HeadlightArmor
Old 05-01-2012, 12:35 PM   #1
tdp1
tdp1's Avatar
Drives: 2012 SS
All kinds of error codes!
Ok, just got her back from the stereo shop where I got the complete sound proofing and stereo installed. Pioneer head unit and Boston speakers. they had the interior completely taken out for the sound proofing. Dash, steering wheel and all. Now Im getting error codes for the traction control. Did they miss re-connecting a plug or what? I'll be taking it back. Just wondered if anyone has experienced something like this. Thanks!
tdp1 is offline   Reply With Quote
Old 05-01-2012, 12:39 PM   #2
garcmol
garcmol's Avatar
Is your steering wheel straight? I'm not exactly sure, but I believe there is a sensor in the steering column that relates itself proportionate to the wheels. So even if the steering wheel is straight, the sensor may be misaligned. This may be the cause of it.
Old 05-01-2012, 12:43 PM   #3
tdp1
tdp1's Avatar
Drives: 2012 SS
Seems to be straight.
Old 05-01-2012, 01:00 PM   #4
garcmol
garcmol's Avatar
Well, I'm linking you to this thread. There isn't a lot of info there, but some possible causes.
A low voltage situation can even trigger the service stabilitrak light. Even misfires do it. The OP in the below thread hit his OnStar button and the tech told him of the wheel position sensors.
http://www.camaro5.com/forums/showthread.php?t=38722
Is it triggering a check engine light or just the service light?
Old 05-01-2012, 01:06 PM   #5
tdp1
tdp1's Avatar
Drives: 2012 SS
I have several warning lights on. If I take it to the dealer, will it be covered under warranty since it was messed up because of an aftermarket stereo install?
Old 05-01-2012, 01:10 PM   #6
garcmol
garcmol's Avatar
Can't answer that. But sounds like your initial thoughts that the shop didn't reconnect something. That, or spliced into something that's now not getting enough/too much power. It wasn't like this when you picked it up from the installer? You should definately get ahold of them!
Old 05-01-2012, 01:20 PM   #7
tdp1
tdp1's Avatar
Drives: 2012 SS
i will, thanks!
Old 05-01-2012, 03:14 PM   #8
Hollywood2010
Hollywood2010's Avatar
Drives: 2010 SS/RS
Hollywood2010 is offline   Reply With Quote
Old 05-02-2012, 12:37 PM   #9
Cam 427
Cam 427's Avatar
Drives: 2010 2SS
Don't know what goes through the original stereo as far as data...but when a component is removed, it can cause issues like this because the data lines are disconnected.
You might check with the stereo installer if the new stereo has the capabilty to pass the data along. If not, did they they reconnected the data buss wires?
Just a thought, because I had a simular problem like this with a component removal.
Cam 427 is offline   Reply With Quote
