Gen5DIY
Old 04-22-2012, 12:07 AM   #1
MJ
MJ's Avatar
Drives: 2010 Camaro SS/RS
Vibration after twin disc clutch install...
Just installed twin disc clutch and flywheel. Now have vibration... most noticeable at 50 mph. If clutch is disengaged while driving, vibration goes away. Am thinking vibration is related to flywheel balance. I was told that it could be one of two things:
1) The stock flywheel may not be zero-balanced... and by replacing it with balanced flywheel, a vibration would result. Would first need machine shop to check if stock flywheel is not zero-balanced. To fix, the new flywheel would need to be sent to machine shop to have it mimic the balance of the stock flywheel.
2) New flywheel and/or clutch assembly is out of balance. Need to replace with a good (balanced) unit.
Are there any other reasons for vibration? What's the likelihood of having stock flywheel not being zero balanced?
MJ is offline   Reply With Quote
Old 04-22-2012, 12:43 AM   #2
pyr0b0y
need....more....hp
pyr0b0y's Avatar
Drives: The Neighbor Hater
If you swapped the clutch but not the flywheel you might need to get the flywheel resurfaced.
just out of curiosity why did you keep the stock flywheel?
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims
pyr0b0y is offline   Reply With Quote
Old 04-22-2012, 01:43 AM   #3
dragon22
dragon22's Avatar
Drives: 2010 Camaro 2SS/RS SIM
Sounds to me like he replaced the stock flywheel and is concerned that the new flywheel is not balanced the same as the old flywheel.
2010 2SS/RS - 6M Silver Ice Metallic
ARH LT Headers with MBRP 3" catback exhaust, Cold Air Inductions CAI, ZL1 inspired splitter, ZL1 Grille, Rear Fascia blackout, Gill decals, Aftermarket Hurst Short Throw shifter, Tune by Jannetty Racing.
dragon22 is offline   Reply With Quote
Old 04-22-2012, 06:21 AM   #4
tkrupinski
Hugger Orange
tkrupinski's Avatar
Drives: 2010 Hugger Orange 2SS/ RS YSI/4l80
Who did you buy the clutch from? Most twin disc clutches come marked by the manufacturer, did you line the paint pen lines up on the pressure plate and flywheel when you installed it? If not it could cause some vibration.
tkrupinski is offline   Reply With Quote
Old 04-22-2012, 08:46 AM   #5
MJ
MJ's Avatar
I'll check for the markings when it's taken apart.
Old 04-23-2012, 01:49 PM   #6
MJ
MJ's Avatar
Update: Markings were lined up and stock flywheel confirmed zero-balanced. Working on another solution...
