Old 04-17-2012, 10:17 AM   #1
ITGuy11
Burning up tires
ITGuy11's Avatar
Drives: 2010 Camaro 1SS/RS
Pfadt LCA Bushing install help
I purchased these sets of Pfadt bushings:
http://www.pfadtracing.com/catalog/p...roducts_id/198
http://www.pfadtracing.com/catalog/p...roducts_id/195
I can't seem to find any installation instructions for these bushings. I currently have the cradle removed for sub frame and diff bushings that I am installing.
I am assuming that I need to remove the lca's and press out the inner bushings with a press and replace with the Pfadt bushings. The diameter of the new bushings seem larger than the than the opening.
Anybody have any tips?
Blower, cam, supporting mods 644RWHP 615RWTQ
My Build Thread COTW 11/19/12
Detroit 5th Gen Camaro Club
ITGuy11 is offline   Reply With Quote
Old 04-17-2012, 10:29 AM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
The best resource for technical support is going to be Pfadt themselves. They can be reached at 888-972-2464. Keep in mind that they are in Salt Lake City so they are probably just getting in.
Old 04-23-2012, 12:38 AM   #3
Bill Waters
Drives: 2011 RS/SS; 1965 Cobra Factory Five
ITguy11 - I am in the midst of a Pfadt stage 5 install. I called Pfadt regarding the absence of any instructions for the bushing kit. As usual, the Pfadt folks were very pleasant but -unusual for them - did not have any specific suggestions regarding the bushing installation. I have not yet done the LCA bushings, but, based on doing the upper rear, the bushings consist of a formed sheet metal outer shell containing a bonded rubber bushing, also bonded to the metal inner sleeve. So there is little in the way of a surface to use press tools to push the bushing out. I had to use a sawzall to cut circumferentially around the inside of the steel shell, then use a fine metal- cutting blade to cut almost through the shell to weaken the wall (without cutting into the CA), then use punches to peel the shell inward, where if done properly, it will split along the line cut into the shell. I find all of the install much more time- consuming than anticipated. I will keep you posted if I discover anything helpful.
Bill
Bill Waters is offline   Reply With Quote
Old 04-23-2012, 07:53 AM   #4
ITGuy11
Burning up tires
ITGuy11's Avatar
I ended up getting all of my bushings changed. I brought the lower control arms to work and had a guy turn down a piece of bar stock to the exact size needed to press out the factory bushings. You are correct, there is very little surface to press the stock bushings out, but once the rod was the correct diameter they came out with ease using a press.
Old 04-23-2012, 11:23 AM   #5
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
The easiest way if you've got access to a press is to remove the control arm completely, use an appropriately sized socket or as mentioned above a piece of bar stock and press it out. Once you've got the process down the other size is a breeze.
Just like the other steel sleeved bushings on the Camaro using a sawzall to remove material and then weaken the steel sleeve also works... but in our experience since the control arms aren't particularly difficult to remove it's probably easiest to take them over to a press or machine shop and have them quickly pressed out.
Pfadt Sways | In Stock | Best Prices | Free Shipping! JDP Motorsports Suspension / Chassis / Brakes 121 08-30-2012 06:07 PM
Pfadt Race Engineering's newest distributor is... Apex Motorsports Suspension / Chassis / Brakes 6 06-12-2011 11:53 AM
Pfadt Rear Tie Rod Install Clj73 Suspension / Brakes / Chassis 5 06-01-2011 02:53 PM
Pfadt Coilovers, special CAMARO5 member PRICING of $2099!! PfadtRacing Suspension / Chassis / Brakes 6 10-21-2010 11:47 AM
Vengeance Racing Install Pfadt Coilovers/Swaybars/Trailing arms on 2010 Camaro... Ron@Vengeance Suspension / Brakes / Chassis 11 09-14-2010 09:49 AM
