| 3rd Generation Camaros 1982-1992 Camaros |
Thread Tools |
![]() Drives: 85 and 87 irocs Join Date: May 2009
I'm working on a 87 iroc with a 350 tpi. It runs pretty good but when its idling, it idles fast then slow. I can't keep the check engine light off to check the codes. The book says it could be a bad prom or not grounded well. I've checked the grounds that a can see easy. The computer #is 1227165, the prom could be an after market? Don't have the # on it tonight. Anyone got any Ideas?
![]() Drives: 1999 Z28 1983 Z28 Join Date: Nov 2008
What codes are you getting? Do you know how to pull codes?
Current cars:
![]() 1983 Z28 1999 Z28 201x Z28? |
If I take the cable off the or unplug it the light come right back on and when I try to get the codes the light just stays on ?
So your not getting code 12?
Current cars:
No just a solid light.
#6 |
If no code 12 then the ECM is bad. Here is a list of ECM's that will interchange. Keep in mind you still need your PROM out of your ECM to plug into your new one.
1987-90 Astro/Safari Van with 2.5L 4 cylinder 1987-88 Blazer S10/Jimmy S15 with 2.5L 4 cylinder 1991 BlazerS10/Jimmy S15 with 4.3L 6 cylinder (with 1227165 ECM) 1991 Bravada (with 1227165 ECM) 1987 Camaro/Firebird with 5.7L 8 cylinder 1988 Camaro/Firebird with 5.0L 8 cylinder with MFI 1988 Camaro/Firebird with 5.7L 8 cylinder 1986-87 Camaro/Firebird with 5.0L 8 cylinder with EFI 1989 Camaro/Firebird with 5.0L 8 cylinder with MFI 1986 Cavalier/Cimarron with 2.0L 4 cylinder and manual trans 1989 Camaro/Firebird with 5.7L 8 cylinder 1986 Firenza/Skyhawk/Sunbird with 2.0L 4 cylinder and manual trans 1986-89 Corvette 1987-91 S10/S15/Sonoma with 2.5L 4 cylinder 1991 S10/S15/Sonoma with 4.3L 6 cylinder (with 1227165 ECM)
Current cars:
#7 |
![]() ![]() ![]() Drives: 2004 GMC Sierra SLT 4x4 Join Date: Feb 2008
Something simple could be your gas cap is lose.
On the 8th day God created the Camaro and all is good.
#8 |
OBD I doesn't have a code for that.
Current cars:
#9 |
black tape...sold in rolls in most hardware stores. $.79. Solved.
#10 |
Yea I had to use the tape on a dodge one time,but I was trying to get it fixed so it would idle right etc.
| Thread Tools | |
| Lingenfelter 2010 Camaro Engine Packages - up to 800hp! | Sizzox | 5th Gen Camaro SS LS LT General Discussions | 108 | 04-14-2010 07:09 PM |
| If I bought the LT could I engine swap for a v-8 engine down the road? | PD123 | 5th Gen Camaro SS LS LT General Discussions | 40 | 03-22-2009 03:54 PM |
| how reliable is the LS3? and why so big? | 1982camaro | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 73 | 02-06-2009 08:15 PM |
| BMEP-Or why you only need 1 camshaft | rayhawk | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 25 | 12-03-2008 12:28 AM |
| Camaro ls3 news...true or false? | Dark Knight | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 74 | 06-05-2008 05:29 PM |
