Old 05-01-2012, 09:34 AM   #1
BowtieBelle
They see me trollin'...
BowtieBelle's Avatar
Drives: 217 ci of fury; Chauffeured by SS
Unhappy Don't think this one will buff out-- suggestions?
So I woke up at 4am to the sound of an awful thunderstorm. My car was not in the garage, so I bolted downstairs and outside to put it away. The windows were fogging, it was beginning to hail and pouring down rain.
So when I pulled into the garage I cut it too close and scraped the crap out of the mirror.
As you can see there's a bit of paint missing (maybe 1mm by 3mm, right on the edge), and brown paint on the edges of the mirror from my garage trim.
Any suggestions? The mirror itself is fine; but I'm sure having it painted would be stupidly expensive. Think I should pony up and have it repainted, or just touch it up with Dr. ColorChip and a clearcoat pen, or touch-up paint? Advice welcome. BAD way to start my day
"Never race anything you can't afford to light on fire and push off a cliff." -CamaroSpike
2011 Custom LT/RS: Bella's Build Thread
BowtieBelle is offline   Reply With Quote
Old 05-01-2012, 09:39 AM   #2
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
That's a bummer....Might be time for some mirror stripes! Theres some that don't look bad at all. I know what you mean about the not wanting to paint it...big hassle...good luck!
90503 is offline   Reply With Quote
Old 05-01-2012, 09:40 AM   #3
bhall82
Drives: 2011 SS/RS
The brown will buff off, then go from there. It looks like it's on the bottom maybe one of the shitty touch up pens GM has will take care of the rest. Good luck
bhall82 is offline   Reply With Quote
Old 05-01-2012, 09:43 AM   #4
h2oplay
Winners find a way
h2oplay's Avatar
Drives: 2010 2LT/RS M6
buff off the brown paint first, see what's left after that....
Injen LT | Magnaflows | BBK LT & HFC | Mace 25mm & P Spacer |Richmond 3.73 | Trifecta Tune
RX Catch Can & Breather | Pedders Inserts | IDEALG Clutch MC & GTO Reservoir | JDP Colorshift Halos | Drake Bowtie Delete |
h2oplay is offline   Reply With Quote
Old 05-01-2012, 09:43 AM   #5
BowtieBelle
I hate those. I can never get the pen to work. I have one.
Maybe fill it with Dr. ColorChip...? I don't know. :(
Old 05-01-2012, 09:44 AM   #6
toesuf94
toesuf94's Avatar
Drives: THR #11 E-force supercharged
Send a message via MSN to toesuf94
Sorry about the bad luck Belle...Like has been said: The brown may buff off and then touch up from there. Sorry that doing the right thing for your baby caused this, but it is better then hail.
Cars and women are both going to give you problems...but you can pay somebody else to fix your car!
toesuf94 is offline   Reply With Quote
Old 05-01-2012, 09:45 AM   #7
BowtieBelle
That's what I keep telling myself. We had quarter sized hail, so this is the lesser of two evils, right?
How do I even buff the brown paint out on an edge??
Old 05-01-2012, 09:45 AM   #8
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
I think that a bit big for Dr. Colorchip.
FSP tuned: 377/389
Old 05-01-2012, 09:46 AM   #9
BowtieBelle
The spot where paint is actually missing is tiny. Like I said maybe 1mm by 3mm...
Old 05-01-2012, 09:47 AM   #10
bhall82
Drives: 2011 SS/RS
Buffing compound, a rag, and some elbow grease
Old 05-01-2012, 09:47 AM   #11
h2oplay
Winners find a way
h2oplay's Avatar
pickup some scratchx, that will cleanup the brown, I would then try the drcolorchip, cant hurt to try....
Old 05-01-2012, 09:47 AM   #12
nyrfan
Let's go Rangers!
nyrfan's Avatar
oh I see now, the paint is in the groove. That may be a hard one becasue of the groove. I'd start with scratchx and a foam buffing pad.
FSP tuned: 377/389
Old 05-01-2012, 09:51 AM   #13
Wizard1183
Wizard1183's Avatar
Drives: ABM SS2/RS M6
Send a message via Yahoo to Wizard1183
As one poster said, buffing compound. I suggest trying that first, as it should come off, If not Id recommend getting some 12-1500 grit sandpaper and west sanding it. Thing is you want VERY light pressure on a corner. Otherwise youll hit the sealer and have grey showing.
Life is short, drive it like you stole it!
Wizard1183 is offline   Reply With Quote
Old 05-01-2012, 09:53 AM   #14
Wizard1183
Wizard1183's Avatar
Thats scratchx, use VERY light pressure. Itll come out and then you polish it and itll be fine.
