Gen5DIY
Old 04-20-2012, 09:53 PM   #1
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
Leaf blower idea
Alright, so a few weeks ago I asked how to get rid of and or prevent the water spots. I got a few helpful ideas, but one in particular just made it worst. Today was about 50 degrees with overcast. After washing the car, I used my new leaf blower. All this did was take a droplet of water and separted them into 20 tinier water droplets that dried much quicker. After I was done drying it off the best I could I had to grab some McGuiers Quick Detailer to get rid of these water spots.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, RX CC, GFX, Subs.
rberns is offline   Reply With Quote
Old 04-20-2012, 10:26 PM   #2
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
Smaller spots better than big spots and also better than scratches from towel dry! Keepma good layer of wax and those 20k small ones should not be to much of a worry.
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 04-20-2012, 10:47 PM   #3
patternpilot
patternpilot's Avatar
Drives: 2012 2SS/RS 05 Jag S type R
Just remember that any dust or dirt in the air will be propelled to 150mph when you use a leaf blower. Think what that does to your paint. Compressed air is much cleaner.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, No Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears.
patternpilot is offline   Reply With Quote
Old 04-20-2012, 11:09 PM   #4
2ss2012
Drives: 2012 2ss ahen grey
i use a master blaster
2ss2012 is offline   Reply With Quote
Old 04-20-2012, 11:10 PM   #5
my leaf blower works perfect every time, I would never dry any of my cars without it.
Old 04-21-2012, 01:33 AM   #6
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
You don't have a good coat of wax down it sounds like. Sounds like you also didn't do a sheeting rinse before.
Sent from my Galaxy Nexus using Tapatalk 2
[B]
Old 04-21-2012, 07:28 AM   #7
babaron
Totally into it
babaron's Avatar
Drives: '67 427vette/'11 Pacecar/'02 BMW ci
rberns, I think your problem occurs for 2 reasons. First, you have a dark color car which shows even the slightest discoloration. Secondly, I would be willing to bet you have hard water in your area.
Try this: After the rinse, sheet the water off quickly, then spray the whole car down with detail spray, again as quickly as you can. Finally, use an Adams Great White Drying Towel on the car.
Another more expensive solution would be to install a hard water filter in your garage. This would totally eliminate water spots.
As always, keep a good coat of sealant/wax on the car. This too will help.
Good luck and let us know what finally works for ya.
Ron
____________________________________THERE MUST BE A SUPPORT GROUP FOR THIS ADDICTION. AM I IN THE RIGHT PLACE?
babaron is offline   Reply With Quote
Old 04-21-2012, 08:08 AM   #8
rberns
rberns's Avatar
Just put paste wax on it 2 weeks ago. I believe we do have hard water. Oh well, back to the shammy for me.
Old 04-21-2012, 08:14 AM   #9
2011ss/rs
2011ss/rs's Avatar
Drives: 11 ss/rs RJT w/Black Cherry stripes
Send a message via AIM to 2011ss/rs
Go to Walmart in the RV section and pick up a water filter for RVs and hook it up to the facet and the hose it will help with the hard water spots. It will cost about $20.00.
2011ss/rs is offline   Reply With Quote
Old 04-21-2012, 11:15 AM   #10
Stex
Drives: 67 goat, 69 goat ram air III
http://www.adamspolishes.com/p-106-a...ing-towel.aspx
Stex is offline   Reply With Quote
Old 04-21-2012, 11:56 AM   #11
Iwantone2
Voice Of The Voiceless
Iwantone2's Avatar
Drives: CGM 1SS RS
OP: if you sheet the water before using the leafblower, it will work that much better. And what I usually do is use the Quick Detail spray to aid in drying.
Old 04-21-2012, 11:58 AM   #12
midnighter
Drives: nothing
I use my air hose from my air compressor. It works great but I have to let it build up pressure if I hold it open too long non stop.
Old 04-21-2012, 07:51 PM   #13
redirish
redirish's Avatar
Drives: 10' IOM 2SS/RS/M6
I use distilled water to sheet before using the leaf blower. I Never have water spots and the water in NJ is very hard.
redirish is offline   Reply With Quote
Old 04-22-2012, 02:41 PM   #14
warren3537
warren3537's Avatar
Drives: 2017 Red Hot 1SS
I picked up a 30 dollar 2 speed leaf blower at wally world, but after using ArmorAll Extreme Shield Wax, the water just jumps off the car.
warren3537 is offline   Reply With Quote
