Emblempros
Old 04-22-2012, 11:09 AM   #1
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
How to eliminate door rattle/buzz from bass?
After nearly 3 years if daily driving with the stock Boston Acoustics system blaring, I'm starting to get excessive (and very annoying!) buzzing in my interior from bass at just normal volume levels. I don't even have the bass levels that high (9 on a scale of 0-12)! It's to the point where I can barely enjoy listening to tunes anymore. Does anyone know of any solutions to this issue that won't break the bank? Thanks.
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged LS3 (9.8:1 CR), Maggie TVS 2300 SC (11 psi), Custom Comp cam (223/244, .610/.596, 114 LSA), 90-lb. injectors, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Lashway Motorsports.
fldrummer is offline   Reply With Quote
Old 04-22-2012, 12:08 PM   #2
gotroost
gotroost's Avatar
Drives: IOM 2SS RS
********? I have the Stealth enclosure kit and love it. Bass on the head unit is set to zero and it still thumps.
Mods: JRE 470 cam kit, Dynatech long tubes/hi-flo cats, SLP underdrive pulley, CAI intake/ADM scoop, Pfadt Stage 2 suspension, Hotchkiss strut tower brace, Proven Wicked tow hook and end links, DBA rotors, Melling oil pump, Katech timing chain/LS2 damper, some bloody knuckles, still in progress...
gotroost is offline   Reply With Quote
Old 04-22-2012, 12:16 PM   #3
The_cartoonist_88
Turbine Cowboy
The_cartoonist_88's Avatar
Drives: 2010 Yellow 2LT Camaro
Sound deadening, Its most likely buzzed and rattled from day one you are probably now becoming more tuned into it.
2010 YELLOW 2LT
The_cartoonist_88 is offline   Reply With Quote
Old 04-22-2012, 12:30 PM   #4
nebchevy
nebchevy's Avatar
Drives: 2011 2SS SGM Camaro
Are you talking about just the doors making a rattle or the whole inside?
nebchevy is offline   Reply With Quote
Old 04-22-2012, 12:47 PM   #5
PonyKiller74
PonyKiller74's Avatar
Drives: 2012 Triple Black ZL1 M6
Send a message via AIM to PonyKiller74 Send a message via Yahoo to PonyKiller74
Have an installation shop remove the door panels to see if anything came loose or undone and get some Dyna-Mat and layer your doors with it. Works great for any system I've installed.
CenterForce DYAD Dual Disc Clutch, JDP stage 2 Clutch Reservoir, Rotofab CF CAI with Big Gulp and WW Reservoir Relocate, Stainess Works LT Headers and Retro Cat-Back with Cat Delete, MGW ST Shifter with custom Knob, CF Tail light Bezels, more to come...
Build Thread for my Z is in the works.....
PonyKiller74 is offline   Reply With Quote
Old 04-22-2012, 01:39 PM   #6
nebchevy
nebchevy's Avatar
Remove the door yourself its HELLA Easy and then yet use some dyna mat
Old 04-22-2012, 02:31 PM   #7
Im_Fly_Like_A_V6
Im_Fly_Like_A_V6's Avatar
Drives: 2012 SIM 2SS/RS L99
Its weird cuz in my 11 lt i had a BA system and didnt notice any door ratel and now on my 12 ss with BA the plastic on the door rattels all the freaking time its annoying... So u guys think dyna mat will take care of it? Even though it sounds like its the plastic on the panels
Im_Fly_Like_A_V6 is offline   Reply With Quote
Old 04-22-2012, 02:42 PM   #8
camarograna2
Car Enthusiast
camarograna2's Avatar
Drives: 2010 Rally Yellow Camaro 2SS A/T
Send a message via MSN to camarograna2
Prolly also add foam pad where you suspect that plastic is rattling
2010 Rally Yellow 2SS/RS
Performance Upgrades: Custom Flowmaster X system Exhaust Audio Upgrades: Too much to write down. Visit http://www.camaro5.com/forums/showthread.php?t=206016
camarograna2 is offline   Reply With Quote
Old 04-22-2012, 11:02 PM   #9
fldrummer
"Black Ace"
fldrummer's Avatar
The plastic pieces are definitely part of the problem 'cuz if I press my elbow against it hard enough, the buzzing is reduced. 'Hard to pinpoint what else might be buzzing...
