BeckyD @ James Martin Chevy
Old 04-18-2012, 10:28 AM   #1
Skogen
Hell Yea!
Skogen's Avatar
Drives: 1969 Chevelle SS & 2012 2SSRS M6
Dealer sticker How to remove?
Ok. Just picked up my new 2012 2SS/RS yesterday.
Dealer stuck this ass ugly sticker on the back.
What is the best way for me to remove this without making a mess.
Thanks
Brian
Life is like sex. If you are not having fun, you are doing it wrong!..
2012 Camaro 2SS/RS Crystal Red Tintcoat - AGP 54/57 Twin Turbo with Meth injection. 704 RWHP.
2015 Chevrolet 2500 LTZ
1969 Chevelle SS396 - Numbers matching
Skogen is offline   Reply With Quote
Old 04-18-2012, 10:42 AM   #2
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '17 Corvette Z51 Coupe
if its just a STICKER, then try to get it started using your fingernail, and warm it up using a blow dryer, just take your time. after you get it off, get yourself some GOO GONE or use Isoprople to remove the leftover residue.
if its one of those plastic badges, use either some dental floss or thin fishing line and work it in behind it and using a sissor action back and forth it will end up cutting the backing off. Then as before, either get some GOO GONE or some isoprople to remove the residue.
Old 04-18-2012, 11:00 AM   #3
OUR72GTO
2010 SIM Beige RS 6M
OUR72GTO's Avatar
Drives: SIM RS 6M 66 Corvair Silverado LTZ
^^^ as above.
CAMARO.. 2010 The Heart Beat is back in CHEVROLET
Now let's put it back in America
OUR72GTO is offline   Reply With Quote
Old 04-18-2012, 11:08 AM   #4
caramaro1969
caramaro1969's Avatar
Drives: 69,82,84 & 10 camaros,87 GMC,07z06
agreed...only way i know of
caramaro1969 is offline   Reply With Quote
Old 04-18-2012, 11:12 AM   #5
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
Nuke pretty much covered it.
If it is just a sticker and not a badge once you get that corner started be sure to pull the sticker at as shallow an angle, parallel to the panel, as you can manage. This will keep as much of the adhesive on the sticker backing and off of your paint as possible. Pulling at a 90* or steeper angle will break the adhesive loose from the sticker leaving it on your paint, which isn't the end of the world, but it is more work to remove.
To illustrate what I mean heres a quick drawing of the direction you want to work in:
Old 04-18-2012, 12:19 PM   #6
Skogen
Hell Yea!
Skogen's Avatar
Sweet.
Thanks!
Old 04-18-2012, 12:24 PM   #7
awfarley
awfarley's Avatar
Drives: 2011 5.7L Tundra Double-Cab X-SP
I removed mine while washing it one day. It took about 10 minutes. Basically did the pull technique above and they came off with no residue at all. I think it also depends on type/strength of vinyl used, luckily my dealer used some pretty easy stuff.
awfarley is offline   Reply With Quote
Old 04-19-2012, 10:15 AM   #8
Skogen
Hell Yea!
Skogen's Avatar
Did this last night. Worked like a charm.
Thanks!
Before
After
