BeckyD @ James Martin Chevy
Old 04-15-2012, 06:53 PM   #1
Tom D
Tom D's Avatar
Drives: 10 Camaro SS/RS RJT
Pfadt Coilover question
Noticed on my front Pfadt coilover a bolt that is loose when off the ground on my lift. Does anyone know what this bolt is for? Its the one right above and on the side of the spindle mount bolt. Center of pic head facing camera. Looks like a 15mm bolt. I looked on Pfadt website and no info in install directions and pic does not show it there. Thanks in advance.
2010 2SS/RS RJT, ADM CAI, Borla Shorties, Borla "S" Cat Back, Edelbrock E-Force Supercharger, GMS Wires, GMS Rear Trailing Arms, GMS Rotors, GMS End Links, GMS Tunnel Brace, GMS Rear Tie Rods, GMS 1G Suspension Package, GMS Stage 3 CNC ported heads, GMS Spec'd R12 Custom Ground Camshaft, Snow Meth Injection, GMS Custom Tuned, Norris Catch Can, MTI Brake Lines, Pfadt Coilovers, Sway Bars, Camber Kit, and Rear LCA Reinforcement, , AAC Footwell, Trunk, DRL and Dome LED Lighting, Technostalgia Tail Lights, RED B/A Pedals, Kompression Custom Wheels with Nitto tires, 621RWHP/584RWTQ
Tom D is offline   Reply With Quote
Old 04-15-2012, 08:22 PM   #2
NC-V
NC-V's Avatar
Drives: cts-v
That is a camber adjustment bolt for alignment purposes. You can remove it so it won't back out and damage your wheel. It is only used to adjust camber during an alignment and has no function other then during an alignment.
NC-V is offline   Reply With Quote
Old 04-15-2012, 08:41 PM   #3
Tom D
Tom D's Avatar
Thanks. I was thinking of that but I am no expert with the suspension. Beer on me if you ever make it to Ventura ca.
Old 04-16-2012, 11:49 AM   #4
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Exactly. That bolt was used by your alignment ship as an aid when they were setting up the alignment. The factory alignment adjustment bolt is quite a bit smaller than that, but the bolt that's left there will work just as well.
You can either remove it or leave it in. Either way it's not effecting the performance or operation of the coilover. The bolts you really need to make sure are tight are the two that secure the coilover to the spindle.
Old 04-17-2012, 08:32 AM   #5
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
I bought two high grade bolts to put in those holes after the first alignment slipped. Was probably the alignment shops fault but it's cheap insurance. Just bottom them out and leave them.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
pfadt coilovers and 20x10 forgelines -- wheel rub on the coilover full of days Wheels and Tires Talk Sponsored by The Tire Rack 32 02-28-2013 12:05 PM
Pfadt Sways | In Stock | Best Prices | Free Shipping! JDP Motorsports Suspension / Chassis / Brakes 121 08-30-2012 06:07 PM
Pfadt Race Engineering COILOVER GROUP BUY PfadtRacing Suspension / Chassis / Brakes 55 10-22-2011 07:05 PM
PFADT Race Engineering - Drag Racing, Track or Street DD CRUSHER2SS Suspension / Brakes / Chassis 4 10-27-2010 02:05 PM
