| Forced Induction - V8 V8 Supercharger, turbo, nitrous discussions |
Thread Tools |
![]() Drives: ABM SS/RS Join Date: Sep 2009
Torq dual pass/dual fan heat exchanger
I completed my install of the new Torq heat exchanger just a little over a week ago. Took a few pics and videos to share with everyone. I was very impressed with the build quality of the unit right out of the box. This was a replacement for the stock Whipple heat exchanger. Install was straight forward and not that difficult. I would recommend that when installing the unit you may want to do two things: Install the top hose and the pump on the bottom mounting bracket before dropping the unit in place. I didn't do this and had to pull it back out to get these two items connected. My pump was initially mounted on the bottom drivers side of the car, just off to the bottom side of the Whipple exchanger. Torq designed their exchanger with a pump mounting bracket on the center bottom which i found to be great. I had to switch the direction my pump was facing but that wasn't a big deal. The pump location/mount is in a great position now. I haven't gotten to run the car hard yet to check IAT's but I will attach a video showing IATs after 10-15mins of idling in the driveway. Also, I did monitor IAT temps when driving 85miles of twisty roads. The IAT temps mostly ran at ambient air temp and went up only around 5 degrees after a WOT straight line burst of 1/8 mile or so. As for the fans, I've noticed a lot of folks asking "are they loud?" You can hear them most when you're right in front of the car. Other than that you really don't know they're running. However, to be fair my ride is anything but quiet so if someone were to put this on a quieter running car I imagine the perception would be that the fans would be louder. Anyway, I'll stop rambling and just say if you're looking for a quality heat exchanger I would recommend Torq! I'm pleased with the product and the service has been exceptional as well.
Pics: New Torq dual fan heat exchanger Whipple exchanger on car before removal Whipple/Torq exchanger size comparison
Initial start up after install
![]() ![]() ![]() ![]() Drives: 2010 2ss/RS 4l80. 2009 2500 HD Join Date: Mar 2009
That should keep you running cool. Good work JD.
D1SC-LG G6x3-SW 2" Headers-DMH Cutout-3" Flowmaster A/T-ADM Dual Fuel-ADM Boost,Air/Fuel gauges-Nitto NTO5r-SJM line lock-Modded LS3 Oil pump-BMR-Toe Bar,Trailing Arm,Sub Connectors,Cradle Bushings-Shep Tunnel brace-MSD Shift Light,2Step-CINCY SPEED Tune-DSS 9" Conversion..3.70s gear
ALKY Control-Extream Innovations Roll Bar- 4l80!! 763RWHP 629TRQ |
Awesome write-up, great job and thanks so much! I knew you would be happy with it but it's great to hear it from you
![]() Btw, your videos are marked as "private". You might need to change the settings in your youtube account /Erik |
![]() ![]() ![]() Drives: Silver 2010 SS Camaro Join Date: Jul 2009
Good job JD!! This is in my near future lol.
MODS:
Whipple 2.9L SUPERCHARGER 666RWHP 562TQ ADM Stage 2 Cam ADM Dual Fuel Pump System ADM CAI ADM Boost & Air Fuel Ratio Gauges Patriot Performance Dual Valve Springs Hurst Short Throw Shifter KW V1 Coilovers Stainless Works Full Length Headers & Full Exhaust Elite Engineering Catch Can Forgeline GA3 Satin black wheels 20x9.5-20x11 |
#6 |
Nice job, thanks for the write up. We can compare fan noises on the 28th. Mine goes into Cincy on the 23rd.
Very anxious about the fan noise, but like yours, I'm sure my exhaust will drown it out unless I'm in front of it.
Built and tuned by Cincy Speed
C5FestIII 2012 Photo by Mindz |
#7 |
Thanks for the kind words. Just letting everyone know we have these IN STOCK ready to ship
#8 |
![]() Drives: 2010 2SSRS, 11 CTS-V, 12 Denali HD Join Date: Apr 2009
I know it's off the subject, but what kind of gauges are you using, and where did you mount them? The guy doing my install doesn't want to install over my a-pillar airbag.
Thanks |
#9 |
![]() ![]() ![]() ![]() ![]() Drives: Rally Yellow 2SS/RS #37115 Join Date: Oct 2009
#10 |
#11 |
We haven't been in real hot temps yet but so far on daily drives the temps are staying down. Stop and go traffic I will see temps up to 105-115 but as soon as I move they are dropping real fast down to a constant 94. Also the time it takes to see temps rise are a lot longer. Thanx torq...
#12 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 LS3Camaro2SSRS IOM in/out Join Date: Aug 2009
IAT sensor
Is your IAT sensor relocated below the whipple, or reading just after the air filter via the MAF sensor?
707 RWHP 655 TQ @91,TVS2300 10/14 OD 2.75/NW 102mm,RDS NLP spoiler/GM splitter/Torq HE & fans/oil & tranny coolers LPE Twin Pump,GT9,Coil Covers,Mats,Pedals/ADM Gauges,Race Scoop/Trunions DDS CVs,Carbon F DS/RPM L6/LPE 9.5 3.73/Pedders HD bushes,align kit RB 2-piece rotors,S/S Lines,Hawk HPE Pads/Forgeline SP3P/Weld RTS Ceramic ARH 2" LT/3" X-pipe,Corsa Touring/BMR TA,Toe,LCA,DS Loop StreetSlayer BC3,MTI Shifter & Trans mt/Hotchkis CB/Elite CC/SJM LineLock PFADT Coil Overs,Bushes,Sways/Links,Engine Mounts,SF Bushes,Camber Kit LPE Brotherhood ![]() . |
#13 |
Heres a good idea of what to expect in the hot weather. We have been hit with a heat wave here in NJ and I took the car out for a trip to NYC and back. We were at 93 degrees outside temps and the IATs were at 118-123 cruising at a steady 65 mph. We hit some stop n go traffic and saw IATs got up to 133-138 and not any higher. As soon as I moved it started dropping back down.The drop in temps as soon as you start to move is great.
| Thread Tools | |
| g5cr cai system anybody install or looking at one "pics" | camarossrs2150 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 41 | 07-14-2011 08:26 PM |
| Torq - South Florida's #1 Camaro Destination - ONE STOP SHOP | Meister@Torq | USA - Southeast | 21 | 02-11-2011 10:14 AM |
| Hot air Intakes -By Kenne bell | ADM PERFORMANCE | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 66 | 02-08-2011 08:33 PM |
| List of Intakes that will work with the TVS-2300 MagnaCharger | JJ2010 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 26 | 03-19-2010 02:11 AM |
| AirAid Cold Air Intake anyone? | Flynnaz | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 12 | 01-01-2010 09:05 PM |
