Jason 98 TA
Old 04-27-2012, 08:22 PM   #1
LewisB22
LewisB22's Avatar
Drives: 1995 Mitsubishi 3000GT/2010 Camaro
Scosche and Pioneer AVIC-Z140BH
I installed the Scosche GM5201B Kit with the Pioneer AVIC-Z140BH in my 2010 Camaro 2SS. Here are some things i learned while installing it.
1. You do not need to connect the blue/white wire for the Remote AMP if you have a factory AMP. I contacted Scosche to confirm this.
2. You do not need any additional controls for the steering wheel controls to work. The Schosche kit takes care of converting the signal from the swc to the radio. For the pioneer just plug the 3.5" male connector from the scosche wire harness to the pioneer radio.
3. If your steering wheel controls (SWC) do not work, get in the car, disconnect the two connectors from the scosche gm5201b, close the doors, turn off the car, remove the key and let the car sit for 7-10 minutes. Make sure you dont open the door or activate anything while sitting there (Bring you phone and play games on it while you wait.). After this, plug in the larger plug first and then the smaller. Start the car. I had an issue with my controls and this fixed the issue. Also make sure you select pioneer in the setting on the scosche touch screen.
4. If you want Onstar to continue to work, purchase the Onstar module from scosche. This will plug into their wire harness and allow you to use the Steering wheel control to activate onstar.
5. When installing the scosche kit, i found it went in easier if i removed the screws that are located on eaither side of the console just under the dash. to get to these screws you must remove the side panels on the center console. one screw is on each side of the console. The scosche kit is a very tight fit, but it will slide in. make sure you dont just push on the front of it. If you do you will probably break the rear piece off or atleast crack where it is welded together. This is a plastic weld. instead make sure as you try to slide the scosche kit in you try to support the bottom peice. I have installed mine a couple of time and the second time was much easier than the first, because the first time i was like there is no way this thing is going to fit, but it did.
6. The gauge cluser will be tight when it goes back in as well. Some people say you need to remove the cigrette light to get it to slide back in, i didnt need to remove anything, just slide it over the gear shifter, and push it back into place. My car is a 6 speed, so i just put the car in 4th and had no problems with reinstalling the cluster
7. You can not use the usb adapter in the center console with this head unit, you can however get the CD-IU51V which is the iphone/ipod cable. it is long enough to rub back to the location where the orgional usb connector was.
IF you have any questions about setting up the pioneer z140bh and the scosche kit, let me know. I will be glad to let you know anything i have found out. So far i like the look of the kit and how it functions.
Items used:
Pioneer AVIC-Z140BH 2DIN 7" Touchscreen In-Dash Navigation AV Receiver
Scosche GM5201B 2010 Chevrolet Camaro Installation Kit
Pioneer GEX-P920XM XM Digital Satellite Tuner
ND-BC5 PIONEER Universal Rear-View Camera
Pioneer CD-IU51V AV iPod/iPhone Cable for Pioneer AV and Navigation models
Scosche VWA3B 1997-Up Audi, BMW, VW Antenna Adaptor
2010 Up Chevrolet Camaro Onstar Interface Module (Cancelled Onstar, so i removed this and just used the jumper plug that came with the Scosche kit)
2SS/RS, Cyber Gray Metalic, Black Interior
Order date- Don't Remember!
2000, Order accepted by GM 10/13/2009
2500, Order preferenced 10/14/2009
3000, Order accepted by production control 10/19/2009 TPW 11/02/2009
3100, Order available to sequence
3300, Order scheduled for production 10/23/2009
3400, Order broadcast 10/30/2009
3800, Order produced 10/31/2009 got my Vin #62932 on 11/04/2009
4200, Shipped 11/4/2009 - Railroad rail number ETTX852716
Last edited by LewisB22; 04-30-2012 at 01:21 PM. Reason: Added Parts used to install radio/nav
LewisB22 is offline   Reply With Quote
Old 04-27-2012, 09:13 PM   #2
Caddyroger
Caddyroger's Avatar
Drives: 2011 RJT Camaro LT2 RS auto shift
Glad your did ok. For some of us it was a pita if you got the the 1st version. The fist version the steering wheels controls did work you could update the firmware if you could it bricked the lcd screen. I bought a pioneer AVIC -Z130BT. I bought dash kit when it just came out so I got the first version and it took me 3 hrs to get the radio in. The rca plugs kept getting in the way. I waited 10 mins connected dash kit when just as been posted the steering wheel controls did not work. I then tried to update the firmware could not get to installed. Called Scoshe ts and told the backdoor way to get the update installed. I got the update installed the first time I turned on the car the dash kit did work. ts told me to do the 10 min reset again. Did that but still it did not work.
They was just getting the 2 version out with the new software and firmware done. I sent it in and got the 2 version. Installed the radio and dash kit and worked all right. The only thing I have a problem with it now If the sun is shinning in the passenger window it hard to see the LCD screen
Edit to add what camarograna2 stated. Tt is is a good write up for the future buyers of the Scosch kit
Caddy
Caddyroger is offline   Reply With Quote
Old 04-27-2012, 09:57 PM   #3
camarograna2
Car Enthusiast
camarograna2's Avatar
Drives: 2010 Rally Yellow Camaro 2SS A/T
Send a message via MSN to camarograna2
Good info and good write up
2010 Rally Yellow 2SS/RS
Performance Upgrades: Custom Flowmaster X system Exhaust Audio Upgrades: Too much to write down. Visit http://www.camaro5.com/forums/showthread.php?t=206016
camarograna2 is offline   Reply With Quote
Old 04-28-2012, 02:23 PM   #4
toyboy1980
toyboy1980's Avatar
Drives: 2012 45th 2LT/RS
Good write up. I've been kinda waiting on the sidelines on this one. I have an AVIC-Z120, so it's pretty much the same beast. Where did you buy your Scosche kit from?
