Emblempros
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 05-02-2012, 09:10 AM   #1
TG 68 Z28
Drives: 1968 z28
painted zl1 on polished wheels
This may have been posted before but I was thinking about painting the ZL1 on the polished wheels. Does anyone know what kind of paint could be used to hold up and look good?
TG 68 Z28 is offline   Reply With Quote
Old 05-02-2012, 09:16 AM   #2
kalamajama
Drives: 2012 ZL1 2002 Silverado, 2010 Prius
Thinking about powder coating mine black with red accents on the arrows and the ZL1 stamp. my car wont deliver until next week. And it's black.
kalamajama is offline   Reply With Quote
Old 05-02-2012, 09:24 AM   #3
jazznurse
jazznurse's Avatar
Drives: 2012 ZL1;2011 Cruze
I'm definitely painting mine. Probabily Gold leaf and clear coat. I've got the center caps with the gold bow ties, all in keeping with the theme of Black, gold and orange to match my number and class letters.
jazznurse is offline   Reply With Quote
Old 05-02-2012, 11:05 AM   #4
TG 68 Z28
Drives: 1968 z28
Do you think it could be painted by anyone or would it need to be power coated to hold up.
If if could be painted what kind of paint do you think would hold up
Old 05-02-2012, 12:09 PM   #5
kalamajama
Was told that it should be sand blasted somewhat then powdercoated. And can be accomplished without removing the tires off the wheel. When mine gets done, i'll post it.
Old 05-02-2012, 12:50 PM   #6
b_williams_82
b_williams_82's Avatar
Drives: 2013 ZL1 #142
Don't you have to set the wheel in an oven to "bake" to powder coat? I don't think you can leave the tires on.
b_williams_82 is offline   Reply With Quote
Old 05-02-2012, 04:05 PM   #7
kalamajama
I stand to be corrected. Yes they do require about 400 degrees F of heat for about ten minutes or so. So yes the tires will have to come off. Thanks for the correction.
Old 05-03-2012, 12:00 AM   #8
1MtnGoat
1MtnGoat's Avatar
Drives: '12 SIM ZL1, 1 of 49
I've been thinking on doing this to my polished wheels. The ZL1 recess has nice sharp edges. I believe if one were to clean the recess well with a q-tip and brake cleaner (sprayed on the q-tip not the wheel). Then use automotive touch-up paint with the small brushes in your choice of colors to paint the ZL1 then wipe off the edges of each letter carefully while the paint is still wet you should get a nice sharp edge. I would put the same type of clear coat over the color coat also. Again clean the edges while the paint is wet. When I find time I think I'm going with a black ZL and a red 1. I don't think the ZL1 needs power coating.
1MtnGoat is offline   Reply With Quote
Old 05-03-2012, 09:06 AM   #9
DangerZL1
Drives: Future ZL1 Owner
This is a great idea. I'm thinking about buying the Black bowtie precut vinyl and using it on the center caps.
DangerZL1 is offline   Reply With Quote
Old 05-03-2012, 09:21 AM   #10
TG 68 Z28
Drives: 1968 z28
I talked to a guy at a body shop and he said to get the model paint. Said he has used that before and it held up really good
Old 05-03-2012, 10:45 AM   #11
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
clean, scotchbrite,mask spray. good to go. any automotive paint will work.
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 05-03-2012, 01:14 PM   #12
hognutz
hognutz's Avatar
Drives: 2013 ZL1
Weather you paint or powerdercoat there will be prep to the metal. Powerdercoat is more durable than paint and they will bead blast there rims as part of the process then do color and usually some places do a clear over the powerdercoat as well different shops sometimes have a bit different recipe so to speak.
MY .02 is find soone who powdercoats wheels alot and will stand behind the work. even if it cost more. painted and powdercoated wheels look great. flaking wheels look like crap.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 05-03-2012, 01:23 PM   #13
HDRDTD
If you choose to go the powdercoart route and if the tires do indeed have to be removed for the baking process, then don't forget to figure in the cost of unmounting/mounting the tires.
My dealer has already told me that mounting the ZL1 tires would run around $100/wheel.
Ouch.
Old 05-03-2012, 06:00 PM   #14
htron50
htron50's Avatar
Drives: 2017 ZL1 Status "Thank You!"
Ouch.
I'm also gonna add that any gaskets for the air pressure gauges need to be removed or they will cook in the heat too... and all that does indeed come to about $100 per wheel!
htron50 is offline   Reply With Quote
