HeadlightArmor
Old 05-02-2012, 04:51 PM   #29
IcePick06
IcePick06's Avatar
Drives: '12 AGM ZL1; '07 Ducati 1098
I believe it is definitely possible to lower the ZL1 an inch or less with the MRC as many CTS-V owners have done this and kits are available online. Currently D3 claims it has the only lowering kit 100% compatible with the OEM mag ride shocks:
http://www.d3cadillac.com/products/d...rings-cts-vcts
I will wait at least a year before making any performance mods to the ZL1 just so I can get a handle on it stock form; that way I can fully appreciate any changes I do make...I'm sure by that time there will be a quite a few aftermarket options to choose from as well
But lowering the car 1/2 inch or so is defintiely on my "to do" list
IcePick06 is offline   Reply With Quote
Old 05-02-2012, 05:44 PM   #30
Speed74SS
Speed74SS's Avatar
Drives: 2010 LPE 650+ CTS-V
Have you seen the LPE numbers on stock suspension???
Where is the "buy it now" button for Pedder's Coils for my LPE CTS-V?
Speed74SS is offline   Reply With Quote
Old 05-09-2012, 06:54 PM   #31
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
You're killing me...
Old 05-09-2012, 08:18 PM   #32
stymie
stymie's Avatar
Drives: 2012 Chevrolet Camaro ZL1
Personally, I would NOT lower the ZL1 unless I planned on spending a good deal more time on the TRACK than as a DD & I were ABSOLUTELY certain it would NOT screw up the MRC. If you don't care about maintaining a factory WARRANTY, I'd contact Ravikumar Ayyagari dba Umbrella Auto Design to have him fabricate a VRH/VariableRideHeight compressor driven lift kit that works with the GM MRC & will allow you to either "slam" or raise the chassis via a couple of toggle switches mounted on the dash to create a delta of up to 2.75" either way.
If you want to lower the CG, don't get a power sunroof, carry a couple of midgets in the back seats or store a load of unnecessary cr@p in the trunk. Sure, a lowered CAMARO L(. (. )KS KOOL as heck & may improve aerodynamics, but then again, you might run a risk of scrubbing your tires on the wheel wells. On real world roads, the ZL1 is plenty low enough with a shallow approach angle of 9°.
stymie is offline   Reply With Quote
Old 05-09-2012, 11:27 PM   #33
mlee
www.CamaroFans.com
mlee's Avatar
Drives: 2017 A10 ZL1
Originally Posted by SIRLOIN View Post
I think i asked this before but i can't find the thead...
http://www.camaro5.com/forums/showthread.php?t=198392
Old 05-10-2012, 10:33 AM   #34
G8GT4now
G8GT4now's Avatar
Drives: 14 SS Sedan
Originally Posted by 1954 Belair-man View Post
You can bet a nite with your wife someones gonna do it
An inch at the top is worth two at the bottom
G8GT4now is offline   Reply With Quote
Old 06-05-2012, 03:23 PM   #35
JusticePete
Update: The ZL1 responds very well to lowering, sway bars, radius and sub-frame inserts. The owners running on per-production parts are thrilled with them.
Old 06-12-2012, 04:55 PM   #36
thespymaster
thespymaster's Avatar
THRILLED is an understatement; my Pedderized ZL1 screams for corners
Old 06-12-2012, 08:43 PM   #37
tpower
DBLCHBY III
tpower's Avatar
Drives: 15 1LE
Spymaster I think its YOU screaming in the Corners !!
tpower is offline   Reply With Quote
Old 10-11-2012, 11:00 AM   #38
Richy_Rich
FAVOR
Richy_Rich's Avatar
Drives: Many Different Rides
I like the Pedders "Track 2 Xa" package for the ZL1 minus the coilovers (just springs)... would want to keep the G3 magneto struts.
It's been my good experience that any car I have ever owned rode better on the street with a complete urethane bushing swap.
- Here in ATL, we've got a dedicated alignmnet shop for Road Atlanta drivers.
Please be kind when you drive; thank you.
Richy_Rich is offline   Reply With Quote
Old 10-11-2012, 11:11 AM   #39
JusticePete
You are dead nuts on!
Does that dedicated alignment shop do suspension installs?
BTW: Pedders Presidential Poll Read BEFORE Voting
Old 10-11-2012, 11:18 AM   #40
GEEo
OKCamaros
GEEo's Avatar
Drives: 4 banger Diesel
Somebody needs to slam a ZL1!! Not just an inch or two, I'm talking about street sweeper low. Lol
Old 10-11-2012, 11:33 AM   #41
tpower
DBLCHBY III
tpower's Avatar
Drives: 15 1LE
Well buy one and let us know LOL
Old 10-11-2012, 12:47 PM   #42
Betiwin
Drives: CTS-V Coupe and GT500
Most CTS-V's getting lowered are not going with the D3 springs and new MR bars. Most are now doing Eibach's with no other modification(except cutting bump stops) and loving it. .9" inch in front and 1.1 in the back. I don't think the MR will be affected to much to notice.
Betiwin is offline   Reply With Quote
