sjm autoprod
Old 04-22-2012, 10:32 AM   #1
MustangKiller
MustangKiller's Avatar
Drives: 2013 2ss/rs A6 yellow !!!!!
lol 1 axle wow GM........lol fml
So i was looking over my new baby today and noticed the larger axle on the right rear. So my question is can i do what gm failed too do and order the larger GM axle and put it on the driver side is this possible or are the axles different for each side?
MustangKiller is offline   Reply With Quote
Old 04-22-2012, 11:33 AM   #2
RxDoc08
Jason
RxDoc08's Avatar
Drives: 2011 2SS/RS M6
The axles are different for each side. One is larger than the other because this is GM's way to combat wheel hop. As far as I know the only way you are going to get axles that are the same size on each side is to get a set of aftermarket axles like The Driveshaft Shop Level 5 axles.
RxDoc08 is offline   Reply With Quote
Old 04-22-2012, 11:49 AM   #3
MustangKiller
Wheel hop? I believe it was too fix the breaking passenger side axle. If it was too fix wheel hop it shure didnt work. I just took mine too the track @ 1,500 miles and ran the tires off it. I ran the car 7 times and it never seemed like the launch countrol even tried it just instantly broke loose and strait in too wheel hop and i had to let off and get back on it. My 60 ft times sucked.
Old 04-22-2012, 01:16 PM   #4
Parapdrapa
Drives: 2010 Camaro
Get 2 equal axles and tell me how much worse it is... Lol
Any IRS setup will have wheel hop especially with a manual and a less experienced person driving. When with full rear end and suspension upgrades you can still have wheel hop. You need to upgrade and learn to drive it to reduce and possssssssssibly eliminate it.
Parapdrapa is offline   Reply With Quote
Old 04-22-2012, 01:21 PM   #5
RxDoc08
Jason
RxDoc08's Avatar
I'm not by any means saying that the axle design works 100%, but that is the reason for having one axle thicker than the other. Also, just about anyone you talk to about launch control on the SS Camaro will tell you not to use it because you can get a much better launch without it and it can break driveline parts.
Old 04-22-2012, 03:35 PM   #6
MustangKiller
Im just sayin ..... Thats like one hid headlight and a regular on the other side but anyway im gonna launch it manually next fri night
Old 04-22-2012, 04:22 PM   #7
jeremywilson18
jeremywilson18's Avatar
Drives: 2011 Inferno Orange 2SS RS(LSX 454)
Send a message via MSN to jeremywilson18
They are supposed to be different sizes and that's the way the DDS makes them as well so don't panic
jeremywilson18 is offline   Reply With Quote
Old 04-22-2012, 05:14 PM   #8
MustangKiller
Dont care what the reason and im not panicing is it just makes no sense unless the idea is that the smaller one will fail over every other drive line part
Old 04-22-2012, 05:36 PM   #9
UCI CamaroFan
Zot!
UCI CamaroFan's Avatar
Drives: Toyota 4Runner
As others have said, that is by design to help reduce wheel hop.
UCI CamaroFan is offline   Reply With Quote
Old 04-22-2012, 05:38 PM   #10
MustangKiller
Ok...
Old 04-22-2012, 05:39 PM   #11
Rhyder
Drives: 2012 45 Anniversary Vert
He told you here why it is and what you can do to even them out if you want to, even the specific axles to get. Im guessing though, that by doing that you will have, potentially, wheel hop issues.
Rhyder is offline   Reply With Quote
Old 04-22-2012, 05:46 PM   #12
MustangKiller
I have horrific wheel hop now the launch control is useless thats the only thing i miss about my 2010 lc worked every time perfect
Old 04-22-2012, 05:48 PM   #13
MustangKiller
Thats ok ill call a friend in drivetrain in the am an ask why
Old 04-22-2012, 05:49 PM   #14
jeremywilson18
Um no it isn't supposed to break. I'm not positive on the actual technology but since they are different sizes they twist a bit different and that should lessen wheel hop. It isn't perfect and there are other things to help with wheel hop but it is one technique. This idea is good independent rear end technology
