SDTW Custom Wheels & Tires
Old 04-17-2012, 09:47 PM   #1
Chavira2009
Chavira2009's Avatar
Drives: 2011 Camaro 2SS/RS M6 Hurst RJT
AAC LED Side Markers
Not to long ago I purchased a set of the LED sidemarkers from AAC. And may I say, they look great!!! But, I'm having a problem with my cars lighting. This is what's going on... This is at night by the way, when the lights are on... I turn the car on, and everything works normally like it should. But after 20 or 30 seconds my left side marker turns off and so does my left halo. My fog/drls also turn off as well. I have the Fieldgoal DRL harness, if anybody is familiar with it. I think I know what the problem is, but wanted to know what you guys thought. I think the LED sidemarkers aren't drawing enough current like the regular light bulb style sidemarkes do. Maybe that is causing this? Any help would be appreciated.
Chavira2009 is offline   Reply With Quote
Old 04-18-2012, 10:29 AM   #2
Chavira2009
Does anyone have any ideas?
Old 04-18-2012, 11:58 AM   #3
AACstyle
AACstyle's Avatar
Drives: www.CamaroLighting.com
Yes, you should contact Jeff (Fieldgoal) and let him know the situation. From your description it is very apparent that the controller causing the issue. The current of the sidemakers is not monitored by the BMC and would not cause this.
AACstyle is offline   Reply With Quote
Old 04-18-2012, 01:48 PM   #4
Chavira2009
Do you happen to know how I can get in contact with him?
Old 04-18-2012, 01:53 PM   #5
AACstyle
AACstyle's Avatar
PM'd you
Old 04-18-2012, 05:57 PM   #6
GearHeadPeter
US Navy Vet
GearHeadPeter's Avatar
Drives: 2011 2LT/RS, 65 Mustang GT Fastback
I had the same issue with mine not too long ago. I think the dealer reflashed my BCM because after that I had the same issue as the OP and I also had FieldGoal's DRL harness. After much trying on FieldGoal's part and mine I just added two diodes to my DRL harness and took off the relays and such. It has been like that for about 8 months now and I have not had an issue with it again.
2011 - 2LT/RS - RY, A6, Gray Interior - Team LLT:
3rd Camaro on this forum to have a Mylink installed. Installation by GEN5DIY, Heritage Grill, Lloyds Premium Ebony Camaro RS floor mats, Empire Billet Camaro Black sill plates, AAC: LED footwell & interior lighting, Rear Courtesy Lights, LED side markers/turn signals, Plasma P13W DRl bulbs, Formula 1 Pinnacle Series tint, Roto-Fab Yellow CAI & Fuse cover, Technostalgia Afterburner LED taillights, EmblemPros custom V6 hydrocoated carbon fiber/RY engine cover, Pfadt Sport sway bars, Ofer's Backup Camera, and full Brembo brake conversion.
GearHeadPeter is offline   Reply With Quote
Old 04-18-2012, 11:07 PM   #7
Chavira2009
So what you're saying, You completely removed the Fieldgoal harness and modified the car's harness with diodes?
Old 06-26-2012, 12:21 PM   #8
Daily Driver
Daily Driver's Avatar
Drives: Silver Bullet
I am having a similar issue but mine has cause the headlights to go out! I have the Ofer non RS to RS wiring kit. I havent had much time to look at it but will play with it some hopefully next week.
Daily Driver is offline   Reply With Quote
aac, led, sidemarkers
