Solo Performance
Old 04-24-2012, 09:51 AM   #1
AiRDawG
AiRDawG's Avatar
Drives: 2011 Camaro 2SS
L99 Lifter Tick - An interesting situation for me.
Ok, so after reading through about 10 of these threads, including THIS very helpful thread, my suspicions have been confirmed, and as the quick iphone video shows, I'm all but certain that my lifters need to be replaced. I'm at about 23,000 miles because I just can't say no to driving this car everywhere.
Now here's where it gets interesting for me. I've voided my warranty. I've put on Headers, a "tune version" Vararam installed, and gotten dyno tuned. So my powertrain warranty is ixnay'ed for sure.
So my question for your consideration is, should I take it in and see if the dealer will do the repair because it's a known issue (in other words, since it's basically one step below a recall), or should I just preempt my inevitable power-hungry desires and get an early LS3 conversion?
Here's the vid:
AiRDawG is offline   Reply With Quote
Old 04-24-2012, 10:05 AM   #2
iHasCamaro
Drives: Silver 2012 1SS
I would put the stock tune back on and have them fix under warranty. Tune wouldn't cause lifter damage unless MAYBE you raised your rev limit and over-revved a lot.
iHasCamaro is offline   Reply With Quote
Old 04-24-2012, 10:27 AM   #3
Brolik10
BLOWN!!!
Brolik10's Avatar
Drives: 2010 RJT 2SS
Lifter tick in the L99 is well documented. Hydraulic bleed-down is the root cause. If you were planning to do the conversion anyway I'd say skip the dealer and go straight to the conversion, if not, take it to the dealer. All they can say is no..
Blown! Full Bolt-ons!
Brolik10 is offline   Reply With Quote
Old 04-24-2012, 10:28 AM   #4
Brolik10
BLOWN!!!
Brolik10's Avatar
I printed out the TSB and took it to my dealer when mine went bad.. Just in case. lol
Old 04-24-2012, 02:19 PM   #5
CyberDan
CyberDan's Avatar
Drives: 1SS Camaro
They would know when you flash the ECM. But I'm in this same boat...26k miles, so I'll be watching this thread carefully.
CAI Cold Air Intake, VMax CNC TB, Borla Sport Catback Exhaust, EE Oil Catch Can, Eibach Sway Bars and Drop Springs, AAC concept side markers, stealth signal bulbs, Heritage grille, Sparks Restorations front and rear modern SS emblems
CyberDan is offline   Reply With Quote
Old 04-24-2012, 02:38 PM   #6
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2010 Camaro 2SS A6
The TSB is for a very loud lifter tick that usually lasts for a second or two at start up.
Your video just sounds like the continuous noise of a normal L99.
Rock-It Man is offline   Reply With Quote
Old 04-24-2012, 03:08 PM   #7
GreyMare SS
GreyMare SS's Avatar
Drives: 2010 Camaro SS L99
I wouldn't hurt to consult the dealer... You may get lucky and have a mod friendly dealer and worst case senerio... They tell you no and your no worse off... Then you have to either just repair to stock or "Make a mod part of the fix" and do the conversion... either way Good Luck...
2010 Camaro SS A6, Converted, Headed, Cammed, Stalled, Tubed, Slammed, Tuned, and much more...
449/rwhp 405rwtq...
GreyMare SS is offline   Reply With Quote
Old 04-24-2012, 06:56 PM   #8
VAbdul
VAbdul's Avatar
Drives: '10 Camaro SS
Your video does not have that same noise people have been complaining about.
I hope things go well for you though, I'll make a video tomorrow.
I purchased my car at 37k miles, and have the same issue with my L99. I just noticed that this is a real issue today - but I'm assuming my car is out of warranty (?) I can't believe the previous owner never got that checked.
Does that mean I have to live with it? or is this considered a sort of recall?
I'll make a video myself, hopefully tomorrow morning since it only appears on cold-start.
VAbdul is offline   Reply With Quote
Old 04-25-2012, 05:39 PM   #9
crosscountry
Drives: Camaro ss 2010
Mine at 13000km, has a light tick at random for about second on cold start-up. I will have to wait for it to worsen to get checked by the dealer! But for now I can easily live with it, I have three years of waranty to back me up if it gets worst.
crosscountry is offline   Reply With Quote
Old 04-25-2012, 07:24 PM   #10
rolnslo
Rolling along...
rolnslo's Avatar
Drives: 2011 2SS/RS SGM
Powertrain warranty is 5yr/100k. Assuming the previous owner didn't do something to void it.
rolnslo is offline   Reply With Quote
Old 04-30-2012, 08:08 PM   #11
JOHNREX
JOHNREX's Avatar
Drives: SILVER 2010 2SS RS
Send a message via Yahoo to JOHNREX
I have the same L99 lifter tick problem, but 10 X's louder. I 'm at 119,100k miles with no mods. Good thing I extended another 100k warranty )) and getting fixed as we speak.
JOHNREX is offline   Reply With Quote
Old 05-02-2012, 12:22 PM   #12
Cpanthers85
Drives: 2011 Camaro 2SS RS
I have the same noise, same side, same everything...It's common on the L99 between the VVT and the AFM. I am about to slap a blower on my car and I last minute decided to just do the LS3 Conversion while I have it apart.
2011 2SS/RS L99
2017 Chevy SS
1979 Z28
Mods: Kooks Long Tube Headers, RotoFaB EForce CAI, American Thunder Catback Exhaust, PFADT Stage 1 Drag Kit + Front Sway Bar, GM Strut Tower Bar. ZL1 Fuel Pump. Nitto NT05R. RX Catch Can.LS9 Cam and Springs.LS3 Conversion.JRE Fuel Rail Upgrade.Edelbrock Eforce.60# Eforce Injectors.Extreme Racing Tune. 523/495
MY BUILD THREAD
Cpanthers85 is offline   Reply With Quote
Old 05-02-2012, 12:27 PM   #13
Brolik10
BLOWN!!!
Brolik10's Avatar
Wise choice..
Old 05-02-2012, 10:43 PM   #14
Frank_SS
Frank_SS's Avatar
Drives: 2010 Camaro SS/RS IOM
this is my car on cold start
http://youtu.be/hev12CtgmyQ
Frank_SS is offline   Reply With Quote
