Old 04-23-2012, 03:03 PM   #1
Protomanx8
Drives: 2010 Camaro SS A6 ABM
Oil pan leaking
Have my car in the shop getting work done and my gasket is leaking. I only have 40k miles on the car. I don't think it should be leaking already . Any one else have this ? Also should warranty cover it ?
Protomanx8 is offline   Reply With Quote
Old 04-23-2012, 03:14 PM   #2
need4spd
need4spd's Avatar
Drives: 2012 2SS Black on Black
I had mine leaking at 500 miles
previous ride - 2010 CGM 2LT RS auto w/roof, eibach lowering springs, volante cai, mrt v2 axle back
current ride - 2012 Black on Black 2SS RS w/ sunroof, muffler delete with SLP exhaust tips, rotofab cai, gm strut brace, BMR 1.4 drop springs all four corners, Stainless Power 1 7/8 long tubes, Hex Vents, Jannetty Racing Tune, Helmholtz J pipe, MMR 228 Z28 replica wheels.
need4spd is offline   Reply With Quote
Old 04-23-2012, 03:14 PM   #3
fast34me
Drives: 2010 CGM 2SS/RS
Are you sure it's the pan, and not porosity of the block? Some of the blocks were defective and leaked oil through the block.
fast34me is offline   Reply With Quote
Old 04-23-2012, 03:30 PM   #4
avt12882
Drives: 2010 camaro ss1 inferno orange
yes I have a 2010 SS 1 Vin#4583 with 5100 miles and I just dropped mine of this morning for the same problem. The mechanic that's fixing the car told me that this is the 5th SS he's fixed because of the rear main seal so your not alone.
avt12882 is offline   Reply With Quote
Old 04-23-2012, 03:32 PM   #5
jd10013
Drives: 2012 camaro
I believe that was a problem in the head, not the block. anyway, did you maybe run over something and bump the pan?
jd10013 is offline   Reply With Quote
Old 04-23-2012, 03:53 PM   #6
fast34me
Condition
Some customers may comment on an engine oil leak.
Cause
Upon initial diagnosis, it may be determined that the leak is coming from the rear cover gasket. This condition may be caused by engine block porosity on the sealing surface. This issue pertains to aluminum block applications only.
Correction
Follow the steps for Oil Leak Diagnosis in SI to determine the source of the leak. If the leak has been diagnosed as coming from the engine rear cover assembly, refer to Engine Rear Cover Replacement in SI and remove the engine rear cover assembly. Inspect the engine block and engine rear cover for porosity on the mating surfaces.
• If porosity is found on the engine rear cover (see illustration below), replace the engine rear cover assembly, GM P/N 12633579.
• If porosity is found on the engine block, use the following procedure to apply RTV to repair the engine block porosity.
The porosity issue is in the gasket sealing surface at the top of the cover, near the high pressure oil crossover port. Refer to the picture below. The oil leaks by the gasket and runs down the side of the cover, and may appear to be a leak at the t-joint area of the cover. The fix is to replace the cover with GM P/N 12633579. Also, if porosity is found anywhere on the sealing surface of the engine block, use the following procedure to apply RTV to repair the engine block porosity. Refer to the illustration below.
Rear main seals are known issues.
Oil Pan leaks are known issues too.
Old 04-23-2012, 06:42 PM   #7
Slowmaro95
Chitown Hustler
Slowmaro95's Avatar
Drives: 2010 IOM Camaro 2SS
Yeah, I've been having this issue on mine w/ under 30,000mi. Looks like the rear main area. Had a few other things replaced under warranty oil related, all covered. These engines are turds, gonna ditch mine after the loan is paid off. My LS1 in my '01 SS was friggin bulletproof, never leaked. Although I broke my theory of waiting 3 years to buy a redesigned/new car with my '10. Bugs prolly aren't worked out across the board yet.
Slowmaro95 is offline   Reply With Quote
Old 04-23-2012, 07:02 PM   #8
BlemsBumble
BlemsBumble's Avatar
Drives: '13 ZL1 #662; '10 SS; '99 SS
It's a pisser when these things occur, but they can be repaired. I've had the oil pan, rear main and oil cooler all leaking within the first 5000 miles. Have had no furthur problem following repair.
BlemsBumble is offline   Reply With Quote
Old 04-24-2012, 09:19 PM   #9
Slowmaro95
Chitown Hustler
Slowmaro95's Avatar
I'm knocking on wood right now. Yeah, it definitely gives you an uneasy feeling in the pit of yer gut when you spend all that money on a new/gently used vehicle and the initial quality is crap. Would be curious if recalls would be drawn up if there were enough occurrences like these.
Old 04-24-2012, 09:25 PM   #10
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
i have changed a few of these pan gaskets for people,, looks like gm changed the design of the gasket, the ones i took out were grey in color and the rubber was very spongy, the new gm gasket is black and the rubber is very firm, i have been using a bead of anarobic sealer on the metal portion of the gasket, top and bottom and all have been dry for months now,
Old 04-25-2012, 09:53 AM   #11
Hannibal
Hannibal's Avatar
Drives: Camaro SS & ZL1
I've had the oil cooler on mine leak. It was fixed and no additional problems have come up. Mine had about 10k on it when I noticed the oil cooler drip.
Hannibal is offline   Reply With Quote
Old 04-25-2012, 10:31 AM   #12
ITGuy11
Burning up tires
ITGuy11's Avatar
Drives: 2010 Camaro 1SS/RS
I had both my oil pan and cooler gaskets replaced at 3,000 miles due to leaking...
Blower, cam, supporting mods 644RWHP 615RWTQ
My Build Thread COTW 11/19/12
Detroit 5th Gen Camaro Club
ITGuy11 is offline   Reply With Quote
Old 05-14-2012, 01:35 PM   #13
TheHorse13
TheHorse13's Avatar
Drives: 2011 Black SS M6
11,000 miles and I've had the oil cooler leak and the oil pan leak. The dealer told me that the pan gaskets are far more likely to leak than the oil cooler. This information came from the call the dealer made to GM technical.
Anyhow, it does suck when these things happen.
TheHorse13 is offline   Reply With Quote
Old 05-17-2012, 11:16 AM   #14
Hannibal
Hannibal's Avatar
Looks like I spoke too soon. My pan is now leaking!
Does anyone know if the motor has to come out to make this repair? My dealer has the parts but tells me it will take days to complete because they have to take the motor out to change the pan and gasket.
