Old 04-20-2012, 02:25 PM   #1
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2012 2LT RS
Anyone tried these Microfibers?
http://www.griotsgarage.com/product/...o?code=FROOGLE
When replying, notice the the purpose of the different towels as not to generalize the brand.
thanks
2012: e85, 80mm TBody, CAI w/scoop, Solo HFC, ZL1 FP, Magnaflow TruX, Dynomax VT, Elite catch can, HP Tune, Throttle Contoller, BMR; Springs, Sways, Trailing Arms, Toe Ends, & Safety Loop, Koni str.t, Pioneer Z150bh, Phoenix Gold Sub, Hertz speakers & 5ch Amp, 1LE rear with 3.91 gears, BMR bushings, Baer Decela Rotors, Goodridge brake lines, Brembo(GM) 4 piston calipers, Hawk Ceramic pads, ported intake, Circle D 5c. 12.3@112 old setup
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
IneedAZ is offline   Reply With Quote
Old 04-20-2012, 03:07 PM   #2
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Haven't tried those but they should be good. Griots generally has very good stuff.
Sent from my Galaxy Nexus using Tapatalk 2
[B]
Old 04-20-2012, 03:28 PM   #3
1954 Belair-man
1954 Belair-man's Avatar
Drives: 2010 Camaro IOM 1SS M6
I've never tried them either but its sounds like a fair price for all you get, i'll be waiting to hear from others who have used them also before i think about buying any
1954 Belair-man is offline   Reply With Quote
Old 04-20-2012, 03:37 PM   #4
Iomcamaro
The enjoyment never ends
Iomcamaro's Avatar
Drives: 2010 1LT/RS IOM #25223
The waffle weave is a good towel. I still find Adams to be the best because it absorbs more due to no dies. The wax and polish towels are my favorite. You can only use one side of them due to tags, but they are break off tags. Easily removed, but the nap is only good on one side IMO. The interior towels are just your basic OTC towels. They arent anything special. The waterless wash and speed wipe towels are very nice if you get some that don't lint. If yours lint, griots will replace them free of charge when they are new. I have a huge local griots dealer and use a lot of their stuff. Some of it is great such as their towels, but others they're are better. I find Adams to be higher quality. Griots is going OTC at advance autos now... But to answer our question, yes I'd buy those towels again. I plan to buy some more this next month actually for my business .
Iomcamaro is offline   Reply With Quote
Old 04-20-2012, 06:22 PM   #5
IneedAZ
IneedAZ's Avatar
thanks for the replies! Didnt know those towels are one sided.
Old 04-20-2012, 08:10 PM   #6
Angelo@Autopia
Angelo@Autopia's Avatar
Drives: 2014 Ford Focus ST
When comparing quality microfiber towels, here’s are some tips that one needs to know when it comes to these towels:
Towel density is very important for a towel. the density is a measure of fibers per square inch of fabric on a microfiber towel. The range for a good microfiber towel is from 95,000 to 250,000 fibers per square inch.
The ratio of polyester and the polyamide blend is very important. While 80% polyester and 20% polyamide is great for detailing, a 70/30 blend will absorb water faster and better. As polyamide is much more expensive than polyester, you can expect to pay more for a 70/30 blend.
Make sure you look at the weave and fabric thickness (plushness) of the towel. Depending on the specific task the cloth is designed to perform, the fiber ends may be hooked (for cleaning), feathered (for polishing and glass cleaning), or tufted (for drying). We all know the saying; it costs more to make quality! Microfiber is no different. Quality construction is not always obvious, here are some observations from folks out there. The biggest complaint with automotive microfiber is that towels with cheap edging will scratch your paint! There are two possible reasons. First, the cheap factory uses a hot wire system to cut their towels. If not properly adjusted, or if a cheap machine is used, the hot wire will melt the fabric. When polyester and nylon melt, they turn into hard plastic and will scratch the paint for sure! The second complaint is that the towel creates excessive lint. Microfiber lint is caused by towels with a high pile or a broad weave using a fiber split that’s inappropriate. The high pile or loose weave allow the fibers to break off, creating linting which some of us have seen. The same split fiber used in a towel with a higher fabric density will lint less or not at all. Always take care of your towels and wash them with a Microfiber soap to maintain them and keep them fresh and new. Remember when you get a new towel to do the CD trick and save you paint from scratches.
Old 04-20-2012, 08:21 PM   #7
IneedAZ
IneedAZ's Avatar
What is the cd trick?
Old 04-20-2012, 08:31 PM   #8
Angelo@Autopia
Try the Microfiber towel on a blank CD. try to scratched the CD by of cleaning the CD, if it scratches it then a 99.9 % chance it will do the same on your paint.
Old 04-20-2012, 08:32 PM   #9
2ss2012
Drives: 2012 2ss ahen grey
What are some of the best towels?
2ss2012 is offline   Reply With Quote
Old 04-20-2012, 08:33 PM   #10
IneedAZ
IneedAZ's Avatar
Ok, thanks
Whose towels do you use on your stuff for wax and polish removal?
Old 04-20-2012, 08:35 PM   #11
2ss2012
Adams single soft dont pass the cd test!
Old 04-20-2012, 08:35 PM   #12
Angelo@Autopia
I have many different ones from Autogeek, and PakShak. Also have some from the close CMA also.
Old 04-20-2012, 08:36 PM   #13
Angelo@Autopia
The ones that don't pass the test I use them for wheels, interior work and door and trunk jams.
Old 04-20-2012, 09:05 PM   #14
IneedAZ
IneedAZ's Avatar
Is what caught my eye with the griots is the fact they say for polish and the others say for wax removal where as i dont see that on other brands so i dont know what to buy.
