Homepage | Garage | Wiki | Register | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools |
#211 |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
Nothing worth noting. Still waiting on parts & pieces, and raw materials for the silicone insulation... Unfortunately I still haven't shipping any of the test intakes.
I did however finally get all of the pieces together to flow test through a throttle body, intake, and head. Perhaps I will report the results from that testing soon. |
#212 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro 2SS/RS Join Date: Apr 2011
Can you explain what a knock retard is. I have a few others use this term, but don't know what it is.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, RX CC, GFX, Subs.
#213 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS LS3 Join Date: Sep 2010
Quick answer. Knock retard is the ECM's response to perceived knock, whether from actual pre detonation (lean conditions, too much timing, poor fuel quality etc), torque management, or false knock ( headers hitting the chassis). KR = timing being reduced in a attempt to stop the knock.
She is only memory now. |
#214 |
BliSSard has come!
Drives: '16 Camaro 2SS, '13 Equinox CRT Join Date: Jul 2009
Good explaination! I had KR that was caused by a loose starter motor which happens to be about an inch or 2 from the right side Knock sensor!
#215 |
So, let's talk about "flow"...
A flow bench is a tool, much like a dyno. With a baseline, you can see gains or losses from changes made to whatever you happen to be testing... A dyno reading can change from run to run depending on many conditions. A flow bench reading can change but it is typically weather dependent. My flow readings may differentiate from the next guy simply because I am in a different state with a higher/lower altitude with a different climate. That said, there has been some flow testing through an LS3 head, intake, and throttle body posted on the internet. These numbers will vary from what everyone else reports simply because of the reasons stated above, much like a dyno run from the same car on a different dyno, or in a different climate or location. However, if a baseline is established, the results will have validity as long as the test is completed in the same manner each time. Next thing... Yes, a flow bench does not "flow" like an engine does. However, an improvement is an improvement. Why do people port heads? More flow... Why port an intake? More flow... Why headers??? More flow... Air in, air out...Right?! While bench testing may not flow the same as a running engine, more flow is more flow... Although it may not be as much in an engine vs as shown on a flow bench... More is more. Now that we're all on the same page. I acquired an LS3 head (thank you Tracy @ RX!), intake, stock throttle body to test things I have on my flow bench. The following numbers were recorded at appx 2500'DA, 74deg F, @ 28" of water, .500" lift at the intake valve on cyl #3. Head/intake/TB with NO intake system: 310 CFM w/ Stock airbox/tube/filter: 294.8 CFM w/ Stock airbox/tube/S&B Filter: 297.8 CFM w/ an OTR intake: 300.9 CFM w/ tube and cone filter: 303.9 CFM w/ Complete JacFab intake: 306.4 CFM (w/ heat shield & lid) It's really quite amazing to see how close the intakes are when flowed through the head/intake/tb vs by themselves as I've tested previously... However, of the intakes that I still have, they still flow more/less in order as I have tested previously without the head/intake/tb. A little details about the competition? The cone filter intake is just that, but in it's best case scenario for flow, no heat shields, no lids, NOTHING blocking any kind of flow to the filter. The OTR is just that, an OTR "ram air" intake. The cone intake was tested with a brand new filter, the JF and OTR intake were tested with a freshly cleaned, and properly oiled per manufacturers specs filter. This particular test with the JF intake was with a K&N, but I am currently testing an S&B filter in the car. If you've followed my previous testing of filters in the stock box, the S&B flows more than the K&N... All of my dyno testing was done with a K&N. That said, I won't mention whose intake is whose other than my own, but know that I'm not playing with ebay intakes here, I have spent a lot of money to procure the best of the best to compare against, as well as a lot just developing this intake... I have no reason to falsify anything, If I thought that this design was bunk, I would have abandoned it long ago and joined the rest of the crowd to build another cone filter intake. The info is as I have personally found it to be. That's where the independent testing comes in... While I have had some set backs recently with mine, holding back shipping of the independent testing intakes... I expect the first test intake will ship the week after next if all goes according to plan w/ fit int the car next week. The first tester should receive theirs before Christmas. If all goes well assuming there are no set backs prior to shipping the first, the second will ship to Lethal Racing shortly after Christmas... ![]() |
#216 |
![]() ![]() Drives: 2017 RS convertible Join Date: May 2009
thanks for the update Jason.
Camaros I've owned:
1969 RS/SS Z10 Indy Pace Car - Hardtop 1 of 250 1970 Camaro 2010 2LT RS 2013 2SS RS Current ride: 2017 Camaro 2LT RS convertible |
#217 |
![]() Drives: 416 w/TH400 Join Date: Mar 2012
sounding like you are REALLY close................... can't wait
#218 |
Drives: '15 Z06, '01 NBM SS, '97 SS Join Date: May 2009
![]() Cant wait to see these drop sir!! Ivan |
#219 |
![]() ![]() ![]() ![]() Drives: 11 IOM 2SS/RS M6 w/Hurst Join Date: Nov 2009
Oooooo I just saw this thread. I have a Jacfab license plate holder that I like quite a bit. I would be very interested in another product from you.
Cheers K |
#220 |
![]() ![]() ![]() ![]() Drives: GT500 and 14 ZL1 Join Date: Nov 2011
Keep us updated
Gone but not forgotten:
1974 Corvette Stingray 454 1986 Z28 2009 Mustang GT convertible 2012 45th 2SS Vert 2013 ZL1 M6 |
#221 |
![]() Drives: 2010 ss2 white w/gold stripes Join Date: May 2011
I am still thinking on getting this when it's ready.
#222 |
Me too
#223 |
![]() ![]() ![]() ![]() Drives: 2018 Camaro ZL1 Join Date: Jun 2011
Any updates?
Sent from my iPad using Tapatalk HD
#224 |
![]() Drives: Sofia: 2012 Chevy Camaro 2SS LS3 Join Date: Feb 2012
Any updates ???? Still very interested in this product.
Interior: 2-tone gray interior, Blue Dome and trunk lights, L.A. Dodgers floor mats (to come: footwell lighting)
Exterior: Sunroof, custom painted gray stripes, vinyl Bowtie emblem decals, Holographic Transformer decals, white license plate LED lights Sounds: Stock highs, Alpine MRX-M100 amp mated to a 12" JL Audio W3 in a ******** Stealth enclosure Engine/Performance: Hurst Short Throw Shifter, Rx Catch Can painted IBM, (to come: JacFab CAI, muffler delete/Flowmasters) |
Tags |
cai, dyno, intake, jacfab, velocity |
Thread Tools | |
