GM Parts House
Old 05-09-2009, 01:17 PM   #1
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
How are you breaking them in?
I want to know how everyone is breaking in there cars.
Have hit 5K once usually hit only 4k-4.5k have 200 miles on the car. Have not pushed the pedal all the way to the floor and have not done anything with the traction control. It has all been mainly in town driving except of couple of miles of 65 mile zone area. Have had it up to 72, but did not break 4000 RPM or over 55 for the first 100 miles. I have the auto.
So have I been bad and possible hurt my car? Or is this ok?
Anyhelp or telling how you have been doing it would be great.
Scott@Bjorn3D is offline   Reply With Quote
Old 05-09-2009, 01:29 PM   #2
CamaroScotty
Drives: Your new SLP Camaro!
Send a message via Yahoo to CamaroScotty
I usually go "easy" on the car for the first 1200 miles...
Scott, ya didn't buy a mustang - you're ok!
CamaroScotty is offline   Reply With Quote
Old 05-09-2009, 01:50 PM   #3
RyanSSaddict
oh no la migra
RyanSSaddict's Avatar
Drives: 2010 Chevrolet Camaro 2SS
I haft to be honest, I have not been very nice to my car, but theirs always the warranty. I know, I know you don't haft to yell at me, but Mustangs have been harassing me and I can't let them get away with it.
RyanSSaddict is offline   Reply With Quote
Old 05-09-2009, 01:57 PM   #4
blackedout010
Drives: on order black 2010 2ss
ill go easy first few hundred, change oil, and then raise hell!!!
blackedout010 is offline   Reply With Quote
Old 05-09-2009, 02:24 PM   #5
KILLER74Z28
MOD SQUAD
KILLER74Z28's Avatar
Drives: 2G1FT1EW9A9100666
Break in is such a farce in today’s times. Break the car in the way you are going to drive it… Most all engines today are roller so really only the piston rings need to be broke in; which comes with time. Look at how most high performance engines are broke in; 30 minutes on the dyno to check and make sure all is good and then “BAM” time to see what she’s got. … Me, I’m driving it like I am normally going to drive it… I will change the oil at 500 miles then call it good. If it’s going to break it’s going to break; not much anyone can do about faulty parts and or craftsmanship. This is how I have broken in all of my high-performance engines and I have not hade one issue.
Who cares about the Blue Oval crowd and their little Ponys? We're getting our Camaro back-and it'll be Supercharged!-MDAII
Team LS3
KILLER74Z28 is offline   Reply With Quote
Old 05-09-2009, 02:25 PM   #6
dankss
Contract Killer
dankss's Avatar
Drives: 2010 black 1ss/rs
i was thinking easy the first 500 then change the oil. AND SUPER CHARGERRRR!!!
dankss is offline   Reply With Quote
Old 05-09-2009, 02:57 PM   #7
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
burnout off the showroom floor.
I piss excellence
and fart awesomeness
Old 05-09-2009, 03:43 PM   #8
r0cketdr
r0cketdr's Avatar
Drives: RJT 2SS/RS
Now THIS is a plan And I interpret "going easy" as don't hit the rev limiter and don't stand hard on the brakes until "things" settle in.
r0cketdr is offline   Reply With Quote
Old 05-09-2009, 03:52 PM   #9
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Agree with Killer.
Modern engines are nothing like their counterparts of a decade or two ago. Bearing and ring materials are completely different and the level of finish on the crank/rods and cylinder walls is excellent. Valvetrains are also ready to go. These are roller drivetrains so varying the rpm isn't necessary like flat tappets for oil dispersion and tappet rotation.
The professional builders I have dealt with warm up the motor at 1,500 - 2,500 rpm, check for leaks and set the timing/fuel ratios. Then they change the oil and filter to get rid of any residual dirt/particles/break-in lube.
After that, they fire it back up, bring it to temperature and hammer it for as many dyno runs as necessary. This is from personal experience and there are probably factory GM types that know a whole lot more that can chime in.
Basically you are probably pretty safe in whatever break-in method you choose. GM tests these things to failure to make sure you don't...
If you want to be super safe, get to 500 miles to cover the drivetrain and brakes. Matter of fact you can do the pump and fade method to break the brakes in quicker. Change the eingine oil to get out any residual crap. Then fire it up and hammer it !!!
C'mon Scott. You know you wanna.....
Old 05-09-2009, 04:24 PM   #10
Miketebo22
Iceman
Miketebo22's Avatar
Drives: SOLD #20,908 SS waiting for ZL1
Send a message via MSN to Miketebo22
i kinda planned on hitting the speed limiter on the way home from the dealership! that appears to be a problem now...hmm...
2G1FT1EW8A9120908
Miketebo22 is offline   Reply With Quote
Old 05-09-2009, 06:14 PM   #11
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
I wouldn't do this now. The reason behind the 55 mph speed limit is because the brakes, tranny and drive train still need to be set and broke in. Not following this can lead to catastrophic failure within the first couple hundred miles when trying to stop.
Old 05-11-2009, 10:28 AM   #12
wirebender
wirebender's Avatar
Drives: 2013 ZL1 BRM, auto sunroof
what is "advanced remote start"?
Roto Fab CAI & res, VMAX PTB, 160* thermostat, NGK plugs, Moroso CC, 2.55 LPE upper & 9.1 lower pulleys & solid isolator, ATI balancer, BTR stage 3 cam kit, Kooks 2" LTs & HF cats (now gutted), FAST 90# inj., Afco dual pass HX w/fans, Alky Control meth kit, M2W, DRL Harness & LEDs, LED Fogs
wirebender is offline   Reply With Quote
Old 05-11-2009, 11:53 AM   #13
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
2-way technology and a convenient display screen shows the vehicles current status (locked or remote-start engaged, for instance) and critical vehicle data, including tire air pressure, fuel level, odometer and theft alarm status. This fob offers greater operating range then the factory keyless entry system, and can control a second, ARSS-equipped vehicle.
Remote start package only includes one remote key fob.
here's the fob
Old 05-11-2009, 11:59 AM   #14
rforbes
rforbes's Avatar
Drives: IOM SS/RS
Does anyone plan on putting in Slick 50 or similiar product on their first oil change, or is this a waste of money?
rforbes is offline   Reply With Quote
New, Better & More Pics of 2010 Camaros from Oshawa...As Promised Elvisuperman Camaro Photos | Spyshots | Video | Media Gallery 232 02-09-2012 09:30 PM
"V" Series and "SS" Series Performance Engineering Division Disbanded Koru 5th Gen Camaro SS LS LT General Discussions 108 02-19-2009 03:09 PM
White House Approves $17.4 Billion Auto Loans to GM & Chrysler josh1147 General Automotive + Other Cars Discussion 97 12-29-2008 02:21 PM
Breaking NEWS: Scott Confirms what we've been guessing. Mr. Wyndham 5th Gen Camaro SS LS LT General Discussions 53 10-23-2007 04:05 PM
Vert Pix from Donut Derelicts : from kenz Camaro Kenz Camaro Camaro Photos | Spyshots | Video | Media Gallery 15 05-16-2007 08:27 AM
