Old 04-16-2012, 09:36 PM   #1
GraySS2011
GraySS2011's Avatar
Drives: 2011 Cyber Gray 2SS 6 speed
videos showing how to change MN6 trans fluid for a V8?
I've found videos for V6's and automatics. Can someone point me to a video showing the process of changing the transmission fluid for a V8 MN6?
Thanks,
Bob
2011 2SS RSS , MN6, CGM
http://www.angelfire.com/hi/nicecorvette <----- My Cars and Trucks
GraySS2011 is offline   Reply With Quote
Old 04-17-2012, 10:28 AM   #2
MileMAN402
RIP JoePa
MileMAN402's Avatar
Drives: 2010 2SS/RS & 2001 Audi S4
It's not hard. The plugs are pretty obvious. Just drain it then use the hose through the engine bay method to fill it back up.
MileMAN402 is offline   Reply With Quote
Old 04-18-2012, 06:39 PM   #3
GraySS2011
GraySS2011's Avatar
It was messy but pretty easy...The big letters next to one of the plugs was a dead give a way FILL ...so I removed that one first. A little fluid came out. The only surprise was when I removed the drain plug. I had just returned from the dealership where I purchased 4 quarts of the GM tranny fluid that is referenced in the Owners manual, so the fluid was hot. The fluid did not ooze out, it exploded out missing my catch pan as I quickly adjusted it. About a half quart hit me and the floor. I used a syphon hand pump and pumped in 4 quarts from underneath the car. It started running out the fill plug so I knew it was full.
Next project bleed the brakes ..but not today
Bob
Old 04-18-2012, 09:13 PM   #4
MileMAN402
RIP JoePa
MileMAN402's Avatar
Bob
How much did the stealership charge you for that. Why didn't you put some better stuff in?
Old 04-19-2012, 03:39 PM   #5
GraySS2011
GraySS2011's Avatar
I thought about using Royal Purple but since the car is still on the full GM warranty I decided to stay with what is recommended in the manual. It was not expensive at about $7.00/qt. It says for manual transmissons and transfer cases on the bottle.
Bob
Old 04-19-2012, 03:48 PM   #6
GraySS2011
GraySS2011's Avatar
If anyone is interested this is the siphon/pump I used. I think I got mine at Autozone..I have used it many times to fill differentials and transmissions.
I usually fill a large plastic bowel with the fluid and siphon it from there. I tried siphoning from the bottles but bottles can tip especially while working under the car. Handy tool.
http://compare.ebay.com/like/1706964...Types&var=sbar
Bob
Old 04-19-2012, 04:28 PM   #7
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Bob
Sounds like it might be the wrong fluid!
-Mark.
Old 04-19-2012, 10:38 PM   #8
UCI CamaroFan
Zot!
UCI CamaroFan's Avatar
Drives: Toyota 4Runner
The manual says that the oil in the transmission will never need to be replaced
UCI CamaroFan is offline   Reply With Quote
Old 04-19-2012, 10:50 PM   #9
MileMAN402
RIP JoePa
MileMAN402's Avatar
It's also synthetic blend and when I added redline to my trans (and diff) it made a noticeable improvement in shift feel and temperature control. If you drive your car hard you should never listen to the manual, it will always be higher mileage than when you should change all oils. Same with the onboard engine oil life meter although it does adjust to your driving style somewhat.
Old 04-20-2012, 04:18 PM   #10
GraySS2011
GraySS2011's Avatar
-Mark.
No Mark it is the proper fluid GM # 88861800
$7.81 / qt I paid $5.90 with my discount
Bob
Clutch fluid contamination problems on Vette fixed for Camaro??? LDGn63 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 05-28-2012 10:17 PM
How to Take Care of Your Clutch The Stig V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 2 10-25-2011 08:46 PM
