Old 04-25-2012, 10:40 AM   #1
nicaraguanguy
Drives: 2011 Chevy Camaro LS
Heater issue
When I swapped my dash to a metra kit my heater stopped working. I didn't really care because it was summer and the Scosche kit was suppose to come out. Well I finally got the Scosche kit and the heater still doesn't work. Any idea's on why?
http://www.camaro5.com/forums/image.php?type=sigpic&userid=34327&dateline=130280  9485
nicaraguanguy is offline   Reply With Quote
Old 04-25-2012, 11:00 AM   #2
Hannibal
Hannibal's Avatar
Drives: Camaro SS & ZL1
Because you broke it.
Hannibal is offline   Reply With Quote
Old 04-25-2012, 01:15 PM   #3
Papa T
Papa T's Avatar
Drives: 2011 2LT RJT, 6A, 19" polished
From a quick look through the 2011 Owners manual:
http://www.chevrolet.com/owners/chevy-manuals/
Looks like you have multiple beaker/fuses that could be an issue:
Page 10-47
Instrument Panel Fuse Block
F5 Heating Ventilation Air Conditioning Controller
Page 10-48
F28 Front Heater, Ventilation, and Air Conditioning
Another thought is if you have your original Radio/ heater control unit... you could try to re-install to see if it still works??
Hope this helps.
Papa T is offline   Reply With Quote
Old 05-02-2012, 11:46 PM   #4
nicaraguanguy
Fuse didn't help. I'm going to take it in but since it's an after market box I hope they will find a solution. Any other idea's on what it can be?
Old 05-03-2012, 08:39 AM   #5
Papa T
Papa T's Avatar
When you say "Heater does not work" what part is not working?:
  • No Fan?
  • No heat?
  • Does AC work OK?
  • All dead?
  • Can you see anything on the heat/AC screen?
Essentially break down what is and is not working.
That may help narrow down to the issue.
Again if you have the original stereo heater unit you my need to have that reinstalled to see if that works.
  • If the original unit works... it's something with the 2 aftermarket units. (or compatibility)
  • If the original one does not work... it's something in the car... then Chevy should be able to trace it down.
Sorry that is all I've got. Good luck.
Old 05-03-2012, 02:58 PM   #6
nicaraguanguy
  • No Fan?
  • No heat?
  • Does AC work OK?
  • All dead?
Fan works, AC works, Everything works but the heater. God forbid it's not compatible, is there a work around that? Also why wouldn't it be compatible if other camaro's have it?
