Solo Performance
Old 04-16-2012, 07:33 PM   #1
david6509
Drives: 2010 Camaro 2SS
Send a message via MSN to david6509
Problems with my camaro cutting power
Guys have had this problem for about 2 weeks. The car seems to be alright when cruising around but as soon as i put my foot down more than half way the car hesitates and just behaves erratically. I had the error code P0358 come up. Anyway the car has a cam and supercharger and its only done about 5000miles, anyone with some information that could help me would be much appreciated.
david6509 is offline   Reply With Quote
Old 04-18-2012, 04:53 AM   #2
david6509
bump any ideas?
Old 04-18-2012, 05:14 AM   #3
1954 Belair-man
1954 Belair-man's Avatar
Drives: 2010 Camaro IOM 1SS M6
I'am not up to speed on error codes but it could be maybe you got a bad batch of gas, sorry i can't help ya more
1954 Belair-man is offline   Reply With Quote
Old 04-18-2012, 06:31 AM   #4
TriGun
TriGun's Avatar
Drives: Camaro 2SS/RS Ice Silver
I have a magnacharged camaro L99. I was having troubles with knock retard values between 2 and 7 at cruising and about 13 at WOT, I checked the car from bumper to bumper looking for any rattles or loose bolts may trigger the knock sensor and I found none.
Later on I replaced the stock plugs with ZR-1 plugs and the wiring to MSD wiring, although I replaced my plugs before 3000 miles. After replacing the Max knock ret values are between 1.5 to 2 at WOT and constant Zero at cruising.
So check your plugs.
TriGun is offline   Reply With Quote
Old 04-18-2012, 08:01 AM   #5
david6509
Will check the spark plugs tomorrow, i do remember when the extractors where getting put on he did mention something about the spark plugs. I was looking at changing the leads and plugs anyway. Who sells the zr1 spark plugs?
Old 04-18-2012, 12:31 PM   #6
TriGun
TriGun's Avatar
They are ACDelco 41104 Iridium Spark Plugs.
I purchased them from the dealer. It is about $10 a plug,
Old 04-23-2012, 12:46 AM   #7
david6509
Just an update the car isn't actually misfiring it is actually closing the throttle at around 3000RPM. My spark plugs will arrive tomorrow so hopefully these will fix it. Fingers crossed.
