sjm autoprod
Old 04-22-2012, 01:11 AM   #1
Redman6.2
Drives: 2012 SS 45th
clutch burn on launch control??
i tried my launch control the other day and it burned or at least sure smelled like it burned the hell out of the clutch, i let it out fast but did not pop it by any means. the car has 1200 miles on it, the clutch should be broke in right? is this normal?
Redman6.2 is offline   Reply With Quote
Old 04-22-2012, 02:46 AM   #2
dragon22
dragon22's Avatar
Drives: 2010 Camaro 2SS/RS SIM
This is not normal, but yes, this is a problem on these cars. It has been noted throughout the forums. GM claims we are not lifting off the clutch fast enough. If you go through the TSB section here, you will find some information.
Somewhere on here, someone is putting out a larger bore master cylinder, I believe, which seems to be helping with the pedal not coming up all the way. (That is why the clutch is burning). It happens under spirited driving.
Hope this helps and welcome to the forums!
2010 2SS/RS - 6M Silver Ice Metallic
ARH LT Headers with MBRP 3" catback exhaust, Cold Air Inductions CAI, ZL1 inspired splitter, ZL1 Grille, Rear Fascia blackout, Gill decals, Aftermarket Hurst Short Throw shifter, Tune by Jannetty Racing.
dragon22 is offline   Reply With Quote
Old 04-23-2012, 12:34 AM   #3
Redman6.2
thanks and i'm sure it will
