Gen5DIY
Old 04-15-2012, 01:31 PM   #1
general23cmp
Drives: 2010 RS SS
rear end moaning at low speed turns
Sound familiar? L99 2010
Mine seems to be worse the colder the car is and gradually goes to nearly nothing as it warms up (still a little). Loud enough for me to worry a little. Forward and reverse...
The car has not been driven much in the 2-1/2 years of owning it (1700 miles, I have more than one toy), so I told myself it just needs driven more, but that may not be correct. A few figure 8's in a parking lot usually solves it quickly. The car has been modified, but nothing in the rear. It isn't a clicking or chunking, but a groan-like noise (almost like someone in the car next to you has a really low note on a large subwoofer coming thru).
Anyone? Is this harming anything or just annoying? Could it be exhaust related and not the rear itself (I have stock exhaust from the cats back)?
Thanks for any assistance.
MP
general23cmp is offline   Reply With Quote
Old 04-15-2012, 04:32 PM   #2
ssmike
BliSSard has come!
ssmike's Avatar
Drives: '16 Camaro 2SS, '13 Equinox CRT
I don't know if it's the same thing but my car has a rubbing moaning sound only when backing up and turning. It seems to go away after it's warmed up, kinda strange!
ssmike is online now   Reply With Quote
Old 04-15-2012, 04:52 PM   #3
general23cmp
Drives: 2010 RS SS
Sounds possible. Mine is a very pronounced droning type noise from the back. Nothing once the wheels are straight and nothing noticed at higher speeds.
Old 04-15-2012, 06:55 PM   #4
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
There is a thread on this issue in the warrenty and problem section and I for on had this same issue 3 times, I also did a few posts on my fix, the posi clutches were hanging up, dealrship replaced the entire diff carrier unit and all has ben well since Jan 5th.. Good luck, there is also a TSB on the issue,
MP
Old 04-15-2012, 08:10 PM   #5
general23cmp
Drives: 2010 RS SS
Thanks. I just have a feeling if I drove regularly, it would get better. It has sat a lot an gets quiet after driving a short distance. I my get the fluid checked/swapped anyway though. Couldn't hurt... Thanks.
Old 04-15-2012, 08:39 PM   #6
Jaysin
Jaysin's Avatar
Drives: 2015 Chevrolet SS
Mine was making a similar noise. The dealer rebuilt the rear end under warranty and no issues since.
Jaysin is offline   Reply With Quote
Old 04-15-2012, 08:54 PM   #7
general23cmp
Drives: 2010 RS SS
Thanks. With the mods I have under the hood, I'm afraid they won't do anything under warranty for the rear, even though I haven't touched anything back there.
Old 04-15-2012, 08:59 PM   #8
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Shouldn't matter, the rear is drive train, and any engine mods fall under powertrain, mine is a DD and it made that noise off and on for 5 months before they decided to replace the carrier unit to fix it, been 4 months noise free..Good luck.
Old 04-15-2012, 09:08 PM   #9
general23cmp
Drives: 2010 RS SS
I'll give them a call and see. Couldn't hurt. How long is the drivetrain warranty on a 2010? I've had mine for about 2-1/2 years.
Old 04-15-2012, 09:12 PM   #10
general23cmp
Drives: 2010 RS SS
I hope that works. I could see their argument as to why their rear end is acting up though if I'm putting too much HP through it.
Old 04-15-2012, 09:21 PM   #11
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Not sure on that question, should be 3 yrs or 36000, drivetrain and powertrain.I think. m ine is for 5 yrs..Extended, and the extra power shouldn't make a dirrerence.
Old 04-15-2012, 10:12 PM   #12
bucketobolts
bucketobolts's Avatar
Drives: 2010 2SS
What your describing is the clutch type posi unit in the rear. Nothing is catastrophically wrong with your rear end. You can add a bottle of posi additive GM # 88900330, costs about $10 and I bet your noise will subside.
bucketobolts is offline   Reply With Quote
Old 04-15-2012, 11:01 PM   #13
general23cmp
Drives: 2010 RS SS
Thanks so much. Sounds like a fluid swap would be useful. Just a couple more questions...
You say it isn't catastrophic, but can it harm it if left alone? I don't drive it much, so if it is no harm, I might not worry too much about it. Heck, it probably hasn't had 6 full tanks in it since buying it 2-1/2 years ago.
Is it uncommon for it to be a relatively loud moaning noise when it occurs? I've had LSD rear ends before and nothing sounded like this. Almost like a low volume subwoofer in my trunk holding a single note.
Thanks.
Old 04-16-2012, 07:48 AM   #14
bucketobolts
Drives: 2010 2SS
Nothing is wrong, what you are hearing is the slipping and gripping of the friction clutches in the differential. This is a common condition and really not a problem, just a nuisance.
HUGE Sale. Proven Wicked ProRIGID End Links up to 30% off! Proven Wicked Suspension / Chassis / Brakes 31 06-01-2012 01:10 PM
CEL - P1682 PSU SS Tuning / Diagnostics -- engine and transmission 4 09-29-2011 08:27 PM
Setting up an IRS/Drivetrain for Drag Racing Kyle2k Suspension / Brakes / Chassis 44 06-05-2010 10:17 PM
Suspension guys out there - lets talk wheel hop Crowley Suspension / Brakes / Chassis 14 10-09-2009 01:06 AM
