Old 05-08-2009, 08:50 AM   #1
edog
edog's Avatar
Drives: 2010 2SS/RS IOM
HTC Touch PRO
I jumped in the V6 Camaro the other day. I paired my HTC touch pro streaming music to the stereo and everything was great. I could listen to music with no issue, and it sounded great.
I tried to pair the phone to the car, but it would not pair. Any ideas? When I went to the radio it gave me a code, the the phone would not take the code.
My service is through Sprint. I know my phone is not a choice for GM, but it lets me stream music from the phone, so I would think the phone would work to.
Any thoughts?
NOVI1500 ECS SC, 13lb boost, LS3 Conversion 113/225/238 COMP CAM, Pro Yank 3600, 1-3/4 Doug Thorley Tri-Y LT/HF cat, X-Pipe, Lingenfelter dual fuel pump, ATI super damper pulley, Ported TB, 160 therm, Tranny cooler, Pedders sways/end links/sub frame bushings, BMR trailing arms & toe rods, 1" Eibach Drop, 3.45 gears. 705HP/589TQ
edog is offline   Reply With Quote
Old 05-08-2009, 10:11 AM   #2
trudawg660
Drives: 2006 Dodge Charger / 2SS IOM
i had a regular touch at one time and my GPS had bluetooth and it wouldnt pair to use the phone features on the GPS. Maybe with the touch pro its the same thing
trudawg660 is offline   Reply With Quote
Old 05-08-2009, 12:17 PM   #3
tejesh83
Drives: 2016 Camaro 2SS
I've had trouble pairing my HTC Touch Pro in my Acura with a similar code issue. I wish I remembered exactly what I did to get it to work, but I'm afraid I can't remember anymore. I suggest playing around with the bluetooth settings page on the phone and hopefully you'll stumble across the solution. I would start by making the phone always visible, then use the "Add new device" function on the phone's bluetooth page. If I remember correctly, I had to start the pairing process from the car 1st and then quickly press "Add new device" for it to pair, or maybe the other way around.
tejesh83 is offline   Reply With Quote
Old 05-10-2009, 01:35 AM   #4
edog
edog's Avatar
Thanks guys, I will go back this week and try again. I want to get it right before I get mine.
Old 05-16-2009, 02:57 PM   #5
beausbriggs
2G1FT1EW3A9113560
beausbriggs's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to beausbriggs
Please let us know what you find out. I have the Touch Pro as well and hope it will work.
2SS/RS LS3 CGM/Black
2G1FT1EW3A9113560
1000, Dealer Order (4.06.09)
1100, Preliminary order accepted (04.09.09)
2000, Order accepted by GM (4.16.09)
3000, Order accepted by production control (4.21.09)
3100, Order available to sequence (5.14.09)
3300, Order scheduled for production (5.14.09)
3400, Order broadcast (5.21.09)
3800, Order produced (5.29.09)
4000, Available to ship (5.29.09)
4200, Shipped (5.29.09)
4800, Rail Ramp Unload (5.30.09)
5000, Delivered to the dealer (6.10.09)
6000, Delivered to the customer (6.11.09)
beausbriggs is offline   Reply With Quote
Old 06-05-2009, 09:46 AM   #6
beausbriggs
2G1FT1EW3A9113560
Any more info on this?
2G1FT1EW3A9113560