Mods: RX Catch Can / MRT Version 2.0 Exhaust / RotoFab CAI / Apex Motorsports Scoop + Windshield Washer Bottle Relocation / Hurst "HardDrive" Plate / Mud Guards / Heritage Grill + Street Scene Lower Valance / Metra Kit + Pioneer AVIC Z120BT / AAC "Ghosted" LED Concept Side Markers / P13W Plasma LED Bulbs + DRL Harness
toyboy1980 is offline   Reply With Quote
Old 04-28-2012, 11:51 PM   #5
LewisB22
LewisB22's Avatar
Not sure my wife got it for me for my birthday.
Old 04-29-2012, 12:54 AM   #6
9072SS/RS
Drives: 2011 camaro 2SS RS
Pics?
9072SS/RS is offline   Reply With Quote
Old 04-29-2012, 12:38 PM   #7
LewisB22
LewisB22's Avatar
Originally Posted by 9072SS/RS View Post
Pics?
I actually has some i was going to upload, but Iphone vs lake and lake won. who would of thought that. But i will take some of the completed installation with a regular camera and upload them today.
Old 04-29-2012, 01:17 PM   #8
Johng57
Mid-Wife Crisis
Johng57's Avatar
Drives: 2012 Black 2SS / RS
I have the same setup - Had my Radio guy install it on Saturday - but the Scosche unit crapped out and would only light up if the plug was wiggled, and would go black as soon as the plug was released. So need to call Sonix and Scosche to get an RMA for a newer unit. I got it during the winter and waited til spring to install.
Order PVSN9X - 2SS Black, RS, GFX....
VIN - 9125176
10/08/2011 (6000) Vehicle delivered to customer or dealer has completed customer paperwork
Johng57 is offline   Reply With Quote
Old 04-29-2012, 06:41 PM   #9
LewisB22
LewisB22's Avatar
Pics?
Ok here a pic of the completed install. Dont really have any other photos from when i was installing, there was enough stuff laying around in the car without trying to take pics too. I started to take some, and i did of connecting the scosche harness to the pioneer harness, but didnt take any more after that.
In additon to the nav unit, i also installed a reverse camara and the xm receiver for the nav unit.
On a side not, the lake phone is working again. Suprising.
Old 04-29-2012, 08:17 PM   #10
montej23
montej23's Avatar
Drives: 2011 VR Camaro
did you do this all yourself and did you have the connectivity package on the car if so does your USB work and your steering wheel controls you dont need any additional connectors?
montej23 is offline   Reply With Quote
Old 04-29-2012, 11:00 PM   #11
LewisB22
LewisB22's Avatar
Yes did everything my self. Pretty much just follow the diagrams from Scosche and Pioneer and connect the pioneer wire harness to the scosche wire harness. From there its just pluging the scosche into the existing car wire harness. Nothing to cut on the car at all.
Steering wheel controls work just as before, you dont have to buy anything else. If you have onstar and get the onstar module from scosche you will be able to used the swc to initiate a onstar call like before as well.
You wont be able to initiate a call using the pioneer bluethooth however with the steering wheel controls. For this you have to push the button on the poineer unit, which isnt a big deal, as its the first one on the left of the pioneer nav unit. (note that pressing this button down will mute the radio.)
My car did have the connectivity package. the existing USB will not work once you install the pioneer and scosche. However i ran the usb connection from the pioneer to the place where the existing usb connection was. and I purchased the Pioneer CD-IU51V which is basically lets you hook your iphone/itouch to the pioneer and use it for a variety of things besides just listening to the music. You can watch videos off the iphone/itouch with this cable as well. And its a 1 amp connection, so you can even charge an ipad from the connection, something i havent been able to do with a cigrette charger. If you have an andriod you dont need the cd-iu51v. just connect directly to the pioneer usb cable.
Old 04-29-2012, 11:23 PM   #12
montej23
montej23's Avatar
do you have heated seats ? if so does this kit allow you to keep this? and what about the xm fin were you able to still use the antennas that came standard on the car?
Old 04-30-2012, 12:01 AM   #13
LewisB22
LewisB22's Avatar
Yes i have heated seats and yes the kit allows you to continue to use the heated seats. the controls are on the scosche touch screen. Two levels just like the orgional.
As far as the antenna, i didnt use the existing xm fin antenna becuase in my experence, it sucked with the exisiting radio, so i just placed the pioneer xm antenna on the rear trunk. its really small and it doesnt bother me that its there. I'll get a photo of it tommorrow if i remember. If you want to use the existing XM antenna, then there is an adapter for connecting the xm unit to the existing antenna. I think i actually bought that adapter, but i ended up not using it.
I did use the existing FM antenna for the FM/HD radio. There is an adapter for going from the existing radio antenna cable to the on on the pioneer unit. i dont have the model handy right now, but i will try to dig that up as well. Ok here is the antenna part info: Scosche VWA3B 1997-Up Audi, BMW, VW Antenna Adaptor
Last edited by LewisB22; 04-30-2012 at 01:21 PM. Reason: Added Antenna Part Number
Old 04-30-2012, 12:43 AM   #14
jeffa
Drives: 2014 2LT/RS Ashen Gray Metallic
When you install an aftermarket unit, you cannot use the XM receiver that comes with the factory radio. You will need to purchase a universal XM tuner and connect it to your aftermarket unit.
jeffa is offline   Reply With Quote
