BORLA
Old 04-30-2012, 11:05 PM   #1
Breesy
Breesy's Avatar
Drives: 2011 CGM 2LT
Unhappy Need help. Window scratches...maybe
Looking for some expertise on windows streaks/scratches. My driver side window had streaks on it when I purchased it. It was a certified pre-owned...barely over a year old. But it looks like the bottom window seal had caused the windows to streak or actually scratch the glass.
I've tried everything from alcohol to window cleaner to a clay bar but it seems it might be scratched. The whole back half of the driver's side windows is like this. I've attached a close up of what it looks like.
Any ideas on how to fix it or will I have to replace it? If so how much would that cost? Thanks for the help in advance.
Breesy is offline   Reply With Quote
Old 05-01-2012, 12:09 AM   #2
Todd@Autopia
Todd@Autopia's Avatar
Drives: 2010 Mazdaspeed 3
If they are scratches you will likely need a machine polisher to fix them. Do you own or have any experience with machine polishing?
Old 05-01-2012, 12:10 AM   #3
Todd@Autopia
From the pic though they don't really look like scratches as they appear to wave back and forth. When you cleaned with alcohol did you notice any transfer (color) on the cloth?
Old 05-01-2012, 07:27 AM   #4
Breesy
Breesy's Avatar
I don't have any experience doing this.
When I rub my hand across it the marks feel like bumps or ridges. I can't remember if there was any transfer after cleaning it with alcohol...
Old 05-01-2012, 06:40 PM   #5
Angelo@Autopia
Angelo@Autopia's Avatar
Drives: 2014 Ford Focus ST
Try Duragloss Nu-Glass by hand. It will not scratch, distort, haze, dull, or damage your glass. It runs about 6-7 bucks and works pretty well in polishing and removing junk off your windshield. You can also use a PC with a White pad to remove and polish the glass.
Old 05-01-2012, 07:04 PM   #6
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
Those don't look like scratches to me... like Todd suggested wipe with alcohol first to see if they come off. Even take a mild polishing compound and rub on a small section to see if the area improves... its possible the glass just has something stuck to it.
I've also seen cases where there was grease or some kind of contamination on the bottom seal that just keeps streaking up the glass when its rolled up/down.
Old 05-01-2012, 07:35 PM   #7
Angelo@Autopia
It also could be dirt trap in the window channel and when you raise or lower the window this is what you get. Check your weather strip in that area for trap dirt or junk in there.
Old 05-01-2012, 08:35 PM   #8
Breesy
Breesy's Avatar
Thanks guys. I tried alcohol before and it didn't do anything for the streaks. I have cleaned the weather strip on the bottom...that's probably what caused it in the first place. I'll have to try that polish to see if it helps.
Old 05-01-2012, 08:36 PM   #9
Breesy
Breesy's Avatar
any place local I can get this? I see you're in Tampa also.
Old 05-02-2012, 06:30 AM   #10
Angelo@Autopia
Most Car Quest stores have them and these places also: http://www.autopia-carcare.com/duragloss-car-care.html
http://www.superiorcarcare.net/durag...FYqb7QodF2CzUg
Yes, I'm in the Palm harbor area.
