Old 05-08-2009, 11:22 AM   #1
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
Head Gaskets
Do we have a definite answer on how thick the factory gaskets are???
I am going to be changing the gasket thickness on my upcoming build, but I need to know the thickness from the factory so I can calculate the change in Compression..
Thanks for any help
ZZcamaro is offline   Reply With Quote
Old 05-09-2009, 05:30 PM   #2
gunslinger
Drives: 1998 Z28 M6
I would assume it would be the same as the LS3 in the G8/Corvette. Check the compression specs on the G8 and Vette to see if they are the same as the Camaro.
Why don't you just use new head gaskets that will reach your target. You don't really need to know the Camaro's head gasket thickness unless that is the only thing you are changing (which would be a HUGE waste of time to just change head gaskets)
GTR: Get Transmission Replaced
gunslinger is offline   Reply With Quote
Old 05-09-2009, 05:36 PM   #3
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
while head gaskets can change the cr, its not going to be enough to do a whole lot. what kind of cr are you going for?
I piss excellence
and fart awesomeness
Old 05-10-2009, 10:18 PM   #4
ZZcamaro
I am going to use a normally aspirated motor until this winter...I will be running around 11:1 or 11.2:1.
Then I am building a shortblock for install this winter which will go to 9:1 and have forced induction. That is the plan right now...But I may go with a stroker instead fo forced induction. Either way it is going to be a monster.
Are the Boston Acoustics & base head unit the same? hdhomer Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 34 01-19-2012 01:54 AM
Bad news for anyone thinking of installing an aftermarket head unit fastball Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 26 05-26-2009 11:18 PM
Song Information Displayed on Head Unit ravensjeff Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 32 03-16-2009 05:28 PM
head gasket change hard or just ok? D1BADZ 4th Generation Camaros 4 11-21-2008 08:42 PM
LSX owners: AFR Cylinder Head Owners FTI-EDC General Automotive + Other Cars Discussion 0 11-10-2006 06:54 PM
