pulley, Kooks 1 7/8 Headers w/high flow cats, PCV catch can, Black CAI, ADM racing Scoop, Flowmaster AT Cat Back, VMax TB, BMR Trailing Arms, Toe links and Cradle bushings.
Pollock is offline   Reply With Quote
Old 04-15-2012, 04:07 PM   #6
IDEALG
IDEALG's Avatar
I haven't had any sticking clutch pedal issues so I couldn't say. make sure your clutch hydraulics don't have air in them. I've heard of the clutch pedal sticking problem but i haven't had one to be able to diagnose the problem.
Old 04-15-2012, 06:31 PM   #7
Pollock
LS3 M6
Pollock's Avatar
Drives: 2011 2SS/RS
I suspect the pedal issue is from an over heated pressure plate. My first pass at the drag strip was fine. So was the second. Had issues on my 3rd and 4th passes. It was a test and tune. I did not let the car cool down like I should have between runs. I was trying to ride the clutch a little to help it slip some coming out of the hole. I assume that is were I made a lot of heat.
Old 04-17-2012, 12:54 PM   #8
IDEALG
IDEALG's Avatar
Shouldn't be a pressure plate issue, but yes it does get really hot inside the bell housing, could possibly be the theory of clutch fluid boiling. interesting.
Old 04-17-2012, 09:58 PM   #9
Graham Behan
Drives: Various
No it does not.
Graham.
Graham Behan is offline   Reply With Quote
Sticking clutch pedal issues - Tick Performance feels your pain! Joey@Tick V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 178 06-20-2016 05:36 PM
I want a new clutch, you too????? Sign here tjbusa V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 370 08-10-2013 03:27 AM
Lingenfelter Breaks Deep Into the 9s paul2010 Dragstrip and Launch Techniques Discussion 94 10-28-2011 03:09 PM
Lingenfelter Clutch return spring Heelhook22 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 5 08-10-2011 03:12 PM
Want to order the LS9 clutch! jnm2003 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 0 02-24-2011 04:12 PM
