Old 04-15-2012, 08:31 PM   #1
SilvrRS
SilvrRS's Avatar
Drives: 2010 Camaro 2LT RS
Rubber strips fading
My rubber weather strips along the windows are
Fading from sunlight. Any idea to make them black again?
SilvrRS is offline   Reply With Quote
Old 04-15-2012, 08:33 PM   #2
Out4it
Banned
Drives: 2011 2LT/RS
Adams Super VRT or In and Out spray
Out4it is offline   Reply With Quote
Old 04-15-2012, 08:39 PM   #3
midnighter
Drives: nothing
Armor all
Old 04-15-2012, 08:46 PM   #4
David79z28
David79z28's Avatar
Drives: 79Z28 and 2010 2SS/RS
I use Meguair's #40 vinyl and rubber conditioner.
http://www.autogeek.net/meg40vinrubc.html
David79z28 is offline   Reply With Quote
Old 04-15-2012, 08:52 PM   #5
GlennP
Drives: 2011 Camaro 2SS
VRT
GlennP is offline   Reply With Quote
Old 04-15-2012, 09:27 PM   #6
Dznts
Anabolic Connoisseur
Dznts's Avatar
this!
Old 04-15-2012, 09:28 PM   #7
The Stig
knows 2 facts about ducks
The Stig's Avatar
Super VRT FTW
Click to view my build thread
Old 04-15-2012, 11:06 PM   #8
midnighter
Drives: nothing
Trim re-nu by Auto Tech is an excellent product.
Old 04-15-2012, 11:50 PM   #9
Iomcamaro
The enjoyment never ends
Iomcamaro's Avatar
Drives: 2010 1LT/RS IOM #25223
The fading is actually oxidization of the rubber. You need to properly clean it with an all purpose cleaner of your choice, then top it with something such as VRT or some other dressing of your choice to prevent it from happening again. If you don't clean the surface, when the VRT wears off, it will look just as bad. Also leaving the surface unclean before you dress it will prevent your dressing from penetrating the rubber therefore the dressing won't last nearly as long.
Iomcamaro is offline   Reply With Quote
Old 04-15-2012, 11:59 PM   #10
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
Correct on all points. Also the oxidation of exterior rubber can be made even worse by the use of harsh detergents. If you use touchless washes for example - often times the chemicals used are rather aggressive (they have to be in order to clean without mechanical agitation) and will prematurely dry rubber trim. There can also be environmental factors... my friends who live near the beach have horrible fading and oxidation on their trim thanks to the salt air and lots of sun exposure.
As the others mentioned, clean well and dress with a water based dressing, assuming they're not too far gone they'll look good as new.
Old 04-16-2012, 07:30 AM   #11
OrangeFury
Camaros Of Northwest Ohio
OrangeFury's Avatar
Drives: 2010 IOM 1LT, 1974 Corvette
How much should the APC be diluted for cleaning this area? Concerned about getting it on my paint while cleaning the rubber.
Camaros Of Northwest Ohio is on Facebook!
http://www.facebook.com/#!/pages/Nor...93610744003149
OrangeFury is offline   Reply With Quote
Old 04-16-2012, 08:07 AM   #12
Iomcamaro
Iomcamaro's Avatar
Spray it onto a towel and scrub the rubber. It won't have any overspray then. Also make sure to rinse the area before dressing to make sure all of the apc is off. You can just rinse with a wet towel.
Old 04-16-2012, 01:46 PM   #13
nUcLeArEnVoY
Oldbie that nobody knows
nUcLeArEnVoY's Avatar
Drives: 2011 1SS/RS M6
Wolfgang probably makes one of the best trim protecants, but it's $20.00 for a 3 oz. bottle.
The challenge of finding a good trim protectant is one that...
1.) Isn't too greasy
2.) Provides a nice, uniform black color
3.) Most importantly IMO, doesn't run or come off when it rains.
So far, only a handful of companies make trim protectants that bead water and don't run off. Adams and Wolfgang are two of them.
nUcLeArEnVoY is offline   Reply With Quote
5th Gen Suspension -- The Book JusticePete Suspension / Brakes / Chassis 151 05-07-2015 05:52 PM
New Product Alert!! - Oracle Remote SMD Strips Ivan @ Southwest Speed Interior Parts & Accessories 8 06-30-2012 12:15 PM
Help with cleaning rubber strips... SilvrRS Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 5 11-29-2011 08:47 PM
100% Waterproof LED Strips with 12pcs of 5-5050 SMD LEDs starting at $12.95 each! Xenith Xenons Interior Parts & Accessories 54 01-23-2011 06:00 PM
How to protect against paint fading. scythezo6 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 6 08-25-2009 12:01 PM
