Old 04-22-2012, 10:22 AM   #1
lsuguy
lsuguy's Avatar
Drives: 2011 2SS/RS
Mirror Tap for Radar Detector Help
Can anyone clarify which color wires to tie into on a 2011? I tried using the colors explained in this DIY
http://www.camaro5.com/forums/showth...ight=Valentine
But using those colors won't turn the detector on. I found a switched power and a ground but it turns the detector off when I go in reverse and is overall acting weird.
Thanks for any help you can provide!
lsuguy is offline   Reply With Quote
Old 04-22-2012, 03:56 PM   #2
Camaroshark
Drives: 2010 Camaro 2SS/RS RJT, 6speed
Timely post! I referenced it and installed the blend mount and mirror tap this morning !
2010 Camaro 2SS/RS, LS3 - 6 speed. Mods, Magnaflow exhaust with resonator delete. ******** 12" stealth box subwoofer kit, Kicker 400 mono amp, JL XD 400/4 amp.
Camaroshark is offline   Reply With Quote
Old 04-22-2012, 05:11 PM   #3
The Stig
knows 2 facts about ducks
The Stig's Avatar
Red wire inserted into back of bracket into existing red wire slot next to Green wire, it's hard to see but there are two red wires in this slot.
Click to view my build thread
Old 04-22-2012, 09:38 PM   #4
lsuguy
lsuguy's Avatar
Drives: 2011 2SS/RS
Something is screwy then because when I use those colors I get nothing. The red wire does read 12v when I ground to the chassis but not getting a ground on the wire the DIY references....
Old 04-22-2012, 10:07 PM   #5
The Stig
The Stig's Avatar
then just ground to the chasis. That's what I did when I installed mine.
Old 04-22-2012, 11:35 PM   #6
Camaroshark
First time I did it I got nothing too. Had to make sure I pushed in far enough to make contact. As soon as I dId I got power! Zip tied it and boom.
Old 04-23-2012, 08:02 AM   #7
The Stig
The Stig's Avatar
I've had that problem before. I just solder everything now. Takes about the same time and I know it's a solid connection.
