Emblempros
Old 04-23-2012, 04:56 PM   #1
armysig
Catch me if you can
armysig's Avatar
Drives: 2012 IOM ZL-1
Trailing arms and toe rods
I have a set of toe rods and trailing arms from BMR on my SS right now. I was wondering if I took them off will they fit on the ZL-1?
armysig is offline   Reply With Quote
Old 04-24-2012, 11:58 AM   #2
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Aren't they the same minus the improved ZL1 bushings? That's my understanding... Even if the tie rods are a different design (which I'm thinking I might remember that...) there has been no mention of knuckle design changes, so they should swing the knuckle off of the subframe just the same as your SS it seems to me. I wish I could offer a confirmed answer...
I need to update the FAQ, lol...
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 04-24-2012, 05:28 PM   #3
BMR Sales
BMR Sales's Avatar
Drives: Race Car
The BMR trailing arms and toe rods should fit a new ZL1 Camaro without any issue.
T.C. Davis
Sales Tech, Test Driver
813-986-9302
tc@bmrsuspension.com
Old 04-24-2012, 05:33 PM   #4
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Old 04-25-2012, 01:00 AM   #5
armysig
Catch me if you can
armysig's Avatar
I was looking at some of the pictures from VIR with the tilted ZL-1 and it looks like GM used the crappy stamped toe road and trailing arm. Thanks for the post! Love your guys parts.
I'm taking the parts off this weekend, I should be getting my ZL-1 in the next week or 2. Once I have it I'll install them to confirm.
Old 04-25-2012, 03:14 AM   #6
iHasCamaro
Drives: Silver 2012 1SS
Does the zl1 need them? The SS does and then some, but the ZL1 has better suspension. Just curious.
iHasCamaro is offline   Reply With Quote
Old 04-25-2012, 09:10 AM   #7
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
What is the advantage of these parts on the ZL1?
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 04-26-2012, 10:32 AM   #8
armysig
Catch me if you can
armysig's Avatar
Well the advantage of the parts on the Camaro is that it will keep the vehicle from doing wheel hop. The stock parts tend to twist and flex, thus producing the wheel hop you see in some Camaros.
This can only help the PTM system as when it reads data from the sensors it will not have to do major adjustments to the car as it launches.
Old 04-26-2012, 11:17 AM   #9
BMR Sales
BMR Sales's Avatar
Drives: Race Car
You are correct. GM did improve upon the rubber bushings in the factory toe rods but they still use the stamped steel toe rods and trailing arms which are prone to deflection which leads to wheel hop. Our parts will definitely be an upgrade over the factory ZL1 parts.
If you could get some installation pictures and pictures of the car it would be greatly appreciated. I would like them for my records and also to show off our BMR Suspension customers cars.
Kyle
T.C. Davis
813-986-9302
Old 04-26-2012, 11:18 AM   #10
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Regardless of the improvements of the bushings on ZL1, I still plan on a full complement of bushings from one of our Sponsors. I'm not sure I'll replace any arms, yet, but I'm definately going to be doing bushings near the top of my mod' list - cetainly before significant power upgrades.
IMHO - you have to have a solid foundation before you can start making power; it won't be any use if the car can't put it to the ground. There's nothing more funny to me than a 600 horse' car running 13s at the track, lol.
Old 04-26-2012, 11:23 AM   #11
BMR Sales
BMR Sales's Avatar
Drives: Race Car
This is definitely the way we think here at BMR Suspension. You to have a good foundation to really get the full potential out of the vehicle.
T.C. Davis
813-986-9302
