HeadlightArmor
Old 04-21-2012, 06:08 PM   #1
Parag
Drives: 2010 camaro 2SS LS3
master cylinder function
im doing some things that are too much to explain here, but i just need to know more about it.
There are two lines coming from the master cylinder(front and rear) then they go to the abs controller to split off to four.
If the front brake line before the abs controller got pinched off, completely blocked, would the pedal be rock solid? or would it feel fine and still work the rear?
stage III cam, 4.10's, custom CAI, suede headliner
461 RWHP, 422 RWTQ
Parag is offline   Reply With Quote
Old 04-21-2012, 06:39 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
I'm guessing you have an LS3, that's the only way you would have 2 lines coming from the master cylinder. That I know of at least.
The pedal would probably work fine, maybe a little harder to push, as the fluid is still traveling to the rears.
Click to view my build thread
Old 04-21-2012, 06:45 PM   #3
Parag
yes i do have an ls3, why is there more lines on the l99's?
461 RWHP, 422 RWTQ
