Emblempros
Old 04-17-2012, 11:14 AM   #1
caligrown562
Drives: 2012 1SS
2012 ss m6 1st gear problem
I just bought my ss and it only has a couple hundred miles on it... I have been having a problem where it doesn't always want to go into 1st.. I have been stuck at green lights fighting it to go... is this normal or what could be the problem? thanks
caligrown562 is offline   Reply With Quote
Old 04-17-2012, 11:17 AM   #2
toml_pa
ʇuɐıʌǝp lɐıɔos
toml_pa's Avatar
Drives: 2011 2SS/RS LS3/M6
I have not heard of one not going into 1st gear. I would take it back to the dealer and have them check it out.
Way too many mods and way too much money. Wouldn't have it any other way.
toml_pa is offline   Reply With Quote
Old 04-17-2012, 01:37 PM   #3
caligrown562
Drives: 2012 1SS
it's only done it a couple times driving a short distance... maybe the tranny ain't warmed up yet?
Old 04-17-2012, 01:41 PM   #4
JoshBobGuptaMarley
Emerald Coast Camaros
JoshBobGuptaMarley's Avatar
Drives: '12 2SS/RS LS3 GBA
Yes mine is very tight when it's cold. Just don't force it too hard. I have the hurst shifter and it does seem to break in, I've noticed it soften slightly. I'm at over 2k miles and I haven't noticed it anymore.
Muffler Delete, Cold Air Inductions intake, Technostalgia Sequential LED Tail Lights, Vmax CNC Ported TB, RX Catch Can, AAC LED Interior Lights (Aqua)
JoshBobGuptaMarley is offline   Reply With Quote
Old 04-17-2012, 01:51 PM   #5
Russell James
Russell James's Avatar
Drives: Camaros
Mine is the same way, sometimes when stone cold I can't get it to go into any gear. Once I can get going though, after a mile or so it straightens out. I'm hoping something is just a bit too tight and may break in, I'm still under 1000 miles.
Old 04-17-2012, 02:56 PM   #6
sloSS
sloSS's Avatar
Drives: 2012 Camaro 1SS RS LS3
If it doesn't want to go into gear from a stop, try shifting back to neutral, let the clutch pedal back up, depress clutch pedal and try to put into gear again.
Sometimes the gear rotation is stopped due to the syncros and the gear teeth high points are touching preventing gear engagement.
sloSS is offline   Reply With Quote
Old 04-17-2012, 09:05 PM   #7
Kal-El
Kal-El's Avatar
Drives: 2012 Camaro ss/rs
Same here but I notice its much smoother once I drive it around a bit. I especially have a tough time getting it into reverse backing out of the garage when first started
Kal-El is offline   Reply With Quote
Old 04-18-2012, 12:26 AM   #8
piticu667
Drives: 2010 Camaro
thats how my issues started on mine... if my hunch is correct they might not have screwed in the pressure plate bolts properly.. drive it carefully and monitor for degradation.. if you feel it happening take it and ask them to check the flywheel..
piticu667 is offline   Reply With Quote
Old 04-18-2012, 12:51 AM   #9
Jims73z
Jims73z's Avatar
Drives: 1973 z28 Rs , 2012 SS/Rs Blk/Blk M6
It's normal and in owners manual. 9-30
My 2000 ss was this way for all 170000 miles. You get used to it.
Jims73z is offline   Reply With Quote
Old 04-18-2012, 01:27 AM   #10
iHasCamaro
Drives: Silver 2012 1SS
Normal when cold and especially before broken in. There are 3 synchro's on 1st & 2nd gear on these trannies. When warm mine shifts like clockwork, and even more so now that it's pretty much broken in.
But yeah DON'T FORCE IT just slightly lift up on the clutch a bit and let it slot into gear.
iHasCamaro is offline   Reply With Quote
Old 04-18-2012, 06:34 AM   #11
xx_ED_xx
xx_ED_xx's Avatar
Drives: 04 Silverado
This isnt normal, First i would make sure the tsb is at least checked about the pressure plate and other related issues. There has been some sucess with putting a better quality trans fluid in. A guy recently on here has been modifing the stock clutch masters and it seems everyone who has had shifting issue so far has had them fixed with his upgrade clutch master.
Also there is more then 3 synchros in this trans
If you give me your vin i can look up warranty and tsb info for your particular car.
xx_ED_xx is offline   Reply With Quote
Old 04-18-2012, 06:49 AM   #12
iHasCamaro
Lol I mean 1st and 2nd have 3 synchros each, not that there are only 3 total.
It's totally normal. Same with any manual I've owned. If it gets worse take it in. but it SHOULD get better.
Old 04-18-2012, 06:54 AM   #13
IDEALG
Chevy's "Rumble" Best!
IDEALG's Avatar
Drives: 2015 ZL1 6 speed
Send a message via AIM to IDEALG
It should go into gear without forcing it whether its cold or hot. If its cold in your area say 60 degrees or colder just let the car warm up a bit before using it. I know mine feels tight and sometimes hard to get it into gear when its that cold.
IDEALG is offline   Reply With Quote
Old 04-20-2012, 05:12 AM   #14
Slickcas
Drives: 12' 2SS/RS LS3 IBM
When the car is cold and I pull up to a stop light I found that if push in the clutch shift in to 2nt then keeping the clutch pushed in it goes into 1st very easy every time.
Slickcas is offline   Reply With Quote
2012 ls m6 1st gear shift noise??? SoCalThug Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 18 01-18-2013 01:55 AM
2012 SS Manual - Reverse pops out of gear dcplus14 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 10 03-27-2012 09:28 PM
The 2011+ Mustang Thread GatorBlue371 General Automotive + Other Cars Discussion 11874 08-23-2011 12:30 PM
Do you want the Z28? ChrisB Camaro ZL1 Forum - ZL1 Specific Topics 1616 09-04-2010 11:49 PM
Clarification Please! L99 and 1st gear Ace 5th Gen Camaro SS LS LT General Discussions 6 05-22-2009 03:34 AM
