Gen5DIY
Old 04-23-2012, 02:18 PM   #1
fargomike
The Dude Abides
fargomike's Avatar
Drives: Black 2SS M6
An eventful Hurst Install
Well to say it was eventful would have been an understatement ! I installed my Hurst shifter this past weekend and it was quite the install . First let me say this was my first time using floor jacks as most work I have done in past has been with ramps or lift with that said I am starting P90X this week ! Getting the OEM knob off was much easier than expected I did lean to one side as to not smack myself in the face . So I get under the car take a look around and see that it is a tight space to work in but manageable . I took the boot off and then tried putting it back on again since I read here most say the boot is a PIA . Was not too bad actually considering what was ahead of me . Used a long needle nose and got the 2 clips off not much of a problem there . Got the pin out and the screws off the old shifter and yanked the old one out . Get the hurst shoved up in there and this is where it got comical , first screw goes up and sh#t if it did not fall behind the heatsheild , reach back in it and oh guess what there are some sharp edges in there , find the screw thankfully it was near the front wedged in . So I get one in , second one going in and sh#t if this one did not go behind the sheild , wayyy back . By this time I was somewhat should you say upset . Got my magnet out and fished it out . The "passenger side" was hard to get to . At the same time the damn boot was flopping and getting in the way . Cant they just design it with a PLATE or something ? Finally get it in , put a strip of the dynamat on the clips get boot on . So I am thinking hey hard parts over right , well I would say it was but getting the rubber grommet on the lower shifter part was hard as hell , blows the boot away for getting something on . Took it and got on the chrome stick , slid it back off and finally got it on . Slapped the neoprene in between got everything else done . Man that looks tough . Took it for a ride nice shifting , clicks right into gear . Got a vibration at about 3k rpms so I will get back under and apply some more dynamat maybe but vibration does not really bother me , seems old school kind of . All in all I am very happy with it compared to OEM . Oh and btw I did not lower the Tranny brace was not much of an issue but I bet it would have kept boot out of the way ?
2010 Black 2SS/LS3/M6 Kooks 1 7/8 Ceramic Coated Headers, Borla ATAK CB , JRE Tune , Halltech Yellow Jacket CAI ,VMax Ported TB, PFADT Coilovers,Forgestar CF5's Textured Gunmetal w/Nitto Invo's 275/315 ,Hurst Billet Plus 2 Shifter AAC P13W Plasma LEDw/DRL Harness ,30% Tinting,
fargomike is offline   Reply With Quote
Old 04-23-2012, 03:33 PM   #2
ctk1
Camarofanatic
Drives: 1969 SS, 1998 RS, 2010 VR 2SS/RS
I put mine in a few weeks ago. While not as troublesome as your experience I did manage to send one of the "irreplaceable" clips flying up under the heat shield. I just unbolted it and thankfully it fell right out.
I like it and it is definitely alot firmer and mechanical feeling. I also installed the Dynamat where it said to. I kind of wrapped it around the bottom, around both clips, which also covered the pin. My shifter seems to have a little drag or take a little effort putting into gear. Is yours like that or do you think that my Dynamat placement may be causing some trouble?
2010 Victory Red R6P 2SS w/RS package. Gloss black Rallys, 6 speed manual, SLP Loudmouth I exhaust, LS7 style blackout panel, SS emblems front and rear, Custom 69 inspired headlight covers, Vararam no tune, Hurst Short Throw, and MTI Racing rear spoiler, SLP Front Splitter, ZL1 Side Skirts
ctk1 is offline   Reply With Quote
Old 04-23-2012, 04:55 PM   #3
fargomike
The Dude Abides
fargomike's Avatar
Mine is the same , with the short throw there will be more effort . Dynamat should not effect it at all . Did yours also have the wrong wrench size for the ball ? Mine was actually metric and the instructions stated 9/16" .
Old 04-23-2012, 09:07 PM   #4
ctk1
Camarofanatic
Thanks, I've been a little paranoid about the Dynamat but I'm glad to hear mine is ok. My directions listed the correct wrench size in the directions. I don't have them handy but I think it was 10 or 12mm.
