sjm autoprod
Old 04-28-2012, 06:18 PM   #1
iLLcoolZ
NSM
iLLcoolZ's Avatar
Drives: 2012 AGM 2SS/RS
Syncing a Samsung Galaxy Note to your Camaro
Hey guys!
I currently use an iPhone 4, but I'm thinking of buying a Galaxy Note. Can I sync it with my Camaro to make calls and listen to music through bluetooth? I really need to make sure this specific feature will work.
Thanks guys.
Stay hungry, stay foolish.
iLLcoolZ is offline   Reply With Quote
Old 04-28-2012, 06:27 PM   #2
edgehead2000
2016 Camaro 1LT 2.0T
edgehead2000's Avatar
Drives: Nemesis
I'm almost sure it will work. I connected two samsung products up to the car this past year and even my cheap walmart phone works too.
edgehead2000 is offline   Reply With Quote
Old 04-28-2012, 06:53 PM   #3
007s 'Vert
Formerly Lil'BlueCoupe
007s 'Vert's Avatar
Drives: '13 2LT/RS Vert, Summit White
I use my Samsung Captivate all the time and it syncs up automatically via blue tooth all the time and without ever a problem. I too am planning on getting a Note as well(when they come down on their prices) and it should work just fine
007s 'Vert is offline   Reply With Quote
Old 04-28-2012, 07:01 PM   #4
iLLcoolZ
NSM
iLLcoolZ's Avatar
Can you also play the music via bluetooth? Or only make the calls?
Thanks a lot guys
Old 04-28-2012, 07:12 PM   #5
wtcadman
wtcadman's Avatar
Drives: 2013 black 2lt with rs package
I have a galaxy note and I have it connected via Bluetooth to make calls and play music
wtcadman is offline   Reply With Quote
Old 04-28-2012, 07:18 PM   #6
GbrilliantQ
¡ʇuɐıןןıɹq
GbrilliantQ's Avatar
Drives: 2011 Camaro IOM 2SS/RS
Yup, my note syncs up just fine. Love my note.
Sent from my Galaxy Note
GbrilliantQ is offline   Reply With Quote
Old 04-28-2012, 07:24 PM   #7
iLLcoolZ
NSM
iLLcoolZ's Avatar
Excellent! Thanks a lot guys, I really appreciate it. I honestly could not find the answer anywhere on the web! So I thought I'd just ask it here. Thanks again.
Old 04-28-2012, 08:51 PM   #8
Emig5m
100% Sport Møde
Emig5m's Avatar
Drives: '17 Civic SI + '04 SVT Lightning
In the audio forum they say that the sound quality of bluetooth isn't that great.
Emig5m is offline   Reply With Quote
Old 04-28-2012, 09:51 PM   #9
bdsdnfam
NoJoken
bdsdnfam's Avatar
Drives: Synergy Green SS
It works. I have a Galaxy Tab and a Galaxy Note. Both sync up!
bdsdnfam is offline   Reply With Quote
Old 04-29-2012, 08:03 AM   #10
Sw0rdf1sh
Sw0rdf1sh's Avatar
Drives: 2012 45th Anniversary - No Stripe
Agreed. I have my Galaxy Tab mounted from Center Speaker (Pro-Clip) and the bluetooth works great for me. I play movies for my kids in the backseat a lot.
2012 45th Anniversary LT2; Stripe Delete; MnP Carbon Fiber Bowtie Inserts; ORACLE Concept SMD Sidemarkers; Oracle LED License Plate Bulbs, ProClip Center Speaker Mounted Samsung Galaxy Tab, Sequential Taillights
Sw0rdf1sh is offline   Reply With Quote
Old 04-30-2012, 04:33 PM   #11
nhbouncer
nhbouncer's Avatar
Drives: 2011 2SS/RS Summit White IOM rally
as mentioned it works for sure I too have a note I do find that bluetooth music lacks in the low end unfortunately. I have an old gen 2 30gig ipod I leave connected in the console for music it doesnt hold a charge any more so it's perfect to leave in the car.
nhbouncer is offline   Reply With Quote
Old 04-30-2012, 08:19 PM   #12
mouserinc
Drives: 2012 1LS
ok quick question on getting the Bluetooth to play music. do you need the anything special at all or should it do it automatically? I have my Droid Razr synced with Bluetooth for the phone but couldn't figure out how to do it for the music.
mouserinc is offline   Reply With Quote
Old 05-10-2012, 07:51 PM   #13
patternpilot
patternpilot's Avatar
Drives: 2012 2SS/RS 05 Jag S type R
Bump
I have a Galaxy Note and had no problem syncing it, but did not see an option or way to play music through Bluetooth. Any suggestions from those who have done this successfully.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, No Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears.
patternpilot is offline   Reply With Quote
Old 05-10-2012, 08:58 PM   #14
Pur3vil
Drives: 2010 ABM 2SS/RS M6
As long as you have the media bluetooth connection (different from the hands free calling bluetooth connection) you should be fine. Go to any of the cd/aux inputs, press menu, go to bluetooth setup and pair the device for GMmusicConnect (or something close to that). Once paired and connected you should be able to play music from your phone or stream pandora, IheartRadio, etc...
Pur3vil is offline   Reply With Quote
