Flowmaster Exhaust
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 04-22-2012, 08:14 PM   #1
Pgoldston
Drives: 1999 camaro
Smallest wheel that will fit on the rear
Whats the smallest diameter rim that will fit on the back of the ZL1?
You can lead a horse to water but you cant force people to look at the data
Pgoldston is offline   Reply With Quote
Old 04-23-2012, 02:45 AM   #2
Pappa Joe
Pappa Joe's Avatar
Drives: Charger/TL1000R/Cobalt/ZL1
I think you meant ,Whats the widest tire I can get on the ZL1!
Pappa Joe is offline   Reply With Quote
Old 04-23-2012, 05:37 AM   #3
Truck Norris
Thread Mover
Truck Norris's Avatar
Drives: a Monte Carlo
^^^ Nahh more like if it can fit 15-17" rims out back to save $$$ like he can do to his 4th gen and GT500's
If 5th gen SS rims will fit out back then the 18" C6 Z06 rims should fit and are the smallest cheapest setup for hitting the strip without changing to a smaller rear brake set up.
In the market for something fast
Truck Norris is offline   Reply With Quote
Old 04-23-2012, 12:35 PM   #4
Pgoldston
Drives: 1999 camaro
Just trying to get the smallest diameter wheel for slicks so there is more side wall to absorb the shock of the driveline. Was hoping 17s but guess its 18s. Will have to look into whats out there. Thanks
Old 04-23-2012, 03:17 PM   #5
HumanWiki
Drives: Car
Wider isn't always better.. Any more width than 100% required is just wasted weight and rolling resistance. You want enough side wall to allow for flex and some shock absorption and just enough tread to hook and go.
HumanWiki is offline   Reply With Quote
Old 04-23-2012, 04:30 PM   #6
grocerygetter
instigator
grocerygetter's Avatar
rear brakes on a ZL1 are same as SS. Fronts are where the difference is. If that's the case, you can get a Bogart 17.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 04-23-2012, 05:06 PM   #7
94turbolsx
Drives: 2000 Camaro SS
If you dont mind spending some money, 17's will fit. Bogart, CCW ect. Cheap way out your stuck with 18's like Z06 replica's ect.
94turbolsx is offline   Reply With Quote
Old 04-23-2012, 06:07 PM   #8
Pgoldston
Drives: 1999 camaro
What makes the bogarts and CCW so specail yet other 17's cant fit? If someone has some number I may actually have a cheap alternative that is lighter than the stockers. I just need some numbers on the wheels and check it out.
