JDP Motorsports
Old 04-15-2012, 04:09 PM   #1
Tim Adams
Tim Adams's Avatar
Drives: 2016 Hyper Blue 1SS
Sway bar bolts not straight
Just noticed this when cleaning under the hood. Cause for concern? The bars have been in for 14 months, I just never looked this close, it may have shifted, may have been that way from the start. Excuse the crap cell phone pic.
Ordered-Hyper Blue 1SS, A8, NPP, 56W wheels Built 1/20/16
Delivered 2/12/16!!
"The greatest sound in the world is a Rolls Royce Merlin over 100 inches"
www.timadamsphotography.com
Tim Adams is offline   Reply With Quote
Old 04-15-2012, 04:50 PM   #2
grocerygetter
instigator
grocerygetter's Avatar
Bracket gives you room to adjust for each car. Other side is probably like that.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 04-15-2012, 04:58 PM   #3
Tim Adams
Tim Adams's Avatar
I'm looking more at the side to side space. Both nuts are gripping far more surface on the left side of the bracket than the right.
Delivered 2/12/16!!
Old 04-15-2012, 10:37 PM   #4
ActNup NY
ActNup NY's Avatar
Drives: 2011 1LT Black Camaro
Get it checked better to be safe than sorry.
The DREAM is free... It's the HUSTLE that is sold seperately
ActNup NY is offline   Reply With Quote
Old 04-16-2012, 09:03 AM   #5
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
What brand of sway bar is that? Looks like BMR. The OEM clamps have one round hole and one slightly elongated hole. Looks likes there's too much play in those clamps. Did you do the install? I would loosen them up and reseat the clamps and probably put bigger washers on each side and torque it back up to spec.
If you don't do your own work, I use Supercar Performance right in Minooka to do some of my stuff. The owner Scott is a great guy and does all the work, and his labor rates are low. Coincidentally I used him to put my front sway on because I couldn't get the engine up high enough to slide out the old bar. I'm picking my car up this morning after he did a complete flush of my brake system with Motul 600. Getting ready for this weekend at BlackHawk.
bannonm is offline   Reply With Quote
Old 04-16-2012, 09:34 AM   #6
Tim Adams
Tim Adams's Avatar
It's the Eibach bar.
Delivered 2/12/16!!
Old 04-16-2012, 11:18 AM   #7
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Make sure that the bolts holding the brackets in place are tightened to spec, and if you're really worried about it apply a dab of blue loctite to the threads on installation. The brackets placement relative to the studs looks good, but if you wanted to realign it so that it's perfectly even on the shoulders of the nuts it wouldn't be a bad idea.
Long story short, don't worry about it too much. If it's really bugging you loosen the nuts, reposition the bracket and add a dab of blue loctite to the threads of the studs.
Old 04-16-2012, 11:56 PM   #8
L99CAMA2011
L99CAMA2011's Avatar
2012 SS has thicker studs and use 15mm nuts instead of 10mm. You could break off that stud if you mess with it too much, be careful. You could always get a new K member.
Old 04-18-2012, 01:21 PM   #9
Tim Adams
Tim Adams's Avatar
Thanks for the tip. He fixed me up this morning. One of the washers was almost completely worn through.
Delivered 2/12/16!!
Old 04-18-2012, 03:38 PM   #10
bannonm
bannonm's Avatar
No problem. He just finished up my brakes over the weekend. Waiting for the rest of my suspension stuff to get delivered and he'll be doing the install. I'm using Scott because he'll help me fine tune it as well on the track.
SS sway bars on v6? jatt5ab1soorma Suspension / Brakes / Chassis 9 07-07-2011 09:32 PM
Pedders CAMAROSOLUTIONB Sway Bar Kit - IN STOCK JP superior solutions Suspension / Chassis / Brakes 0 06-25-2010 03:07 PM
CAMARO 1998 RED CUSTOM MADE, LEATHER, DVD, CAMERA, NEON kachyok Autos For Sale / Wanted 17 06-22-2010 07:13 PM
