JDP Motorsports
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Suspension / Chassis / Brakes
Old 04-23-2012, 01:11 PM   #1
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2010 X5 Camaro Turbo
BREMBO 6 POT Front Brake Upgrade PLUS Rear Sport Rotors :: 2010-2012 @ Phastek
BREMBOŽ 6 Piston (380x34mm) Front Brake Upgrade PLUS Rear Sport Rotors :: 2010-2012 Camaro SS
Upgrade your 2010-2012 Camaro SS brakes with this new front / rear package that combines Brembo's 6 piston monoblock Gran Turismo front calipers with slotted or cross-drilled 380 mm x 34 mm two-piece rotors, pads & stainless steel brake lines, PLUS a set of matching rear Sport rotors.
Package Includes:
Brembo 6-Piston Gran Turismo Monoblock Front Brake Upgrade (380x34mm)
Slotted or Cross-Drilled Two-Piece Front Rotors
Front Stainless Steel Brake Lines
Front Pads
Matching (Slotted or Cross-Drilled) Rear Sport Rotors (Factory Size)
Ultra High Performance Brembo Brake System packages were developed to offer race-inspired braking components that are endowed with several significant advantages over a vehicle’s original braking system to provide superior braking time after time. They are for drivers who want to make a statement by substantially improving the looks and performance of their vehicle’s braking system.
While they are available for sports cars, sporty coupes, sedans, light trucks and SUVs, in most cases the Gran Turismo Brake System’s massive aluminum calipers and large diameter brake discs require the use of aftermarket wheels with the necessary brake clearance.
Brembo Gran Turismo Systems provide excellent stopping power in everyday traffic, as well as superior high performance street and track driving. They are designed to bolt onto the vehicle’s original suspension and are fully compatible with the vehicle’s stock brake master cylinder and anti-lock braking system (ABS).
While most Brembo Brake System packages have been developed specifically to replace the vehicle’s front brakes (due to the high braking demands encountered there), rear brake systems are also offered for selected applications.
Ultra High Performance Brembo Brake System packages combine high performance fixed aluminum brake calipers, large diameter 1- or 2-piece vented brake rotors, brake pads, stainless steel braided brake lines and aircraft quality mounting brackets and hardware. (See photo and chart below.) Brake caliper and rotor sizes are selected based on the vehicle’s requirements. In most cases, the aluminum calipers are available in red, silver or black finishes. Additionally, the rotors feature drilled or slotted disc surfaces depending on the vehicle application and brake system selected. All cross-drilled holes are bi-angle chamfered at the rotor’s outer surfaces to help reduce the cracking caused by repeated, high stress, high temperature brake applications. The brake discs are coated for corrosion resistance to help eliminate rust and to offer a bold, aggressive appearance to enhance the look of the vehicle’s road wheels.
Pricing and Technical Info: Available online at www.PhastekPerformance.com!
Sales@Phastek is offline   Reply With Quote
Old 04-25-2012, 10:38 AM   #2
Sales@Phastek
Place your orders
Old 05-01-2012, 04:38 PM   #3
Sales@Phastek
Place your orders
Old 05-08-2012, 12:11 PM   #4
Sales@Phastek
Taking orders
Old 05-16-2012, 11:03 AM   #5
Sales@Phastek
thanks for your orders!
Old 05-31-2012, 11:01 AM   #6
Sales@Phastek
post or pm if you have questions
Old 06-12-2012, 01:36 PM   #7
Sales@Phastek
post or pm with questions
Old 06-18-2012, 03:43 PM   #8
Sales@Phastek
HI !
Old 06-26-2012, 05:20 PM   #9
Sales@Phastek
taking orders
Old 07-10-2012, 11:09 AM   #10
Sales@Phastek
Place your orders
