JUICEDMOTORSPORTS
Old 04-29-2012, 10:00 AM   #1
my2SSRS
my2SSRS's Avatar
Drives: 2010 2SS/RS 6 spd RJT
Exclamation New Gears, now lights on all over the dash??
Ok so just put in 4.11's, as soon as i turn the key on it says service stabil control, ABS, all my stabile control, track control lights on the dash are lit up..i have an sct programmer from JRE and its not showing any dtc's...any ideas.. I have JRE's 91 octane tune loaded, the speedo is right. I have unhooked the battery and nothing changed?? THanks for any info
Russ
2010 2SS/RS 6 spd. Silver Ground Effects, Tinted Windows, BFE SS longtube headers, 3" X, mid pipes,Flowmaster 10 mufflers, ROTO-FAB CAI, 4.11 RG's, Phadt Racing Bushings, JRE custume tune, Mobile1 ATF, RP rear gear oil, Custom badges, Hide away front plate holder. Custom engine cover and hood liner. 412 rwhp
my2SSRS is offline   Reply With Quote
Old 04-29-2012, 11:19 AM   #2
swiftkart
swiftkart's Avatar
Drives: 2010 SS/RS LS3 M6
You might check the plugin on the passengers side next to the fuel tank, they may have unplugged it and forgot to plug it back in which will cause what you are seeing, it happened to me.
swiftkart is offline   Reply With Quote
Old 04-29-2012, 11:20 AM   #3
The Stig
knows 2 facts about ducks
The Stig's Avatar
Did you get your speedo recalibrated/tuned
Click to view my build thread
Old 04-29-2012, 04:41 PM   #4
my2SSRS
my2SSRS's Avatar
checked the plug, and everything looks good there...???
Old 04-29-2012, 04:43 PM   #5
my2SSRS
my2SSRS's Avatar
the tune from Ted must have it in there, because i have done nothing but load his 91 tune, when i took it out i had my gps and its right on the money!! Any other ideas? Sure dont want to take it to the stealer!! thanks for the info..
Old 04-29-2012, 05:06 PM   #6
The Stig
The Stig's Avatar
As far as I know Ted's tune is a tranny tune and doesn't tune the speedo. But I have been wrong before.
Old 04-29-2012, 05:16 PM   #7
2L82RUN
2L82RUN's Avatar
Drives: ABM SS/RS
If its out of alignment from having it apart it will throw a stabilitrak message. Happened when I replaced my toe rod arms. Is steering wheel normal or off to one side? Just a thought
2L82RUN is offline   Reply With Quote
Old 04-29-2012, 08:22 PM   #8
my2SSRS
my2SSRS's Avatar
steering wheel is good, and the speedo is right on, i've got the m6. Wondering if the wire from the hub up to the plug got damaged somehow?? Does that wire come out of the hub so i could to a contunutity check on it??
Old 04-29-2012, 08:23 PM   #9
my2SSRS
my2SSRS's Avatar
so how did ya fix it, cause i do have the stabil track message as soon as i start the car, and all the other lights on??
Old 05-10-2012, 05:30 PM   #10
my2SSRS
my2SSRS's Avatar
Exclamation
*UPDATE* So i went to the dealer and ordered the left side speed sensor, changed it out and good to go!! So how the little wire got damaged inside, couldnt see any damage but that was it!! Thanks for all the info!!
Old 05-14-2012, 02:10 PM   #11
Chevrolet Customer Svc
Drives: GM Vehicles
Glad to hear that the dealership you work with was able to work out this issue for you!
Brandon
Chevrolet Customer Service
Chevrolet Customer Svc is online now   Reply With Quote
