R1 Concepts
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > V6 Bolt-Ons & Tunes
Old 04-27-2012, 12:22 PM   #1
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2010 X5 Camaro Turbo
SLP Harmonic Balancer / 25% Underdrive Pulley #100232A @ Phastek Performance
2010-2012 Camaro V6 SLP Harmonic Balancer / 25% Underdrive Pulley #100232A
2010-2011 Camaro V6 SLP Harmonic Balancer / 25% Underdrive Pulley #100232A
SLP's new 25% underdrive balancer for the 2010-2011 Camaro V6 incorporates a number of high quality features you won't find on any other aftermarket unit and makes up to 6 additional rear wheel horsepower and 4 ft-lbs of rear wheel torque. Among these features are a pair of extra tall belt retention walls that eliminate the belt slippage issues common with other balancers. Other unique design strengths include a 100% steel construction (other brands use aluminum), integral timing marks and built in puller mounting threads. Includes a new balancer bolt and detailed installation instructions.
NOTE: Requires new belt part# K060810 (Gates) or 81.0" equivalent (not included)
SLP Harmonic Balancer/Underdrive Pulley Features:
Up to 6 Rear Wheel Horsepower Increase
Up to 4 ft-lbs. Rear Wheel Torque Increase
Extra-tall belt-retention "walls"-no more thrown belts!
Lighter than the stock balancer
Integral timing marks and puller-mounting threads
Does not cause false knock retard or erratic power-curve dips
Place your order today at www.PhastekPerformance.com
Sales@Phastek is offline   Reply With Quote
Old 04-30-2012, 01:13 PM   #2
Sales@Phastek
Order yours today
Old 05-04-2012, 11:37 AM   #3
Sales@Phastek
thanks for your oders!!!
Old 05-11-2012, 09:41 AM   #4
Sales@Phastek
Taking orders
Old 05-22-2012, 03:56 PM   #5
Sales@Phastek
Processing orders all day!
Old 06-08-2012, 10:36 AM   #6
Sales@Phastek
Old 06-14-2012, 03:56 PM   #7
Sales@Phastek
post or pm with questions
Old 06-14-2012, 11:33 PM   #8
Murnaneaa
Murnaneaa
Drives: Black 2011 Camaro
is there a dyno of this and will there be any cel's after instal?
2011 Black Camaro, K & N Cold Air Intake, VMAX Ice-o-Lator, Varamax Ported Throttle body, Ported Intake Manifold, Port-matched heads,SLP Loudmouth 1 Axel-Back Exhaust, Weight Reductions, 3.55 Rear end and Gear swap, Phase Cam, Pace Setter Long tube Headers, Cat deletes, Trifecta tune, RX oil Catch can, 20inch Motegi Racing Rims, Nitto Radials, etc.
Murnaneaa is offline   Reply With Quote
Old 06-15-2012, 09:22 AM   #9
Sales@Phastek
No you shouldn't have any CEL's after install.
I don't have a dyno plots either of before and after. A pulley like this won't get your more HP than what you had before. So, if you had 300 at the crank before, you still have the same 300 at the crank. The power you pick up is the difference of the parasitic affect of the heavier stock pulley vs the lighter aftermarket pulley.
Old 06-15-2012, 09:27 AM   #10
jm251
jm251's Avatar
Drives: 2010 CGM 2LT RS A6
how hard to install?
IO Int, 20" polished, Rx catch can, RX breather, CAI Inc, VMax TB, MRT V2
Future Mods: 3/8" Black Ice-olator, Trifecta Tune
jm251 is offline   Reply With Quote
Old 06-15-2012, 10:01 AM   #11
Sales@Phastek
Originally Posted by J.L.TYCHE View Post
Its a very easy install,less than an hour.Its the crank pulley take your drive belt off then remove the single bolt in the crank pulley.If the car has low miles may come off with out a puller.If you need a puller and dont have one go to advanced and rent one or pick up a cheep one at sears.
quoted from a different thread. the car should also rev a little faster and have better throttle response
Old 06-26-2012, 04:02 PM   #12
Sales@Phastek
taking orders
Old 07-10-2012, 09:45 AM   #13
Sales@Phastek
Place your orders
Old 09-02-2015, 11:40 PM   #14
Slik_ss
Slik_ss's Avatar
Drives: Black ss 2011
How could I go by this with an ss ? Should I go with a lower percentage ?
Slik_ss is offline   Reply With Quote
