Emblempros
Old 05-01-2012, 06:50 PM   #15
Jermola23
Drives: 2011 black camaro
It as close as what the challenger has in the cupholders
Jermola23 is offline   Reply With Quote
Old 05-01-2012, 10:56 PM   #16
GunnyG
Da WHALE
GunnyG's Avatar
Drives: 2014 Stingray, 2015 Panamera 4
Originally Posted by martinezj454545 View Post
If you get all the parts to it which will just be El Wire, Aquarium tubing, and the cup holder cover ill help you install it. No worries about charging anything.
Alright, sounds good. Could you pm me where you picked up the stuff from? And a brew or two is not too steep a price for me bro!
Project MantaRay...Underway
GunnyG is offline   Reply With Quote
Old 05-01-2012, 11:05 PM   #17
ubrimah
Oreo
ubrimah's Avatar
Drives: Summit White LT/RS A6
Originally Posted by REDXIIIDave View Post
OP,did you use the quick connect wires from this site?
Click the pic!
ubrimah is offline   Reply With Quote
Old 05-02-2012, 12:28 AM   #18
martinezj454545
Drives: 2011 Camaro LS V6
Originally Posted by bee sting View Post
I like the look ! Wonder what it would look like with a plate over it . My setup now is just the 2 leds in abl and a Camaro billet plate cover.
Not a bad price either.
It is with a plate over the cup holder, i glued the aquarium tubing to the inside of the plate.
martinezj454545 is offline   Reply With Quote
Old 05-02-2012, 12:39 AM   #19
Jermola23
Inside or under the plate?
Old 05-02-2012, 12:40 AM   #20
martinezj454545
Originally Posted by Ben Thur View Post
did you drill into it and where?
no i did not drill into anything i ran the el wire around the cup holder cover plate and into the arm rest (if thats what you call it) by the center console.the only way you can see the el wire is if you lift the top cover on the arm rest but then again its only a couple of centimeters that you will be able to see, i just cant start drilling hole on it, not into all that so i try to find ways to get around drilling if i can.
Old 05-02-2012, 12:42 AM   #21
martinezj454545
yeah i seen someone post a picture of it and the cup holder was clean and it didnt have excess light shining through so thats what gave me the idea of doing it like this to see if we can have something like that on a camaro and i think it came out pretty well in my opinion. Going to see if i can do it again but this time a much cleaner version.
Old 05-02-2012, 12:43 AM   #22
martinezj454545
its on the inside of the cover plate and glued to the thickness portion if it make any sense.
Old 05-02-2012, 12:48 AM   #23
martinezj454545
The Aquarium tubing i picked up from pet smart or any pet store that sells aquariums lol, the EL Wire you can Google search it and find it online and the prices veries,
tools
-tape
-pliers
-soldering iron & solder.
Old 05-02-2012, 12:54 AM   #24
martinezj454545
i did use quick connects wire but not from this web site and i also soldered my own connections. the one on this web site look like the will solder the quick connect to the el wire for you which i would recommend getting because its a pain cutting the el wire just right. If you buy the el wire from this web site also buy the inverter if you don't have a inverter than your el wire will never work.
Old 05-02-2012, 06:02 AM   #25
bee sting
bee sting's Avatar
Drives: 1997 30th Ann. Z28 & 2010 2LT RS
Thanks for the info.
bee sting is offline   Reply With Quote
Old 05-02-2012, 03:34 PM   #26
ubrimah
Oreo
ubrimah's Avatar
What do you do with the inverter once it's plugged in to the el wire? Do you just wire that into a power source?
Click the pic!
Old 05-02-2012, 08:03 PM   #27
martinezj454545
That's correct wire the inverter to any 12 volt power supply.
Old 05-07-2012, 10:48 PM   #28
LED Crazy
okcamaros.com
LED Crazy's Avatar
Drives: 2012 2SS/RS IOM L99
Could you provide a day time picture of this mod?
LED Crazy is offline   Reply With Quote
abl, cup holder, el wire, lights
