Old 04-21-2012, 10:08 AM   #1
Mr. Texas
Mr. Texas's Avatar
Drives: 2016 Mosiac Black 2SS A8
Clunking Noise in Rear Only When Stopping
I searched countless threads to see if anyone else had this same issue, but I couldn't come up with anything.
I installed BMR 1" drop springs and trailing arms. I took the car to have the bushings timed and an alignment done yesterday. The car rides great and makes zero noise while driving over bumps, turning, etc. The problem is when I come to a quick stop the car makes a small clunk noise. It seems to do it has the weight settles back on the rear after it is transferred to the front from the quick stop. Everything is tight underneath the car. Is this normal?
Mr. Texas is offline   Reply With Quote
Old 04-21-2012, 10:13 AM   #2
MPG1959
Drives: 2012 45th SS
Mine does the same thing with a full tank of gas. I think the gas is just sloshing back and forth making the clunking sound when coming to a stop.
MPG1959 is offline   Reply With Quote
Old 04-21-2012, 11:52 AM   #3
11SynergyGr&Bl
JZ
11SynergyGr&Bl's Avatar
Drives: 2011 Synergy Green Camaro
It's probably the gas in the tank. Is it coming from one side or the other? other thing you might want to check is if the spring is seated correctly. i wouldn't think it could be, but a way to check is lift the car up so the rear is off the ground. You can leave the wheel on, or off. Off would give you more eye'n room tho. Check the spring, and seats of the spring, also does the spring have up and down movement play at all?
*2011 SGM Camaro*
Hi/low 8k HID kit, Injen WB long tube, Pfadt stage 2, Rx black ice-olator, Rx catch can (color matched =D).
11SynergyGr&Bl is offline   Reply With Quote
Old 04-21-2012, 05:18 PM   #4
Parag
Drives: 2010 camaro 2SS LS3
sway bar could be binding.
stage III cam, 4.10's, custom CAI, suede headliner
461 RWHP, 422 RWTQ
Parag is offline   Reply With Quote
Old 04-21-2012, 06:24 PM   #5
JohnZ
JohnZ's Avatar
Drives: 2010 Camaro 2LT V6
What would you do if the sway bar was binding? I might have the same issue.
Injen CAI, V-Max Throttle Body, Rx 25mm Iceolator, Rx 10mm Plenum Spacer, Mace Ported Manifold, ARK N-II Catback, Trifecta Tune, Rx Catch Can.
BMR Bushing Inserts,Pedders Radius Rod Inserts, Pfadt Sway Bars and Endlinks, LSR Front Subframe Brace
SS Brembo Brakes, Racing Brake Stainless Lines
JohnZ is offline   Reply With Quote
Old 04-21-2012, 07:02 PM   #6
Parag
ive only seen that with improperly installed mounts. its pretty obvious under the car if the sway is binding.
461 RWHP, 422 RWTQ
Old 04-21-2012, 07:11 PM   #7
JohnZ
JohnZ's Avatar
this might be a dumb question, but what exactly happens when the sway bar "binds"?
Old 04-21-2012, 07:16 PM   #8
Parag
it clunks and makes noise.
depends on how bad the problem is. if it is way off or bent, the car will sit crooked.
its really rare.
if you have aftermarket sways, just check with the brand to see what mounts are required.
other than that look into see if you need additional sub-frame bracing.
461 RWHP, 422 RWTQ
Old 04-22-2012, 11:29 AM   #9
Mr. Texas
Mr. Texas's Avatar
I put the rear end up on ramps and broke the end links loose. I shook the heck out of the sway bar and retightened everything. That solved the problem!
Old 04-22-2012, 01:52 PM   #10
mntgome1
mntgome1's Avatar
Drives: 2012 AGM 2SS/RS
I have read a thread about a clunking noise coming from the rear passenger side of the vehicle during deceleration. It was reported as normal and had something to do with the fuel system.
mntgome1 is offline   Reply With Quote
