Old 04-26-2012, 10:18 AM   #1
HRD_WRK
HARD WORKING PATRIOT
HRD_WRK's Avatar
Drives: 2011 CAMARO 2SS RS-AUTO
omitted
Thanks.
Long time avid daily reader -thanks to all for your helpful threads!
Bolt ons, Stock Torq Converter - 11.810 & 116.21
HRD_WRK is offline   Reply With Quote
Old 04-26-2012, 12:20 PM   #2
bad55nomad
Drives: 2010 Camaro 1SS A6 Inferno Orange
18-20 pounds . Play around between there for best 60 ft
bad55nomad is offline   Reply With Quote
Old 04-26-2012, 10:22 PM   #3
Jchaluja
Jchaluja's Avatar
Drives: Twin Turbo Camaro
I have been running 17 psi at the track for 3 years now, I like them, I run 10's with them...
Jchaluja is offline   Reply With Quote
Old 04-26-2012, 10:46 PM   #4
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
Is this warm temp pressure or cold?
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 04-27-2012, 06:03 AM   #5
2010SSRSM6
2010SSRSM6's Avatar
Will the 305's fit on a 10" rim?
Old 04-27-2012, 06:22 PM   #6
SGOS252382
SGOS252382's Avatar
Yes, 305s are a perfect fit on a 10" rim.
Old 04-27-2012, 07:41 PM   #7
bad55nomad
The 305 drove fine and fit fine on stock rims , They are a little heavy and if I didnt go to a 18" rim I would stay with the 275 . They stick fine at the track just heat them up good .
Old 04-30-2012, 01:08 AM   #8
2010SSRSM6
2010SSRSM6's Avatar
Originally Posted by HRD_WRK View Post
I stayed safe and went 275 to match stock and keep weight down.
Caught a deal on a second set of back stockers- so I can keep the original wheel/tread looking good for shows.
These are my secondary/lesser wheel set up-only for True Street runs not Daily driver- which is by 1 sec increments. Just needed something not shy of water box and a little more grip-was on the mark before. Not 'powered up' yet(counting the months down)-don't need a wider tire for now. Will ditch these later for 325m&h DOT/17"Bogart to match my current track only set.
Thanks for the info guys. I was thinking of sending my rears out to get widened, if they fit without it, I'll keep the $300 and put it to use elsewhere.
Old 08-30-2013, 08:40 AM   #9
Denis
Denis's Avatar
Drives: 2010 SS
bumping this thread as opposed to starting a new one....
so correct me if im wrong, 32 psi or so for the street (mainly so it doesnt piss off the tpms lol) and about 18 psi at the track. now that 18 psi is gonna be the hot pressure from driving to the track, is that taken into consideration?
Old 08-30-2013, 09:53 AM   #10
Jchaluja
Jchaluja's Avatar
That's right, I've been doing that for years on stock wheels and many 10 sec passes
Old 08-30-2013, 10:57 AM   #11
Denis
Denis's Avatar
Drives: 2010 SS
perfect! thanks!
Old 08-30-2013, 01:53 PM   #12
Juice2SS
Drives: 2011 2SS
I run between 20-23 pounds of pressure. Nothing lower than that makes me 60 foot any better. It slows down my MPH if I go too low.
Juice2SS is offline   Reply With Quote
Old 08-30-2013, 02:56 PM   #13
Denis
Denis's Avatar
Drives: 2010 SS
Well I'm full bolt on (aside from a throttle body) and its an L99.
Old 08-30-2013, 03:08 PM   #14
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
I've tried between 18 and 25 cold. The worse the track, the lower I got in air pressure. I ran them at 30 psi at Norwalk last year at the LPE event, that track was hooking bigtime.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
