HURST
Old 04-15-2012, 05:51 PM   #1
Janet
Drives: 2015 Z06, 06 Silverado,
ZL1 Valentine 1 Hardwire?
We want to hardwire the V1 radar detector. In the DIY section there is a very good thread, but it is fairly old (2009). Does anyone know if the ZL1 wiring is different in the areas we will be using?
Would one of our lurking GM engineers jump in here please???
Thanks, Janet
Janet is offline   Reply With Quote
Old 04-15-2012, 08:01 PM   #2
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
I used one of these. Much easier than wiring all the way to the fuse box.
http://www.invisicord.com/index.html
ZO6 Bryan is offline   Reply With Quote
Old 04-15-2012, 08:49 PM   #3
The Stig
knows 2 facts about ducks
The Stig's Avatar
Thanks, Janet
The overhead console is the same wiring, so it'll work.
Click to view my build thread
Old 04-16-2012, 12:19 AM   #4
Janet
Thanks guys
Janet
Old 04-16-2012, 12:23 AM   #5
monstertodd
monstertodd's Avatar
could also try tapping off of the side fuse panel. Can't be that much different.
Old 08-05-2012, 05:09 PM   #6
Nightspore68
Nightspore68's Avatar
Drives: 2013 Camaro ZL-1, Victory Red
Janet,
What did you decide to do?
In my SS I had wired it to the fuse box and clipped the detector onto the visor, but that makes it so you can't use the visor. I was hoping for a better solution.
Nightspore68 is offline   Reply With Quote
Old 08-05-2012, 05:10 PM   #7
Nightspore68
So how is your detector mounted? Suction cups? Does it stay in place?
Old 08-05-2012, 07:01 PM   #8
ZO6 Bryan
ZO6 Bryan's Avatar
Yes suction cups right next to the rear view mirror. Stays in place fine. I have all my cars wired the same way so I can just grab the V1 and plug it in depending on what I drive that day.
Old 08-06-2012, 08:46 PM   #9
brucedd
Drives: xxx
Mine is a Escort, but is mounted using a mirror-mount. The invisi-cord does not work on the ZL1 as there is only "always on" power there, nothing tied to ignition, so if you choose to use that, you have to remember to turn off the detector or risk slowly draining your battery.
We tapped into the side dash fuse box, tucked the wire in the moulding, spliced in the invisi-cord and have a nice, neat, custom looking installation that powers on with ignition.
brucedd is offline   Reply With Quote
Old 08-06-2012, 10:09 PM   #10
Nightspore68
There was a nice benefit to using the visor mount - I could leave the detector in the car at all times. You couldn't tell from the outside that it was there (once the wiring to the fuse box was hidden), so I just left it in the car. But every now and again I had to retuck the wire into the molding. And of course I couldn't use the visor.
The mirror mount looks pretty conspicuous. I'm assuming you have to remove it every time you get out of the car?
Old 08-08-2012, 06:11 PM   #11
brucedd
Drives: xxx
No, but I typically am not leaving the car anywhere long or the slightest bit risky. Not SO conspicuous because there is no curley wire to lighter power, but yes it is clearly visible if you look.
Old 08-08-2012, 07:00 PM   #12
fee5fofum
fee5fofum's Avatar
Drives: 2012 CTS-V Coupe & 2SS/RS
Read this DYI on "Hardwiring a V1 or any Radar Detector" here :
http://www.cadillacfaq.com/faq/answers/v1install.html
If you need a Rear view mirror mount and hardwires / mirror taps , I got mine from here :
http://www.blendmount.com/index.html
Hope this helps !
fee5fofum is offline   Reply With Quote
FE3 to ZL1 Zway Bar UpgradeZ and ZL1 ZuZpenZion PackageZ JusticePete Suspension / Chassis / Brakes 111 05-08-2013 11:38 PM
More Camaro ZL1 info!!! MS3DALE Camaro ZL1 Forum - ZL1 Specific Topics 94 06-24-2012 10:44 AM
ZL1 Accessories Sheet? lifter10 Camaro ZL1 Forum - ZL1 Specific Topics 9 02-23-2012 06:05 PM
Spied: Camaro ZL1 Track Package / High Performance Package In Testing?! Tran Camaro ZL1 Forum - ZL1 Specific Topics 321 10-21-2011 10:08 PM
ZL1 vs Corvette- Why do people insist this doesnt exist? Impacts on pricing/perf? Arachnyd Camaro ZL1 Forum - ZL1 Specific Topics 60 09-19-2011 05:13 PM
