Old 04-19-2012, 12:19 PM   #1
KMSRS2SS
I lurk
KMSRS2SS's Avatar
Drives: 2010 SS/RS
Output shaft snapped
It will be on the lift this afternoon to be checked out further, but it sheared. I'm hoping the trans is still fine and all I will need to do is upgrade to the DSS one piece. I'll know more later, any suggestions?
This happened first time at the track since upgrading the suspension and putting a ls9 clutch in and linelock. My guess is I finally got a really good burnout to warm up the D/R and the track was already pretty sticky so it hooked and the weak link was found, and quick.
460 at the wheel so far...
VMS Stage 2.5 Camshaft Kit- Comp cam LSA 114,227/239, .613 .623, RotoFab CAI, VMS ported intake manifold,Kooks 1 3/4" headers with HF cats, Corsa Catback, VMS custom dyno tune,TechAFX engine hose relocation kit, DSS 1400 hp axles, BMR toe rods and links, LS9 Clutch, Hurst short throw with roll out, Liberty Gear built tremec 6060.
KMSRS2SS is offline   Reply With Quote
Old 04-19-2012, 12:27 PM   #2
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
ouch sorry to hear that..one of many reasons i dont track my car or do burnouts
Sent from my SCH-I510 using Tapatalk 2
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 04-19-2012, 12:35 PM   #3
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Output shaft is part of your transmission, NOT part of your drive shaft. I'm sorry to say this is going to be very expensive.
SUX2BU is offline   Reply With Quote
Old 04-19-2012, 01:12 PM   #4
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
Shouldn't be if car is a 2010 under vin 25000. Known problem and GM never released vin #'s of cars with suspect transmission output shafts ( cause they really don't know ) other than cars with vins lower than 25000 MAY BE affected. There is a TSB on broken output shafts in 2010 SS cars, you need to inform your dealer about it.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers & rotors, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, ZL1 Brembo Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 wheels w/Vredestein 275/40/20 & 315/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat
flht99b is offline   Reply With Quote
Old 04-19-2012, 01:27 PM   #5
KMSRS2SS
I lurk
KMSRS2SS's Avatar
Drives: 2010 SS/RS
My vin is just above 30,000.
SUX,
Any experience with what the costs would run to rebuild the trans? I didn't think this fix was going to be cheap, just sucks it happened right after putting 5+ grand into the thing. What's that saying you gotta pay to play.
Old 04-19-2012, 01:46 PM   #6
blake-b
blake-b's Avatar
Drives: Black 2010
Tick Performance offers a rebuild service.
http://camaro5.com/forums/showthread.php?t=175394
http://www.tickperformance.com/2010-camaro-ss/
When my TR6060 dies, it is going to Tick for a level 3.
Old 04-19-2012, 02:20 PM   #7
flht99b
flht99b's Avatar
SUX,
If you are running stock axles and the trans output shaft broke before they did, that just doesn't seem right. Or maybe, like I said GM really doesn't know what cars received questionable output shafts and some are in cars with vin's greater than 25000.
Old 04-19-2012, 02:38 PM   #8
KMSRS2SS
I lurk
KMSRS2SS's Avatar
Drives: 2010 SS/RS
I've been looking at Liberty since they are local, I can save a few bucks by dropping it off and picking it up. I'm going to give them a call and see what's up. thanks for the replies so far!
Old 04-19-2012, 02:39 PM   #9
KMSRS2SS
I lurk
KMSRS2SS's Avatar
Drives: 2010 SS/RS
I haven't upgraded my sig, but i'm running DSS 1400hp axles, I figured I would replace those before the stock ones broke. I pretty much upgraded everything except the trans, and driveshaft at this point.
Old 04-19-2012, 02:51 PM   #10
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Ed M.
I'm always paranoid about seeing this number for this issue, since mine is 25261. Also, this was for production run 1, 125000
Smoked tail lights/ZL1-1LE 3rd brake
Rotofab cai
Old 04-19-2012, 03:03 PM   #11
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2010 2SS/RS/M6
hahaha, me too...mine was built the following week.
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 04-19-2012, 05:58 PM   #12
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
SUX,
I've rebuilt plenty of T56s but haven't torn into a tr6060 yet, but they shouldn't be much different. I'm guessing the output shaft might be $300 or so and since you have to take the COMPLETE thing apart to swap it out I would go ahead and upgrade the syncros.
Depending on how much your shop charges I would say as cheap as $600 or as much as $1000. Also that is if it was a clean break and didn't mess anything else up.
Old 04-19-2012, 07:29 PM   #13
DandD
DandD's Avatar
Drives: 2010 2SS and 2011 LS
It's sad stories like this one that make me glad I did my drivetrain before I started adding the horsepower. This past winter I added 1400 hp axles and 1 pc aluminum driveshaft from DSS along with a new clutch, Pfadt trailing arms and toe rods, and had Liberty rebuild my trans. Kevin, SUX2BU is correct it won't be cheap, Liberty will do a rebuild the same basic rebuild as the Tick level 3 for just under 2k. I had mine done as my vin# is 10320, but from your info above it sure sounds like the folks at GM haven't quite shared "all of the story" with us on the output shaft problem. I feel your pain Kevin, I ran out of coin before I could do anything with my differential so I'm hoping to get thru the year at 415rwhp so far so good best of 12.83, we'll see if it makes it to the end of the season.
Around here we like baseball, hot dogs, apple pie, and Chevrolet
DandD is offline   Reply With Quote
Old 04-20-2012, 04:21 AM   #14
Bonemaro
Bonemaro's Avatar
Drives: 2010 RJT 1SS M6
Send a message via AIM to Bonemaro
I'm with you Dan, but just 125 HP over stock shouldn't be breaking anything. This car mimmicks mine as far as the build goes. Just pisses me off to hear such sad news like this with just a fair amount of increase.
1400hp axles for 460 at the tire is a slap in the face. Or it could be the crown and butterscotch schnapps talking, but this rubs me the wrong way. I may be alone on this, but this is one cheaply/minimal made car for the american dollar inside and out.
signed-
still a fan
Bonemaro is offline   Reply With Quote
